Question about GE JKP86 Electric Double Oven
F4 Hi... My oven is having some issues, there is an F4 blinking and i can turn the oven ON. The Microwave attached to it is working just find... i need to know what the F4 mean and maybe how to fix it, i called GE and they charge tooo much money just to send some guy to check out the problem that's not including the labor and materials.. so please someone tell me how to fix my F4 situation
  • luvin2thpick Aug 27, 2007
    Do you know where i can get a replacement for the temperature sensor?
    Problem Solver:
  • 6 Answers
Replace the temperature sensor. It is usually located in the upper left corner of the oven (inside). Two screws hold it in place and, if you're lucky, you can pull out the junction to disconnect the old and connect the new one. Do this with the power off, Please!
Posted on Aug 26, 2007
I have a kitchenaid convection oven with microwave F6 EO code
Your tring to fix an appliance that's 10 yrs. Old ! Replace is your answer
May 14, 2012 | GE JKP85 Electric Double Oven
The oven keeps beeping code F4.
F4 Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Aug 05, 2011 | Amana AOCS3040 Electric Single Oven
When baking in top oven for any period of time my oven will start beeping with an F4 blinking on the oven temp screen? What is it trying to tell me?
Hello & Welcome to FixYa
F4 error code indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. However, I believe it is the sensor as the problem is only with bottom oven. Please get back to me if you have any other questions.
May 03, 2011 | Ovens
Conbi microwave oven and grill grill and oven working microwave not warming up light on and turn table working as normal
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Troubleshooting Tips
Mar 05, 2011 | Ovens
F3 f4 gaas oven when preheated these numbers appear it beeps and shuts off
Hi, replace the oven temperature sensor if "F2," "F3" or "F4" is displayed. "F2" indicates the oven temperature is too hot and the oven temperature sensor is suspect. "F3" or "F4" indicates the oven temperature sensor or shorted or open.
Jan 22, 2011 | Magic Chef Ovens
Oven wont light gaves F4
Hi, the F4 error code means Open or shorted oven temperature sensor (RTD)..
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Oct 20, 2010 | GE 30 In Freestanding Gas Range ...
F4 code Dacor oven
F4 means there is an open circuit in the Oven Temperature Sensor. Could be a bad sensor that needs replacing, cound be an issue with the wiring harness.
A test would be to short the sensor wire together at the sensor. the error code should change to F3. then you would know it is the sensor and not the harness.
Mar 03, 2010 | Ovens
The oven won't turn off and it shows a e3 f4 in the display
Hi There
I have found this for you and hope this is helpful.And let me know how it goes.
F4 Shorted oven temperature sensor Replace oven temperature sensorThank you for writing to fix ya.
Best Regards Richard
Jan 06, 2010 | Ovens
luvin, F4 is a shorted oven sensor. Under 950 ohms. Should read 1060 ohms at room temp. The sensor is located in the upper left hand corner of the rear oven wall. Remove the 2 screws and it will pull out enough to remove the connector. Catriver.
Aug 22, 2007 | GE JKS05 Electric Single Oven
GE JKP86 Electric Double Oven Logo
194 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
