Question about Systemax Pursuit 2130 Notebook
Ethernet not seeing network cable when plugged in
When I plug in my ethernet cable to connect my laptop to the internet my network icon tells me that the network cable is unplugged. I've tried uninstalling and reinstalling the ethernet card from device manager but that doens't seem to fix the problem, I still get the same error message. I checked the Bios but I can't find anywhere to enable or disable hardware in there so Im probably looking in the wrong spot. Any suggestions would be greatly appreciated.
  • Mayaskyler Aug 23, 2007
    Im connecting straight from the modem with an ethernet cable, I've tested the ethernet cable on a desktop and it works fine. My modem is connecting fine to the internet and my desktop can browse without a problem. My ethernet port on the laptop itself is not seeing that a cable is even plugged into it. Is there a way to enable to the ethernet within the bios?
    Problem Solver:
  • 6 Answers
- If you have wireless card enabled, disable it to see if it fixes the issue. - Did you try a different cable that you know works for sure? -Go to the laptop manufacturer site and download the latest driver, it may help. -Try a different port on your router (if you have one), if you don't then check to see if the cable is secured. -reset your modem and router. -Are you using the correct cable type? make sure it is a straight-throug cable and not a cross-over cable. Here are some more troubleshooting tips from microsoft: http://support.microsoft.com/kb/910389
Posted on Aug 23, 2007
  • Mohammad Abubaker Aug 23, 2007
    If the NIC is disabled in the BIOS, then you will not see the adpater in "Network Connections" and it will not be listed in Device Manager either.
    If you have went though the Microsoft Link that I sent you ealier and none of the steps helped, then the only thing I can think of is Your NIC has gone bad or if you are not seeing any status lights on the Nic when it is plugged in, then check the 8 PINs on the NIC, one of them maybe bent or missing.
My M800 won't cannot detect any wifi or network and i can't get online
try to connect via lan cable.if u get online then look for wifi switch !
Apr 09, 2015 | Computers & Internet
Network cable not properly plugged in or may be broken
which OS do you have? XP, Vista, 7, etc. you must have a wireless adapter in your PC to use wireless and it must be enabled.
if not wireless, then you must have an ethernet slot with cable(CAT5) inserted from internet modem/router. if you have a laptop then you have wireless available. there is a key on keyboard to turn wireless on. you have to have your Network assigned to the wireless internet provider too. if you have cable(cat5) connected to a modem or router/modem connection, and you see an ethernet icon in your lower right corner window(looks like a little computer display), then you have an ethernet connection. if not then either the cable is bad or the modem/router is not producing a connection to pc. thats alot i know but i have little knowledge about your internet connection on your pc. you have not given that to me to use
Apr 18, 2014 | Microsoft Computers & Internet
Computer won't recognise ethernet connection from router
I don't know the make. model, of laptop or your OS? Open network connections, is it enabled? Is there a Network Icon in the Tray Notification Area? You really do not need a Disk to connect. Just plug in the ethernet and boot the machine.The computer should ID the connection, if it enabled and working properly. If not open Device Manager , Network Adapters and enable the ethernet adapter.For further assistance respond to post.
Dec 18, 2012 | Computers & Internet
Ethernet issues.
Can you plug pick up internet with a different laptop in the same place? If another laptop can plug in with the same ethernet cable and get a signal then you know its "your" laptop and not the cable or the connection, If it is your laptop that is the problem, check to see if your network card is working properly by going into device manager. My guess is you need a new network card.
Aug 20, 2012 | Toshiba Satellite L655-S5156 Notebook -...
My internet doesn't work
Plug a different computer into your cable-modem or DSL-modem, to see if that computer can successfully use the modem to access the Internet.
Try a different Ethernet-cable between your modem and your computer, to see if that fixes anything.
Click Start
Click Control Panel
Click Network Connections
Under the "Local Area Connection" icon, do you see "network cable unplugged", or "disabled" ?
If so, connect the cable, or right-mouse-click on the icon, and choose "enable".
Dec 07, 2010 | E-Machines eMachines Desktop PC
Ethernet to router connectivity issue
The correct way to do the connection is by plugging the Desktop to one of the Ethernet ports and any wireless device over the wireless network.
Dec 01, 2009 | Zyxel P660HW-D1 Router
How to hook your xbox360 to laptop to get on xbox live
wel if you have wireles internet you can get a wreles adapter for your xbox and conec it that way
Oct 25, 2009 | Microsoft Xbox 360 Console
My ethernet cord will work going straight into my laptop but shows no connection when plugged into router
under your network connection in your laptop is the on board ethernet disabled? this seems to happen sometimes or it gets done because people don't like seeing the icon on the lower right by the clock saying network cable unplugged
Aug 07, 2009 | Linksys Wireless-G WRT54G Router
Please clarify what you mean by ''Connect with an ethernet cable''
Ethernet cable means CAT5 or UTP for others or LAN cable. The connection should be LAN port of your computer to LAN1 of your router.
And you can connect also the internet cable usually ethernet cable from your internet provider directly to (ethernet cable)WAN port of your router to get signal from your internet provider.
Also if you get this message, this could also means you still don't set up or configure the router's settings to communicate when your LAN and router. They must see each other to access the router's utility webpage.
Regards
Jul 10, 2009 | Linksys Wireless-G WRT54G Router
Plugged ethernet cable innto laptop from cable modem and nothing
Click Start / Control Panel / Network Connections.
Your Ethernet status should show under LAN or High Speed Internet. It might be disabled, in which case, right click & ENABLE.
Let me know how you get on.
Jan 10, 2008 | Dell Latitude C640 Notebook
Systemax Pursuit 2130 Notebook Logo
740 people viewed this question
Top Systemax Computers & Internet Experts
Steve Allison
Steve Allison
pankaj rautela
pankaj rautela
Abhinandan  Patil
Abhinandan Patil
Are you a Systemax Computer and Internet Expert? Answer questions, earn points and help others
