Question about Texas Instruments TI-83 Plus Calculator
Small black square in top left...won't turn off
Upon turning on calculator, I only get a small black square in top left corner and nothing else. It won't turn off unless I remove a AAA battery. My 15 yr old son is in calculus and needs this thing! Please assist...thank you~
  • joes mom Aug 27, 2007
    I replaced all the batteries...the triple A's and the CR1616...still has the same problem. I think it's odd that I would have to spend between $67 and $87 to send this one back to Texas Instruments to get a refurbished one!
  • Anonymous Mar 29, 2014
    My son noticed that one of the batteries leaked in his TI-84 and now it will only display a black square in the top left corner when turned on. The black square stays on for about 5 seconds and then turns off. Any suggestions? Thx
  • 35 Answers
You should replace the AAA batteries with new ones, and should by a new set of back up batteries.
Posted on Aug 27, 2007
It won't finish the start up
It is looking for something to boot from. Remove any CD and USB drives. Then try physically reconnecting the drive. From there you will need to verify in BIOS.
Check first boot in BIOS as well.
Jan 31, 2013 | Gateway ONE GZ7108 All-in-One Desktop PC
Dc17 won't turn on
there is a reset button under the cover that houses the on/off switches. remove the handle/wand and look on the back (where the top of the hose sits) for 2 screws (its a torx/star head screw size t10 i believe). remove them and locate 4 small locking tabs that hold the switch cover to the frame of the vacuum. Depress them and pop the cover off (2 towards the top and 2 towards the bottom). Youll see 3 switches (2 square red buttons and one small cylindrical shaped one). Push the small red one (the one to the left if my memory serves me right). you should hear a click. if you do than the switch is reset. if not check all connections to all 3 switches. if you see nothing loose or not connected, you may need a new brushbar motor.
Nov 18, 2012 | Dyson DC17 Animal Bagless Upright Cyclonic...
How do i use the radical symbol on my ti-30xs
The radical symbol is used to calculate square roots. It a radical has a small 3 to the top left of it, it means cubic root. It it has a a small n or a small x to the top left of it, it means nth root.
The way any of these roots works is one of the following:
Enter a number (positive for a square root or an nth root with n even) then press the square root button. The result is then displayed.
The other way is to press the root key then enter the number whose root you wan t calculate. The result is then displayed.
If you press the square root key and a radical is displayed withy a left parenthesis, you can be sure it is the second way.
Jan 26, 2012 | Texas Instruments Office Equipment &...
How to feed paper roll into calculator
Installing the Paper Roll
Caution: Avoid placing a double thickness of paper into the mechanism.
Do not pull the paper through the mechanism without pressing feed button.
1. If necessary, press on to turn the calculator on, and press P
to turn the PRINT display indicator off.
2. Remove the printer compartment cover by placing a thumb on each of the lower ridged corners of the cover. Push until the cover pops open, and lift the cover off.
3. Unroll a few inches of paper from the small roll and cut the end squarely.
4. Hold the paper so that it unrolls from the bottom, and insert the end of the paper into the slot under the printing mechanism.
5. Press feed button until the paper feeds out of the top of the printer compartment.
6. Place the small roll of paper inside the compartment.
7. Feed the end of the paper through the slot behind the clear plastic "window" of the printer compartment cover. Then snap the compartment cover back onto the unit.
Jun 07, 2011 | Texas Instruments TI-5006 II Calculator
HP LaserJet M4345 - The printer display is mangled, the touch screen does not respond properly to commands. Is there a way to reset it?
Calibrate the control panel
Use the following procedure to calibrate the control panel:
1. Turn the device off.
2. Press and hold the # key and the C key.
3. Turn the device on.
4. When a small white square appears in the upper-left corner of the control-panel display, touch
the square with a stylus.
5. When a small white square appears in the lower-left corner of the control-panel display, touch
6. Allow the device to finish the boot process.
Hope this helps.
Jan 25, 2011 | HP LaserJet M4345 MultiFunction Printer
I turn on the calculator and all I get is a small black square dot in the upper left corner. TO Connect can read the unit, but nothing works on the display.
If the small black square does not blink The Calculator is Locked
it need an hardware reset
let me know if you if you want to fix the Calculator
ecrdn@yahoo.com
Jack
Oct 21, 2010 | Texas Instruments TI-84 Plus Calculator
How do I fix my calculator if I can turn it on but cannot turn it off and press any button after I turned it on?
do you have a solid black square in the top left corner?
if so, blow hard into the I/O port on the top of the calculator. That fixed the problem for me.
Sep 22, 2009 | Texas Instruments TI-83 Plus Calculator
TI 84 plus calculator, flashing dot in upper left hand corner
When you turn the calculator on, its screen is cleared, save for a small square on the top left corner. This is the cursor and it is blinking: The calculator is waiting for you to order it to perform some calculation.
Try this simple operation
[1] [+] [1] [ENTER]. The calculator will display the result one line down justified to the right.
Hope it helps.
Aug 26, 2009 | Texas Instruments TI-84 Plus Calculator
No display on flip out screen
I have a Sony DCR-TRV30. Your camara is probably similar. On the bottom left outside corner of mine, there are two buttons, labeled "exposure" and "program AE," and a small thumb wheel above them. Set the indicator to "camera" and open the screen. Push the "exposure" button and a light grey rectangular screen with a minus sign on one end and a plus sign on the other will appear near the top left corner of the screen. Rotate the thumb wheel so that the small black square in the rectangular screen will move from the "+" side towards the "-" side while the image on the screen gets darker.
Jan 04, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
Setting tax
If the model is EL-2125 , and not 2125C or 2125E the following will work
1)switch on
2)press CE and then CA (you should see 0. with small 00 in top left hand corner but nothing else)
3)press M- button (rate set button),current tax rate 17.50% will appear with tax at left hand side
4) type new rate eg 15.00 (making sure to hit the decimal and two zeros, tax at the left and % should still be on the screen)
5) press M- (rate set button) (small 00 will appear in top left hand corner)
6) press = ( new rate and G will appear small 02 in top left hand corner and = sign below it)
hope this works for you, please let me know either way
David
Jul 31, 2008 | Hanns.G Corporation HW191D 19" LCD Monitor
Texas Instruments TI-83 Plus Calculator Logo
252 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
