Question about Sony FD Trinitron WEGA KV-32XBR400 32" TV
Sound but no picture
Hi All, need some help here. I came home the other evening, turned on my set, then after 5 minutes the picture just went out. Sound is still fine I can change between video sources but nothing on the screen. Not even the volume bars. I'm not getting any led code flashes either. I've tried the 4 hour reset, but still the same problem. Any help supplied would be apreciated. thanks
  • TimBigred Aug 24, 2007
    Thanks for the info Mike,
    Can you tell me which board the chip is on?
    Perhaps I can bring the board to a repairman instead of lugging the 150 lb set around.
    I know my way around the inside of the set.
    thanks
  • 398 Answers
The only time I have seen a Sony set with absolutely no picture and no on-screen menu but no error codes from the front LED, the main signal CXA jungle IC was bad and needed to be replaced. This is something that should only be attempted by a qualified tech familiar with Sont sets.
Posted on Aug 23, 2007
  • Mike Longo
    Mike Longo Aug 24, 2007
    Obviously, I have not seen your set so I cannot say for sure that your jungle IC is bad. I also do not recommend taking the board to a TV shop because guessing at the problem offers no quarantees that the set will work after you pay to have a new IC put in (if the shop agrees to do that), and it is possible that the board can be damaged where it wasnt before. However, if you still want to go that route, look on the CRT board and there will be wires attached, and the jack that has the red, green, blue information wires will go back to the board that contains the jungle IC. The most notorious jungle IC for causing problems is the CXA1477 series.
SOURCE:
Sony Plasma KDE 42xs955 has delay in of 5 to 10 minutes for picture to appear. Sound turns on immediately
Contact the authorized service centre for Sony. This is not a fault that a normal user can do anything. Electro help
Oct 22, 2014 | Sony KDE-42XS955 42 in. Plasma HDTV
Screen goes dark after 5 minutes with sound
Could be the ballast boards for the white light.
Jan 04, 2014 | Vizio VP422HDTV10A 42 inch 720p LCD HDTV
Start, drive, stop, need boost to start again; then after a day of not driving it will start without boost on the second day. What's going on?
check your battery. i had the same problem two months ago. i thought it was the alternator or starter , but the shop said i my battery wouldn't keep a charge.
Dec 27, 2011 | 1993 Cadillac Fleetwood
50 inch LG plasma model 50PX5D. Lost picture and sound
well it looks to me u need a new tv....all the details u give are pointing that ur picture tube is gone.....but call LG help and costumer line and ask them......u may get away from it to get a new tv
make sure when u get a new plasma to extend ur warren tie to a max o 3 to 5 years and if this would happend u get it repaires for free.......cost for a new screen app 1000 to 1500 dollars
Mar 12, 2009 | LG 42PC3D 42 in. Plasma Television
Picture but no sound on my Vizio L37 Flat Screen
I had the same thing just happen and I used the following instructions from the Vizio Website for "humming sound" on tv and it worked. My sound is now working!!!!
1- Power off TV
2- Unplug TV from outlet
3- Press and hold in the power button on the TV for 30 seconds (while it is unplugged from the wall)
4- Release the power button
5- Plug in the TV into a different outlet
6- Power the TV back on.
Reset the TV settings.
Jan 29, 2009 | Vizio GV42L 42 in. LCD Television
Sylvania 13 inch -- model unknown
Hi DiBd. Some electronic components in a tv can go out of tolerance during long periods of inactivity. I think that's what's happened to your set. Some component in the video section of your tv has given up.
Greg.
Aug 13, 2008 | Sylvania 6413TC 13" TV
TruTech 19" LCD TV+DVD
I have a sansui 19" LCD TV+DVD
I had to attempt multiple times turning the TV on to get a picture. The sound was fine. This kept happening when I would go to turn on the set the TV kept playing fine with picture & sound but after the 2nd attemts I turned it off & then tried to turn it back on which took multiple attempts, it kept playing for a few minutes then the picture went out but the sound was still there.
The set is not yet 2 years old.
Mar 13, 2008 | TruTech PLV1615T 15 in. LCD Television
Slow to No picture
What is the make and model number of your tv. Iclude cassis number if it is a RCA, Phillips/ magnavox. Need that info in order to even begin to offer any suggestions as to what may be happening with your set.
Feb 11, 2008 | Televison & Video
Picture has green tint on startup
Jar-Head, bad news, the picture tube has a mild short in the green cathode, tech can come out and try to restore it but it`s usually a futile attempt on sony tubes, sorry to be the bearer of bad news, BMW Rider
Jan 14, 2008 | Sony KV-32S26 32" TV
Sony FD Trinitron WEGA KV-32XBR400 32" TV Logo
66 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
