Question about Denon S-101 System
The standby light just blinks orange and no sound and nothing display on the panel. Everything else is working..cable box and tv and sirius box.
  • 4 more comments
  • Anonymous Dec 02, 2007
    same issue.
    please help.
  • CCSkinner Dec 03, 2007
    I recently experience the same problem. The system appears to be powered up but the on/standby light just flashes orange and nothing else seems to function. I have had the system for about 13 months so it is out of warranty (of course.)
  • hughug Dec 15, 2007
    Same problem here.Unit is only 4 months old.
  • peppersboi Dec 19, 2007
    I took it back to the store and bought a different unit, no one could figure it out.
  • BigoBear Feb 04, 2008
    I have had my unit a little over a year and am having the same problem. After ready the manual, It seems you are suppose to unplug the wall plug before detaching the other wires/cables. I had never heard of such a thing. I was told this was like surge protector and would have to be sent off to be repaired. bad design flaw. I still have not sent mine off to their authorized repair place which when I called, were clueless about the problem or how much it would cost me to fix it.
  • hanyst Apr 24, 2009
    I have the same problem, it doesn't power up but the power light button flashes when pressing it or pressing the play button.
    I checked the 2 fuses inside the Boom Box and they r good.
    Help please.
    Thanks,
    Hany
    Cell (310)291-6899
Same here orange light flashes! how would the subwoofer work?
Posted on Oct 24, 2012
Ic 802 PN:N70 broke
I cant fınd what it is . I thing fuse
I changed some wire and it is working
this part is on the 32 volts and on the power board in the player.
this part loks like bc transistor but it has two legs.
Posted on Jan 06, 2009
Same here stanby light flashes, any fixes?
Posted on Dec 19, 2007
SOURCE:
Soyo Flat Screen TV won't turn on. Red light blinks but nothing powers on.
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy.
If you're sound in electronics, and wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Flip card, can be selected by the drop-down list, by the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window. google.com/+GopakumarGopalan
Nov 01, 2013 | Soyo Televison & Video
Hey, At home we have a Sony Bravia KDL40l4000,
It sounds that the main board to this TV is faulty. A non stop blinking of standby light indicates that. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 15, 2013 | Televison & Video
The tv will not turn on anymore-have a blinking red light where the power green is located -is a flat screen hdtv connected to an xbox 360, tivo, and cable box. model no. 42PF9431D/37 . The cable is...
internal breaker, hopefully that xbox is plugged into a 3prong ac outlet. unplug the tv from electricity for a half hour and that circuit breaker inside should auto reset.
Dec 15, 2009 | Philips 42PF9431D/37 TV
Tv won't turn on
it was damaged during transit to you
May 29, 2009 | Westinghouse TX-52F480S 52 in. LCD TV
My thomson dti 6300 250gb free view box wont turn on
Emailed Topuptv and got this reply
Dear Sir/Madam,
Thank you for contacting Top Up TV.
Please note that we are currently aware of an issue affecting some Thomson DTi6300 boxes.
If your DTR will not come out of standby and is not responding to your remote control, please try the following procedures.
Step 1: Power cycle
First of all, remove the power to the box and wait 20 seconds before restoring power.
Wait while the box tries to restart and allow 2 -3 minutes for this to complete.
Try this at least twice.
If it doesn't go to the solid green light then proceed to the next step.
Step 2: Front Panel Reset
Note: This procedure will unfortunately cause you to lose all of the recordings that you have stored on the box. You will need to be able access the back of the DTR and the front panel buttons
1. Remove power to the unit by removing the power cable from the back of the DTR.
2. Wait 20 seconds and restore the power cable while holding in the standby/power on button on the front panel of the DTR.
3. Release the standby button immediately you see a light 'blip' on the DTR front display and then immediately press the following front panel arrow buttons in sequence Up>Down>Left>Right
4.The DTR will now show the Orange LED with the Green LED flashing until the format has been completed in about 60 seconds. The DTR will return to ON automatically.
5. If requested, perform a channel scan to complete the operation.
We apologise for any inconvenience caused. Our Customer Services department can also be contacted on 08444 159 159. However, please note that we are currently experiencing high call volumes and so may not be able to answer your call as quickly as we would like.
Kind Regards,
Richard
May 04, 2009 | Televison & Video
Right out of the box. doesnt work
Don't feel bad - these are cheap TV's and there are lots of problems with them. Just be glad it failed so soon that you can take it right back and get something more name brand this time.
Remember - always google the model number you are looking to buy (with either "repair" or "complaint" in the search) and you'll be less likely to buy an TV industry land mine.
Jan 24, 2008 | Maxent MX-42HPM20 42 in. Plasma HDTV
Phillips FTR 9964 Blinking Green/Orange Indicator Light
PHILIPS 42 WILL NOT TURN ON,WITHE FTR9964 RECEIVER
TO BLINK ORANG /GREEN AFTER 40 SEC ORANAGE
May 23, 2007 | Philips E-Box FTR9965 DTV Receiver
Denon S-101 System Logo
568 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
