Question about Optoma MovieTime DV10 Multimedia Projector
Optoma MovieTime: The Lamp that Won't stay on
A few months ago, the lamp 'popped' and the projector shut down. I assumed the lamp was gone, but it came back on (after sitting for a while). When I noticed how hot one side of the projector was, I thought maybe a fan had burned out. So we set up a little fan to blow air across the unit, which solved the problem for a number of months. This summer, the external fan solution has failed, and the machine again shuts itself down (without warning), but now it turns off after only a few minutes of play time. The lamp currently has 507 hours. I have adjusted various settings to reduce the brightness of the lamp, to no avail. Is this how lamps fail? Is it a temperature sensor? And/or the cooling fan? Are their repair options other than sending it to Optoma?
  • 640 Answers
Its definitly a cooling issue.the temp sensor is working because it shuts the unit down.when a lamp goes it goes just like a light can open up the unit and locate the fan take it out and go to a radio shack a match it up to a universal fan.
Posted on Aug 28, 2007
Unit will not power on. replaced lamp, same result optoma movietime dv10
please Check Lamp Cover and Interrupt Switch
- Ensure that all connectors are securely connected and aren't broken
- Check LVPS
- Check Lamp Driver
- Check Main Board
May 27, 2014 | Optoma MovieTime DV10 Multimedia Projector
Why won't my Optoma DV10 projector won't turn on?
On an Optoma DV10 if its not the lamp timer, then it might be a cooling fan that needs replacing. Take out the old one, and look-up its part number online. If you don't feel confident taking it apart, have a qualified person do this.
May 23, 2014 | Optoma MovieTime DV10 DLP Projector
Temp light flashes and then shuts down
possiblely it is the problem of fan, try to check the radiator fan port.
later use the machine, shut off it, until the lamp fully cool.
projector color wheel, lens and bulb, remote, lamp power, mother board. all brand and most of model.
computer mother board, memory, harddisk,
HP server, switch, and router.
Nov 21, 2011 | Optoma MovieTime DV10 Multimedia Projector
The lamp of my optoma hd80 shut down after 20 minutes. The lamp indicator problem light on. My lamp as only 880 hours. Do i have to change the lamp now?
Hi Pierre,
Did you resolve this issue. I am facing a similar on. After a few minutes, the lamp shut down and the the red lamp light turns on. I was thinking it is an overheating issue.
Mar 25, 2010 | Optoma HD80 Projector
Optoma EP721 Projector Lamp will not come on
I had the same problem I thought the lamp was Broken orburned out.
I removed the lamp tried  to look at it and see if I could tell if it was burned out or not. Put it back in and it worked.
Oh I forgot! Originally I had loaned it to a friend and it came back broken. The foot at the bottom was broken so I assumed, that it was probably dropped or fell off the table.
So First I bought a second projector because the bulbs were so expensive. Then I did not try to check the bulb for a couple of month's It only had 70 hours on it Anyway Give it a shot. Worked for me
Feb 10, 2009 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Optoma DV10 projetor suddenly started made popping sound
Please Check and service the fans and the Air filters. then check again. In case the noise still comes then service the fans or replace accordingly. By complete service of projector, this will work.
Rave services
Jan 12, 2009 | Optoma MovieTime DV10 Multimedia Projector
Shuts down .
are fans running
is lamp thermistor positioned too close to lamp
is pj going into shutdown because its not seeing an input signal??? check menus to see.
Feb 19, 2008 | Optoma MovieTime DV10 Multimedia Projector
My MovieTime die after two LED flash for a second after power up.
Check the Lamp and replace if that is damaged.send for repairs if the Lamp is okay.
Nov 26, 2007 | Optoma MovieTime DV10 Multimedia Projector
Optoma MovieTime DV10 Multimedia Projector Logo
639 people viewed this question
Top Optoma Office Equipment & Supplies Experts
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
