Washer will fill agatate rinse but no spin checked pump pump is ok and not blocked can here water draining
The motor operates off the timer cams inside the timer. in the wash mode the agitator turns in one direction. when it calls for tub empty the motor reverses direction and actuates the pump. at this stage the tub should spin. sounds like the timer is bad for this one function. timers cost around $120. (mechanical timers)
Not a mechanical timer in this one..
was told to check motor control but dont know where it is
hmmm.. i hope not because i just ordered a control board yesterday , tryed to ohm the board and all i got was a open reading the board cost 115.00
after the machine fill the water level it goes to the wash cycle but the moter will not agatate the wash light just blink if you hit start wash light goes to a solid light but still no agatation.
I have a equator ex 2512 combo washer dryer, it fills with water then agatates then does nothing and the dial spins, then agatates then dial spins drum fill with more water, drum never spins and it won't drain water. I have to turn it off and drain water from the coin trap. Any ideas on what I need to fix this problem. Unit is old but only used a couple of times on the boat. I assume it's circa 2005
washer spins instead of agates
