Question about Samsung LE26R73BDX 26 in. HD-Ready LCD Television
Need help Hi I have a Samsung HD digital TV ( LE26R73BDX )about a year old. Recently the DTV has stopped functioning. It only allows the use of channel 5. None of the controls work when I want to use DTV, not even D.MENU. So I can not reset the system at all. Somebody advised me to turn the TV on by pressing the buttons ?INFO, MENU, MUTE and POWER? in sequence and within 1.5 seconds in order to open the MENU screen, but it didn?t work. On the other hand the ordinary TV works perfect. Is there anything that I can do to resolve this problem? Yours Allen
  • 1 more comment
  • Anonymous Nov 03, 2007
    Have the same problem my telly is 13 months old..... :-(
  • Move2Decaf Dec 02, 2007
    Mine started doing this about a month ago intermitently. Would switch it off and on again and it was fine. However, starting to happen more and more often, and having longer periods when DTV is totally unavailable - and all associated menus can't be accessed.
    Have reset everything during the periods I've got access, but still no good. Would appreciate any insight anyone might have...
  • Anonymous May 20, 2009
    I had exactly the same problem but did just as toph-phillip instructed and bingo now all is OK
    many many thanks
    Graham
Ensure the tv is in analogue mode, not dtv and turn it off. with the remote: press info then, menu, then mute then power. these buttons need to be pressed sequentially not all at the same time and in quick succession. a menu will appear on the tv. navigate to the reset option and press the left arrow key on the remote (or press the enter/ok button) the tv will reset itself and turn off. turn the tv back on & it'll re tune all its channels. DTV should be working again.
Posted on Mar 28, 2009
Can't get Digital TV (freeview)
Change the input to antenna.
If it says cable:
On your Samsung remote is a button that says antenna. You want it to say AIR. Air is an ATSC tuuner that allows you to receive over the air HD with a pair of rabbit ears.
If it says AIR:
If it says AIR and you still can't get the HD channels. In the menu it will say Channel. In that sub menu it will say autoprogram. Make sure you have an antenna connecte to AIR in the back of the set and autoprogram AIR only.
Any questions respond to this post and I will respond.
Jan 12, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
I have a samsung tv and dvd player and it has just started coming up on screen when i load a dvd to play a region error messagesayinh no good.It has been working ok before this.i just recently upgraded my...
make sure your tv is set in right language and location because after the big re-tune you might of entered wrong ones
the best way to do this is reset back to plug & play put tv in analog mode press TV/DTV on remote and then MENU ( NOT DTV MENU ) move down until you see plug & play in one of the menues press enter and follow on screen instructions
Nov 07, 2009 | Samsung LE32R72BX 32 in. HD-Ready LCD TV
Frozen samsung TV - wont turn off
since you say you have had it just a short time
call samsung and request service for your set this is a problem and will get worse
if its just a couple months old parts are still in warranty and not sure of labor there is a warranty statment in the owners manuel
Nov 01, 2009 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
Could you please advise if our model Samsung TV. LE26R8 purchased in 2007 has the built in FREEVIEW tuner. Many thanks, Peter smart
Yes it does.
If you look on your remote there should be a dtv/atv button and a dtv menu button to tune it into dtv.
Oct 16, 2009 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
SAMSUNG LCD TV horizontal lines
causing of horizontal lines is leaky or defective capacitors. check big value capacitors around the board at Horizontal area. check the filter capacitor as well. good luck
Mar 21, 2008 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
Samsung LE26R73BDX 26INCH - LOSS OF DIGITAL SERVICE
Solution that worked for me:
Beware: Although the process should be safe, it technically voids your warranty.
Enter the service menu:
1 - turn of tv with remote
2 - press and release in the following order on the remote: Info, Menu, Mute. Make sure remote is pointing at the tv
3 - turn on the tv from the remote
4 - you will see the service menu. using the down arrow on the remote select the Reset option. Using the right arrow button at this point will do a hard reset.
5 - Wait a few seconds, turn TV on
6 - you will have to rescan analogue and digital channel but it should be working now.
Dec 28, 2007 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
Digital Tv stopped working
I have got samsung 40 lcd is working fine but dtv got stuck on one channel. Its not moveing from one channel I have tried everything. Its not workig. please can you email me your suggestion to solve this problem.
Email address: fazalhareef@yahoo.co.uk
Dec 15, 2007 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
Samsung LE32R74BDX ...DTV problems
Oct 23, 2007 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
Dtv
I followed your suggestion and it works! You certainly do push the
info
menu
mute
power buttons but I cannot remember the exact order.
I may have pressed them altogether, or in a quick sequence and it may have been in standby mode or switched on.
Fiddle with it, because it does work.
What will happen is that you will get a set of commands on the screen. Use the remote to get to RESET. At first I coudn't get this to work as I kept pressing the "enter" button in an attempt to select this option, but actually you just need to press the right arrow button to select it.
Reset comes into place. Wait a while and press a channel number, then just re-tune. You will have to re-tune anologue and digital. This works - please share with others. Eamonn
Aug 23, 2007 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
Samsung LE26R73BDX 26 in. HD-Ready LCD Television Logo
834 people viewed this question
Jerry Greenberg
Jerry Greenberg
