Question about Whirlpool LSB6200KQ Top Load Washer
Whirlpool LSC9355DQO won't spin and makes grinding noise
My top loader worked fine until this morning. I tried to wash a set of sheets together with a mattress pad. When the machine got to the spin cycle, the machine started to make grinding noises and the agitator did not spin. I removed the soaking wet mattress pad and tried again. Same problems. I unplugged and replugged the machine. Problems remained. I checked the door latch and it still clicks. Any ideas on what's wrong and how to repair it?
  • 2 more comments
  • marinunited Aug 23, 2007
    Thanks for the suggestion!
    How can I find out the part number for the motor coupling?
  • Anonymous Dec 14, 2008
    Can you explain this in detail? I'm wondering why you don't mention removing the agitator, which seems to be where the noise is coming from. Is it my understanding that it is something that I don't need to remove it for repairs?
    Thanks a bunch.
    Victor
  • Anonymous Mar 31, 2014
    New mattress pad under the agitator after it was washed
  • 164 Answers
Grinding noises are never a good sign. My best guess is that the motor coupling is shot. Very inexpensive repair if you're handy. unplug and tip the machine back. locate the motor and remove the clips holding the motor/pump assembly to the transmission. carefully remove the motor and if the coupling is shot, replace. put it back together and should be good to go.
Posted on Aug 23, 2007
  • Geoff Siegel
    Geoff Siegel Aug 24, 2007
    go to sears.com and go to the parts section put your model number in and look for the motor coupler
SOURCE:
I have a Whirlpool Gold washer (MOD# GSQ9669LW0). The washer makes a grinding noise below when in operation. Spins when agitating, but not in rinse mode. Water still pumps out in final spin.
This machine can get items stuck in the drum, the bearings can go bad etc. https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Washing-Machine/38-5-620929-/Whirlpool-Washer-won-t-spin-GSQ9669LW0.
Oct 16, 2017 | Whirlpool Washing Machines
My maytag hav2558aww wont turn on wash cycle
Possible that the grinding noise comes from the drum, irregular movement or broken paddles.
You can try and attempt only if equipped with a fundamental understanding of the working .
I shall give you some tips to this click 1..: Washing Machine
2. Replacing bearings
Jan 24, 2013 | Maytag HAV2558 Top Load Washer
Whirlpool washer dryer has been making a grinding noise for a while and now won't drain
Hi.
The grinding noise was probably being caused by objects stuck in the drain filter. Disconnect power and check the drain filter. On Whirlpool front loaders the filter is accessed from the front of the machine. You will need to unscrew the filter cap and to remove blockage With top loaders the access is underneath or at the back. You lean the appliance on one side and disconnect the hose directly connected to the pump. Disconnect power before starting maintenance.
Here a page about drain/spin problem.
If you need parts see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Sep 10, 2011 | Washing Machines
Whirlpool WF665/1 clunking/grinding
Could be worn drum bearings.
Jun 04, 2010 | Washing Machines
My whirlpool top loader is making a grinding
The direct drive coupling is broken. This video will show how to replace it.
http://appliancejunk.com/forums/index.php?topic=3437.0
While you have it torn down check the drain pump for blockage too.
Dec 26, 2009 | Maytag PAV2300 Top Load Washer
Washing machine wont rinse or spin
it fills up with water but it won't spin and then makes like a grinding noise someone told me it could be a clutch
Aug 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Everything works-no spin-motor sounds like it won't engage
Sounds like the clutch is malfunctioning. Not an easy DIY job -- probably need a service call.
May 31, 2009 | Roper RAX4232KQ Top Load Washer
Whirlpool Ultimate Care Model LSR8233EQO - Loud noise during final rinse/spin
Sounds like the clutch, mi9ne works fine but is noisey when spinning, repair guy said it was the clutch.
Feb 05, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool won't spin at high speed
Sounds like you may have lost your basket drive and clutch assembly. This is a pretty involved job to replace for sure, and requires you to remove the inner basket, drop the transmission, etc. Does the unit make any wierd noises, like popping or grinding? Does it agitate ok in wash? I would bet almost for sure that its that basket drive and attached sub-pack thats went bad. If you want to try and tackle this yourself, let me know, and will get you directions to do so. Good Luck!!!!
Feb 02, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool LSB6200KQ Top Load Washer Logo
570 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
