Question about Numark CDX Turntable
Powers up but thats all folks......
You turn the beast on all the lights come on and stay on,it freezes... sometimes it comes on by its own free will,ive tried powering it up turned on its side or upside down a few times this worked but generally all the lights come on but nobody is home...anyone out there got a idea....
  • Anonymous Jan 20, 2009
    same prob.. no solution
  • KONCR33T May 16, 2009
    I turn power on...all lights come on but thats it. I really like the CDX but I'm always having a problem. I've got three and only one works right. That's alot of money and that's pretty sad.
  • 515 Answers
Hmm, that is rather strange. Have you moved the unit recently, or took it to a gig? Might have received a power surge or similar, which might have caused it to freak out. Not much you can do, but you might want to contact Numark (in Rhode Island - 401.658.3131) to obtain instructions on resetting the unit - might work, might not work. This generally involves either turning off the unit and pressing a series of buttons on the unit, downloading a small file, or obtaining a CD from the manufacturer. Numark's tech support is pretty decent, but they don't go too in-depth. If the resetting does not work, then you obviously have a more serious issue, and will need to have a service tech take a look at it. Might be a blown Resistor or Capacitor. Sorry, there isn't much more you could really do. Good Luck!
Posted on Sep 01, 2007
Same thing happened to me. Annoying! And mine was used. First the CD would load, got that fixed. Now it just lights on, that's it. Put a cd in and it spits it back out. I'm done with CDX's, although I do want this one to work cuz I don't have the $$$ to buy a new one or invest in a repair and I need it!
Posted on Jun 13, 2009
  • StreetSermon Jun 13, 2009
    Same thing happens to me. Just turns on, lights are on but nothing works. Spits CD's out. And I don't have the $$$ to invest in repairing it. What a dissapointment.... :(
THIS UNIT IS BRAND NEW LIGHTS UP BUT CD NO WORK
Posted on Oct 20, 2008
I Had the same problem wuth my cdx all the lights came on and stayed on.it stayed stuck like that and I had to send it back to get it repaired.Since I no longer was under warranty with numark I had To pony up(Get ready For bad news)$270 bucks.But The Good news is I sent it to T.S.I Repair Industries And They are a very good company.my cdx is working really good for now at least.I would suggest any body who owns a cdx to get an extended warranty because believe me you will need it.
Posted on Jun 21, 2008
SOURCE:
My ps3 keeps freezing games and movies ive done
turn off you playstation....then turn it back on to where the red light comes on (standby) then hold the power button til it beeps 3 times....it should turn on and back off durin this time....then repeat that process again and a screen should pop up and it asks you if you would like to restore playstation or rebuild database....try the rebuild database.... (it will delete everything saved on your playstation and it could take hour to rebuild it) if that doesnt work then yoyu have a faulty blue ray lens
Dec 27, 2009 | Sony Playstation 3 (PS3) Console
Car wont start
IS THE RED LIGHT THAT IS STAYING ON THE BATTERY LIGHT? IF SO IT COULD BE AN ELECTRICAL FAULT, AND IS NOT FIRING UP THE ELECTRIC FUEL PUMP
Mar 13, 2009 | Acura CL Cars & Trucks
Nds lite not working
Youve damaged the top screen cable - nothing to do with wifi block
see www.dsdoctor.co.uk
Jan 31, 2009 | Nintendo DS Lite Console
Amp works when beaten
It sounds like you have a broken connection in the amplifier. The first thing to check is the fuse. Sometimes the contacts become weak on the fuse holder and the connection becomes intermittent. Any other troubleshooting would require opening up the amp. Any repairs would require resoldering the broken connection.
Let me know if you have any other questions.
Sep 22, 2008 | Jensen XA2250 Car Audio Amplifier
Plenio VXA-3000 Navigation Unit, powers on but screen stays off.
If you Need Plenio Tech Support
www.dvssale.com
Dan Kim 408-970-3388 office
DVS Sales Inc.
2398 Walsh Ave.
Santa Clara, CA. 95051
Email [email protected]
posted 01.15.2009
[email protected]
Jun 01, 2008 | Digital Video Systems Plenio VXA-3000 GPS...
Does not power stay on
try this with just the ac plugged in and the battery removed. Sometimes the battery, when fully discharged, can cause the system to shut down.
check your warranty here for Free
Feb 22, 2008 | Toshiba Satellite M35X-S149 Notebook
Crazy turn offs
Symptom: Intermittent won't start, power supply LED's may be intermittent Cause: Power supply regulator I901 P/N CZ00868 is leaky, may verify the problem by freezing I901.
Nov 27, 2006 | Hitachi 60V500 60" Rear Projection...
Emachines 1900+ gets power to the monitor and computer but wont boot
There could be a number of causes. Do you hear any beeps when the computer starts up? Try seating all the chips in the motherboard. That means, apply pressure to each individual chip on the motherboard with your finger or thumb. The goal is to make sure each chip is securely attached to the board. Sometimes, heat or new h/w installs partially "pop" some of the chips out of the motherboard - causing the circuitry to be disconnected...
Aug 03, 2006 | E-Machines eMachines Refurbished EMA...
Numark CDX Turntable Logo
553 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Inno Laur
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
