Question about Samsung SCH-u340 Cellular Phone
Aftermarket battery I bought an aftermarket battery. When I instal it, a message comes up, non-supported battery see users guide. The battery will work, but will not charge. Is there a way around this, or am I stuck with this battery? By the way, the place I bought the battery replaced it with another one but I get the same message.
    Brigadier General:
  • 7,752 Answers
What you can do is try buying an original battery or taking the phone to a samsung mobile store have them try one of their batteries in it and see if the same problem occurs, if it does then you know to buy original batteries....
Posted on Jan 28, 2008
What causes "toner not recognized" message?
Printers are programmed to reject non-genuine ink tanks and toner cartridges.
Some of them are also designed/programmed to stop working altogether if you fit an aftermarket product and you will have to get a new printer. Most likely you have one of those.
Never use non genuine products. You can try and pull the new genuine OEM toner cartridge out and refit it and see if the machine will reset and recognise it. If not I don't think you are going to get it printing again and you will be up for a new printer..
Follow some of the trouble shooting procedures in the user manual and if none of these work you are probably done with that printer.
Jan 04, 2016 | Goalsetter X554 54 Inch Glass Extreme In...
My HP color Laserjet CP5225DN shows message: "Used Cartridge". How can I fix this?
It is telling you that a used cartridge is installed so that you know that the toner tracking system cannot guarantee exact remaining toner indications. The used cartridge message is not generated by a non-HP cartridge, Non HP cartridge will generate a different error.
Jul 16, 2015 | HP Color LaserJet Professional CP5225dn -...
Loses power every time you leave for a couple of days, service says is not the battery
If your battery is good you have a current draw somewhere. Do you have any aftermarket or non Subaru things installed? Like a radio, remote starter or a hardwired GPS or the like? If improperly installed they are often the cause of a draw on your battery.
I've seen batteries that test good with a load tester after taking a full charge but will still not HOLD a charge. If there's no aftermarket stuff installed, I think you most likely have a bad battery.
Mar 22, 2015 | 2015 Subaru Forester
Throttle relearn video you tube
Simply disconnect both battery terminals after installation of the replacement Throttle body. Hold the two battery terminals together for 1 minute, then reconnect the battery terminals to the battery. Be advised that use of aftermarket throttle body parts may cause the fault code to stay in memory, due to non standard electronics in them. If the throttle position sensors fail [part of the throttle pedal assembly] the fault code may still stay in memory. I've had a number of GM trucks which required replacement of both the throttle pedal assembly & throttle body assembly to correct the fault. The vast majority of aftermarket parts are now made in China or the third world. Quality control on these items is almost non-existent. It is very hard to find top quality aftermarket parts now. Engine sensors, electronic controls and engine mounts are three areas where I now use only dealer supplied parts. I've had to many headaches and wasted time dealing with defective aftermarket parts.
Aug 23, 2014 | 2006 Chevrolet Trailblazer
Check gas cap light is on after replacing stock with aftermarket cap
gas caps are either vented, or non vented. it sounds like you needed one type but bought the other...... Just a possibility
Sep 21, 2017 | 2004 Pontiac Grand Prix
Flashing red/green battery light
Some non-Dell batteries will cause the led to flash. There are some aftermarket batteries that have circuitry which 'fools the laptop' and prevents the flashing. As long as the battery is working there's nothing to worry about.
Feb 23, 2010 | Dell Inspiron E1705 Notebook
New aftermarket Inspiron 6000 battery will not power the Laptop
I would say that the power management portion of the system board is probably faulty if it behaves the same with both the factory battery and the aftermarket.
Many systems have the charge controller and battery interface on a separate board but unfortunately on the Inspiron 6000 it's integrated.
FYI, Here's a copy of the service manual for that system: http://support.dell.com/support/edocs/systems/ins6000/en/sm/index.htm
Jan 21, 2010 | Dell Inspiron 6000 Notebook
I keep getting a message of unauthorized charger when I plug in m
IF THIS CHARGER IS AN AFTERMARKET IT MAY NOT WORK WITH THE PHONE
Aug 10, 2009 | Motorola Lands Phones
Communication error?!
I'm betting you bought an aftermarket battery and not an original JVC battery. The error message you are getting is caused by the camcorder not being able to read the charge sensor in the battery. Some of the aftermarket batteries neglect to put that sensor in the battery, or have a sensor which does not match the OEM sensor in a factory battery. Try an original JVC battery. Is this solution answered your question bu sure to rate it. Thanks!
Oct 23, 2008 | JVC GR-D750 Mini DV Digital Camcorder
Sony Vaio aftermarket battery
i have the same problem with the aftermarket battery. my sony is VGN-S48GP which i have for 3 years.
there are a few posting about this on the web on how to solve them. some people are successful and some are not.
there is a .exe file call ISBmgr.exe which is contained in the start up sequence of windows XP, when the XP is installed with factory disk from sony. this programs checks the battery and does not allow non-sony battery to work with the notebook. i ask XP not to load this program and now i can use the battery.
THIS IS HOW:-
go to Run
type MSConfig
look for startup tap
find ISBmgr.exe
disable it
reboot
i like this method because the action is reversable. there are other posts on the web which ask you to delete the ISBmgr file. i did not choose that way.
Good Luck.
ecj
Feb 15, 2008 | Sony VAIO PCG-K35 Notebook
Samsung SCH-u340 Cellular Phone Logo
1,466 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
