Question about Mitsubishi VS-50605 50" Rear Projection Television
Mitsubishi VS-50VA1 schematics or resistor ID
I have a big screen projection Mitsubishi VS-50VA1. A few of the components on the convergence board have burned, and I need to do some cleanup and possibly replace one of the chips. Anyways, three of the resistors have had their markings charred off, and if someone could tell me their resistance and rated wattage, it would be most appreciated. Even better, if you happen to have the schematics on hand, please let me know if you can email them to me. The numbers for the resistors are as follows: R8T98, R853, and R895. Any help would be greatly appreciated!
    Genius:
  • 1,694 Answers
Perform PIP bypass (must give up PIP function) 1)remove PIP module,leave out. 2)Install 22mf/50v NP caps on bottom of PCB. Mount cap to VP pins 5 to 11. " " " " " 7 to 9. Re-check video=should be clean.
Posted on Oct 04, 2007
  • Vista Electronics Oct 04, 2007
    Clarify==
    Solder cap between 5&11 on VP connector
    Solder cap between 7&9 on VP connector
Mitsubishi big screen rear projection tv the blue
The tv 100% have convergence problems,it dead.If any colors lines don't matches or stay in the - + convergence grid.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.The tv conververgence board must have these parts changes to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Dec 11, 2010 | Mitsubishi Televison & Video
How to fix a mitsubishi vs 55601 convergence problem? I can't get teh red or blue to line up, leaving a ghost like affect on the screen
hello, the reason for this is down to the convergance ic 2 large chips connected to metal frame called heatsink they usually located behind the tuner board, also there are some resistors in front chips and capacitor at either end these will need to be tested as well. hope it helps.
regards
shaun
Oct 19, 2010 | Mitsubishi VS-55601 55" Rear Projection...
I have a mitsubishi VS-50801 rear projection TV that has a very distorted and glichy picture
Ur tv convergence are dead.Ur tv convergence board require changing the 2 STK convergence ICS,and some or all it resistors.The shop will cost u $300-$350 for parts and labors.
May 19, 2010 | Mitsubishi VS-50805 50" Rear Projection...
Mitsubushi VS-5043 Rear Projection,,, Replaced 3 Converrence IC's. Recovered green color. Red color is bowed. Cannot move red crosshais in convergence set up. Is their a way to reset? Could something else...
There are a few low value 1-watt flameproof resistors in the convergence yoke circuits. They typically range from 1 to 3 ohms. An open resistor will cause the respective color to be non-responsive. Also chack that you have the convergence yokes re-connected to the correct connectors on the board.
Nov 10, 2009 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi Convergence Problem
you need to replace the convergence board but it will cost you around $200 to fix the board and components associated with it .......
Have you tried adjusting the convergence settings ........
Oct 13, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi big screen vs45605
I believe I have a convergence problem with my VS-45605, i cannot get the front panel controls to move the blue and red crosses. I dont have original remote and a universal remote doesnt work either, any suggestions.
Jul 24, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi VS-50705 convergence problem.
There should only be a couple of STKs, the R's are resistors, they STKs should cost under $20. This should be everything you are looking for. If you need anything else, let me know.
CHASSIS: VZ7
MODELS: VS-45605 / VS-50605 / VS-50705 / VS-55705 / VS-60705 / VS-70705
Ref # / Part # / Part Name & Description
IC8C01 267P141030 HIC- STK392-110
IC8C02 267P141030 HIC- STK392-110
Jun 05, 2008 | Mitsubishi VS-50705 50" Rear Projection...
Mitsubishi VS-50VA1
Go to http://www.remotes.com enter in the TV model number, and order it, as there is nothing that can be done in a case like this. You could try to borrow a remote from a local store to switch the set back to the tuner section or borrow an original remote from someone.
Sep 21, 2006 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-50605 50" Rear Projection Television Logo
239 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
