Mitsubishi WS-65615 65" TV Logo
Posted on Aug 23, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Power gets to the TV -- power light initially comes on and then immediately turns off.
Vista Electronics
Level 3:
Genius:
  • Master 1,694 Answers
  • Posted on Dec 07, 2007
Vista Electronics
Master
Level 3:
Genius:
Answers
1694
Questions
Helped
585224
Points
2786
Use STK392-570 original Mits # times two............T.
Check fuses..................Let me know......
Anonymous
Level 2:
Sniper:
  • Expert 140 Answers
  • Posted on Aug 23, 2007
Anonymous
Expert
Level 2:
Sniper:
Answers
140
Questions
0
Helped
105160
Points
449
Check 5A micro fuses F9A04 and F9A05 - If one or both are open change both convergence IC's = STK394-250.
1helpful
My 55313 power light dose not come on
The SMPS section is not oscillating. Your TV need a through checkup. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electric shock. Instead, contact any experienced service technician, or the nearest service center.
2answers
My T.V. Will power on for a couple seconds then immediately turn off! Please help!
Unplug the unit from the outlet for at least 1 hour and check if the symptoms persists. If yes, check if the unit can give an error code by following the steps below.
- Power on the unit and wait until the initialization takes place.
- Press the front panel "Input" and "Menu" buttons at the same time and hold it for 5 seconds, it will activate the error code mode. LED flashes a two digit error code. Example, if the error code is "22" the LED will flashes two times pause and then flashes two times and will repeat the error code for 5 times.
"12" means no error has occured.
Please let me know what will be the result to assist you further.
Regards,[email protected]
Tv not turning on
U know how to solders?Replaced the convergence ICS and all it resistors,should get ur power back.Tries Websites Tv repair World.com,Tvrepairkits.com.First check ur DM power board see not any burn parts first.
2helpful
Mitsubishi ws-55511 does not turn on
Listen: you need to wait for the set to first shut off! then push on the TV(not the remote) Input and Menu both at the same time for 5 seconds and then release---the power light will then blink---this model has this feature--
2helpful
2answers
1helpful
Model CS- 40307 40 inch Mitsubishi TV will not turn on
continue to push power button until light turns green. verie rate of push and hold
Power problem on mitsubishi ws 48315
are a tech, if not you gonna have a hard time with this television you probably have to call a repairman
Mitsubishi WS-65313 - Will not turn on
The most common failure are the two convergence integrated circuits part # 267P173010. The two pico fuses may be open as well, which come from the power supply and provide +24 volts and -24 volts.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
