Question about Fine Digital FineDrive 400 GPS Receiver
Issue with the Input prong
There is something wrong with the input / inlet. The prong seems to have been pushed down and to the side so now there is no connection bewteen the cord and the input prong.
    Scholar:
  • 107 Answers
Do you mean the power socket? if so, you could take it to a TV repair shop and they may be able to replace it.
Posted on Jan 16, 2008
SOURCE:
I can't get the input to work. Neither the remote or the button on the side will get me to that menu where I can select HDMI. Worked fine yesterday.
The tv needs a hdmi signal to enable selection on screen. My guess is that there is something wrong with the hdmi cable or the output device (video player, cable box or such}
Dec 17, 2015 | Sanyo DP26640 LCD TV
I have an RGB port on my visio, but my remote does not have any buttons to get to RGB mode, I have all the others like HDMI AV and component... How do i get to RGB mode if it is not on my remote. going to...
There is a video/input/source buuton on the side of tv. Push it and all inputs will be there use volume control to move the highlighted input when you get to the one you want push input/video/source it will change the channel
Dec 13, 2010 | Vizio Televison & Video
Connect to tv problem
The cable you describe should be the only cable that you need. You want to make sure that you switch to whichever input you connect to on your TV. If you are getting sound but no picture there may be a problem with either the input or your cable. Connect the cable to a different input to see if it works. If it does then the problem is with the input on your TV. If it doesn't work then there is something wrong with the cable. You may have to get it replaced at the place you purchased the camera from/
May 29, 2010 | Samsung VP-D361 Mini DV Digital Camcorder
Cable input is not working
Sounds like you mabe be on the wrong source. Try hitting the input button on the side of the set to change inputs. Input channel up or down find tv hit input again. If on the wrong input you will only get a blue screen and message no signal that will apear for a few seconds.
Sep 21, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Push the water dispenser, water starts but then stops abruptly
Yes , replace the water inlet valve . The piece the wall water line connects to .
Aug 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Won't Charge! :-(
Hi. these situations are mostly caused by a bent or broken copper prong that is located within the input charger port that is inside the phone housing.
When you insert the charge cord into the input port, there are copper prongs that will have to connect to each other and , this contact point will transfer the necessary current to the cell for a proper charge.
If the prongs are damage in any way due to broken copper or, bent copper prongs, this will prevent the necessary current from flowing to the cell.
Most remedies are crude like using a tooth pick or paper clip to straighten out the prongs inside the port. these methods do more harm than good and i recommend sending this phone in for a input port transplant. the manufacture or local repair depot is the best repair solution for this situation.
There is one thing that i would do before sending it to the repair depot. try using a completely different battery cell. if you purchase a new battery and the charger continues to not charge, this will confirm the input port failure.
Please rate and god bless:)
Apr 22, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Speakers not playing correct on a Pioneer SX-550
It could be the speaker output or the amp input. If you have a headphone socket on the amp try headphones and hear if it's the same problem.
If it's the amp's power output then this can be repaired. It's a case of unsoldering the blown transistor or integrated amp chip and soldering in a new one. It's not hard but you need to find someone competent.
Apr 28, 2017 | Pioneer Audio Players & Recorders
Operating a SONY DVD player with RCA TV
The only thing I can think of is that you have the input option on the wrong input. Have you tried pushing the input button or TV/Video button? I hope it helps...
Feb 23, 2008 | RCA F27664 27" TV
Side Buttons - Not Responding (wrong input?)
These buttons can stick, when you press the buttons do they click
if not then it is stuck in.
Jan 27, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Power supply issue
sound like they have damaged the "new motherboard" when have installed it at the shop. Or they installed a cheap brand and it's not correctly sitting in the base. should ask them to show you the old motherboard they removed to make sure they haven't just fudged-up the old one.
Jan 13, 2008 | Acer Aspire 5004WLMi Notebook
Open Questions:
Fine Digital FineDrive 400 GPS Receiver Logo
Top Fine Digital GPS Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a Fine Digital GPS Expert? Answer questions, earn points and help others
