Question about Yamaha HTR-5790 Receiver
Powers on for just 5 seconds then off
With the use of remote or Panel button, it goes on for 5 seconds and then off. Took off the top and noticed that during the short on cycle, the fan does not come on. Unit has worked great for 2 years, now this problem. Any suggestions.
Re: Powers on for just 5 seconds then off
Took my Yamaha HTR 5790 to a repair shop for an estimate to repair. Cost me $50 for estimate to be applied to repair. It needed two circuit boards replaced at a cost of $390.00.
SOLUTION... they kept my $50 and I bought a new AV Receiver that WAS NOT a Yamaha.
Posted on Oct 11, 2007
0 characters
3 Points
My Yamaha RX-V661 powers on when I hit the power switch. After two seconds it goes to stand by.
try holding the 'straight' and 'audio select' buttons and press power. What does it say on the front panel? Should say some kind of protect: I, DC, PS. This will help narrow down where your problem is.
Oct 15, 2013 | Yamaha RX-V661 Receiver
Harman Kardon AVR 350, Unit powers off into standby mode after a few seconds. Removed all connections and wires, problem persists. Weirdly enough, if I keep pressing the source button, the unit stays on....
It needs to be serviced. Bad caps, resistors, & possibly a transistor or two. Not an unbearable repair, but you can count on it being 100-175 depending on the shop. You followed all the troubleshooting you could without opening the unit.
Oct 02, 2013 | Marantz SR8001
How can I get my onkyo remote control (RC-693M) to control my Sony LCD tv?
Manual says: 1. While holding down the REMOTE MODE button for the mode in which you want to use the command, press the [ON] button. *** Hold both buttons down for 3-4 seconds *** 2. Press the button you want to learn the new command 3. Point the remote controllers at each other, about 2-6 inches apart, and then press and hold the button whose command you want to learn until the Remote indicator flashes. *** Hold them level with each other, 2-3 inches apart, and don't move them at ALL while you press the button on the old remote *** 4. To learn more commands, repeat steps 2 and 3. Press any REMOTE MODE button when you've finished. *** If the command was learned correctly, the remote indicator will flash *SLOWLY* twice - about a 1 second blink, and the red light will remain on. If the command was NOT learned correctly, it will blink twice *QUICKLY* - about .5 seconds, and the red light will go off. *** If the red light stays on, you're golden - keep going until you get to a button that flashes red quick and the light goes off. Some of the buttons I programmed took 6-7 tries in exactly the same position to learn.
Oct 09, 2012 | Onkyo TX-SR705 Receiver
I have a Denon DRA 397 receiver and when I power it up the standby light goes on but nothing else powers up?
If you are not pressing the power button on the remote that may be the problem
Apr 11, 2012 | Denon DRA-397
My remote control stopped working except for the on/off button. what can i do to get it going again?
Start by changing the battery's, then if the problem still persists try and hold down the power button for 5 seconds and then see if maybe it took, if not then it might me time to replace the remote. I hope this could help. if not please let me know and i will try to help you out.
May 28, 2011 | Technics SA-AX540 Receiver
How do you unlock an ipod touch, I think I did this accidentally. the slider does not work
You might just want to try to force it to shut down by holding the sleep wake button on the top of the iPod for about 5 seconds. After it powers down, wait about 5 seconds, then hit the power button on top for about 1 second to turn it back on. After it powers up all the way you should be able to unlock your iPod.
Hope that helps!
May 03, 2011 | Audio & Video Receivers
How do I reset my yamaha receiver htr5730
Page 52
1 Hold down STEREO on the Front Panel
"Factory Preset" appears on the front panel
2 Press STEREO to select the desired setting.
'Reset' To reset to factory presets
'Cancel' to cancel without making changes
3 Press STANDBY/ON to confirm your selection
Jan 15, 2011 | Yamaha HTR-5730 Receiver
I have a denon avr 2802. the remote powers the
Try doing a factory reset by turning off main power switch.hold down speaker a and b buttons while turning on main power switch ,display will flash 3 time s then release buttons,this then returns unit to factory default settings.
Apr 13, 2010 | Denon AVR-2802
After powering up the display reads, "No Disc" and unit powers itself off after about 10 seconds.
Please update this with the make and model. With that info, I should be able to figure out what is happening. In generic terms, the unit performs some system checks when powered up. It seems that a problem is found that is causing the system to shut itself down. Any details about the unit and what you hear or see in addition to what you have already posted would be helpful as well.
Hope to hear from you soon.
May 06, 2009 | Audio & Video Receivers
Yamaha HTR-5790 Receiver Logo
333 people viewed this question
Top Yamaha Audio & Video Receivers Experts
Steven Wander
Steven Wander
Larry Stiles
Larry Stiles
Are you a Yamaha Audio and Video Receiver Expert? Answer questions, earn points and help others
