Question about RCA Lyra RD1090 MP3 Player
Music player my mp3 player loads up the music to play it, but then freezes and doesn´t let me do anything?
  • 4402 Answers
SOURCE: rca h100a mp3 player
update the firmware
Posted on Jan 24, 2008
SOURCE: no display on my RCA OPAL M402A Player
heres how i did it when you plug it into the computer and it gets reqonized then you go to mycomputer and youll see where it says opel right click on it then go down to properties and go to hardware and u can either defrage it or you can scan for problems and if i was u i would scan and fix the problems first then defrage it but make sure u back up your data or it may get lost if that dont work then idk
Posted on Jan 24, 2009
SOURCE: my mp3 has been frozen
you need to push the reset button in the back its a tiny pin hole. stick a safety pin or a bobby pin. in there and hold down for like 10 secs. if that dont help then you may need to send it in.
Posted on May 09, 2009
SOURCE: RCA MP3 Player invalid license message
I also had this problem and I finally figured it out. I usually use the Windows media player to put my songs on my t MP3 player I used itunes 1 time to put a few songs on my MP3 player then i went back to using wmp and i kept getting the invalid license message, i put the songs on itunes and put them on my MP3 player and they worked perfectlly
Posted on Jun 18, 2009
SOURCE: the mp3 player will freeze up when I try to play
You need to update the firmware. You can do this by going to rca's website. After it's installed everything should work fine. My Opal did the exact same thing.
Posted on Oct 11, 2009
  • 93869 Answers
SOURCE: Unable to Play Music & microSDHC Card
Unfortunately, you can't use a microSDHC card in the TH1101. The TH1101 was designed to work with microSD cards. The microSDHC is a newer standard; while those cards will fit into the slot, they will not function properly in microSD devices. You'll have to limit yourself to microSD cards 2GB and smaller.
Posted on Jul 07, 2010
0 characters
1 Points
Hi i had bought my philips go gear 1gb 3 yrs back right now i am facing a problem i just format the go gear drive from my pc and now when i load the go gear with some music it doesn't show the contents...
MP3 players can only play music files in mp3 file format. You can download mp3 music files from the Internet toyour computer and then copy them to your MP3 player. For your CD collection, you need to convert your CDs tomp3 music files onto your computer or download them from the Internet and thencopy them to your MP3 player after you have connected the USB cable tothe MP3 player and the computer.
You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track. Click on this link for instruction on converting musicfiles to mp3 file format :-
Aug 24, 2011 | Philips MP3 & Digital Media Players
My daughter was given a ELMF53084 MP4 player without instructions. We have no idea how to load music onto it or do anything with it. Can you please advise of where to get the instructions from. Thanks...
MP3 players can only play music files in mp3 file format.You need to convert your CDs to mp3 music files onto your computer ordownload them from the Internet and then copy them to your MP3 player.
Click on this link for instruction on converting music files to mp3 file format:-
Mar 17, 2011 | MP3 & Digital Media Players
SwiMP3 (128 MB) MP3 Player: I have the original first version of the Swimp3 pl...
This could actually be an easy fix. If you have any files on the player that are not WMA or MP3 files, or that you've stored your music in folders - either way it could simply stop the drive from playing.
Incompatible Music Files: If you have loaded a music file that is not compatible, it simply won't play. The SwiMP3 player works with mp3 or wma files, but not aac (like from iTunes).
Solution: Remove the incompatible files. Convert your other music files to mp3 or wma, and if you are importing your songs direct from itunes, you'll need to convert them to mp3s first.
Incompatible NON-Music Files: An MP3 player is similar to a Thumb Drive or Flash Drive because it can hold any kind of file that will fit in the drive's capacity. However, if you have loaded an incompatible file - including JPEGs, Cover Art, Word Docs, anything that is not an MP3 or WMA file, the player simply can't translate it into music.
Solution: Remove the incompatible files, leaving only your mp3 or wma files in your root directory.
Folders: The mp3 player is not able to open folders and play music files stored inside, to the Swimp3 player the folder is simply an un-playable file.
Solution: Open the folders, move or copy the music files into the root directory (remember, mp3 or wma - not aac), then delete the folders.
I hope you find this helpful.
Swimp3 Troubleshooting Video
May 18, 2010 | Finis Swi MP3 Player
My samsung YPK3 mp3 player is fully charged and when I go to turn it on, it freezes on the loading screen. I tried the reset button, but it didn't do anything except turn it off.
try to remove all the music on your mp3 player, copy it on your computer so you can put it back later,
after removing all the music try to open it, then if your mp3 player loads completely turn it off then put back the music files
hope this thing helps?
Jan 22, 2010 | Samsung YP-K3 MP3 Player
Sansa View freezes when music is accessed (I've tried everything)
there mite be a corupted music file that is stopping your system from running properly like a coppy protected file or a virus encrypted file. check all your music that you load to be sure its not copy protected. jsut hover over the music file and wait for the info page to pop up on it it should say if its protected or not if it dosnt say anything then its not protected. as for finding the virus encrypted files thats a little harder just load one song at a time and see if it plays on your mp3
Jan 07, 2010 | SanDisk Sansa View 8GB MP3 Player - Black
Sansa c150
Wait till it runs out of power then charge it. It should charge up normally.
Jul 07, 2009 | SanDisk Sansa c150 MP3 Player
No sound at any volume, also freezes
You have a Bad unit. I had to go through 4 of these Before I got one that was Good.
Jan 13, 2009 | RCA Lyra Th1032 MP3 Player
Rca h100a mp3 player
update the firmware
Jan 24, 2008 | RCA H100 MP3 Player
How do i start?
Hook it to your computer. Go to My Computer and select the external drive device..which is your mp3 player. Then open your music folder on your computer and drag the music to the appropriate folder on your mp3 player. Make sure the extension on the music is .mp3 or it will not play. Once the music is loaded, unhook the mp3 player and you should see your newly loaded songs on the player.
Dec 29, 2007 | iLO (2 GB) MP3 Player
Having trouble with the facet on my mp3 player and trying to get it to play.
idk i have the same problem maybe you should push the reset button.
Aug 04, 2007 | SanDisk Sansa c140 MP3 Player
RCA Lyra RD1090 MP3 Player Logo
19 people viewed this question
Top RCA MP3 & Digital Media Players Experts
Gyula Lacz
Are you a RCA MP3 and Digital Media Player Expert? Answer questions, earn points and help others
