Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
I INSERT THSI CARD IN MY TOSHIBA SATELLITE AND AFTER A FEW SECONDS THE SCREEN GOES BLACK! I need to carefully orchestrate my moves to retrieve pictures. I use it with my Nikon D70 digital camera. What is the problem? I used ti have the same problem with another 2Gb CF, don't rememebr teh brand,; I lost it several weeks ago.
    Problem Solver:
  • 7 Answers
Hm, odd problem, I'd try reformatting the drive (Windows) My computer > Right click > Format. If the drive's corrupted, that could be causing your problem. But remember, formatting will erase ALL data on the drive, back it up before you try this.
Posted on Aug 24, 2007
0 characters
3 Points
How do i transfer my pictures on to 2gb sandisk
Hello there,
You have so many ways to do this. It depends on the function of your phone or camera. You can transfer it via bluetooth or if you have a memory card reader, you can insert the card given that its an SD card. If its the micro one, you need to get the microsd to sd adapter.
From there, you can manage your photos.
Jul 14, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Activation of keys on an FTAS receivers
Your query > "Instructions on how to install new keys and activate an FTA receiver using a 2GB Cruzer Micro Flash Drive with 3 smarth technology"
Generic responses:
1. depending on your FTA receiver (brand/model/version) (BlackBird, MultiStar, UltraStar, Pansat, Digiwave, Viewsat, Coolsat, Fortec, Ariza, Twinhan... or even clones) you would need to download the appropriate firmware/satellite keys using your PC & Internet connection;
2. links to firmware/satellite keys maybe available from your FTA receiver manufacturer's website or forums such as HashHU FTA
3. in your PC, unzip the downloaded firmware/satellite keys to a temporary folder;
If you are using a stand-alone hardware FTA box:
a. plug in your 2GB Cruzer Micro Flash Drive to one of your PC's USB port;
b. copy/paste the unzipped files in the root directory of the Flash Drive. Verify that you have the .bin or .pmg of whatever your FTA box is using;
c. remove flash drive from PC's USB port and insert into the USB port of the FTA receiver;
d. on the FTA box, using your remote, go to Menu, Settings or Sytem Information, keys, firmware or receiver Upgrade, select USB, select Flash, Save, Activate or Upgrade;
e. wait until the FTA box has uploaded to itself the new firmware/satellite keys;
f. reboot (power on/off).
If you are using PC-based FTA satellite receiver:
i. run your FTA receiver program;
ii. select for Tools/Options/Upgrade or Update;
iii. browse/direct to search in your temporary folder where downloaded files were unzipped;
iv. once found, click OK/Update/Upgrade;
v. in some brand/model/version, there is an auto upgrade/update feature which will download appropriate firmware/satellite keys if you are online.
Hope that the this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Nov 24, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I cannot insert my sandisk 4g usb into my computer. The red part of the Usb is matched by a black portion with little holes. I cannot insert it into my computer. Help please
Try connecting the SANDISK to a different computer. It *should* fit.
Try connecting the SANDISK to a different USB port on your computer. It *should* fit.
Dec 08, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How do you put info on this sandisk also how do you get info from it
Do you hve a computer? You need to have a card reader? You can cpy music from the PC to the card and then insert it into the Player. You can write and delete music files as many times as you wish
Pleaae rate our help to keep the FREE service online ++++
Aug 30, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sandisk 8gig micro sdhc card
It is most likely because your card is a SDHC (NEW ) and your reader is just a SD.
Aug 03, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Memory card is not working
>You need to have a card reader.
insert your card in the appropriate slot and wait for the detection by your computer.
>Then open your my computer in which you can see your card, right-click it and select FORMAT.
This should solve your problem.
May 06, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Regarding my sandisk 2gb flashdrive
u need to update ur computer from the company that made it Looking forward to helping U Shaun
Nov 12, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I needs driver for Sandisk cruzer 512MB SDCZ6-512 Please download Driver
Sandisk how has a generic FlashCP (locking mechanism for files on their cards) is SDCZ-xx where "xx" is any version.
Otherwise you souldn't need a special driver. Your operating system should recognize the thumb drive when it is inserted into the USB port and load the driver automatically. If it doesn't then there may be some problem with the USB port or the USB port driver.
Jun 22, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
66 people viewed this question
Top SanDisk Hard Drives Experts
Brian Sullivan
Brian Sullivan
Are you a SanDisk Hard Drive Expert? Answer questions, earn points and help others
