Question about Philips 55PP9401 55" Rear Projection Television
T.v. power up then shut off
T.v. red light comes on no piture no sound t.v. clicks three or four times then cuts itself off
    Genius:
  • 1,153 Answers
Your set is in High Voltage Shutdown because 1 or 2 problems. If there was a color problem or Convergence problem before the set went out. You should first change out the converg. amps. If no colour problem then check 6810, 7801, 7802 replace with exact parts also look for bad caps high voltage 200v@470uf change all, power supply and defection board.
Posted on Aug 23, 2007
  • Lashawn Robinson Aug 26, 2007
    If nothing helps then check for open glass fuse. this looks like a resistor in a glass case. My be 1900, 2004,1206 these maybe open and also look for a short, reg. maybe. for this procedure someone should know about components and shorts and opens.
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Oct 26, 2011 | Sony KDF-E42A10 42 in. LCD Television
Tv will come on but shuts itself back off
Sounds like it just needs a new lamp.
The way to tell is the lights in front:
green blinking as TV reboots = bad lamp
red three blinks = door switch
red four blinks = bad fan
6 or 9 blinks = bad thermal fuse
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Dec 17, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
There is no picture or sound just a blank screen
Thats the error for convergence failure. You can get the convergence repair kit for your model at the following link. The kit contains the parts and detailed instructions.
http://www.tvrepairworld.com/
Aug 01, 2009 | Panasonic PT-47WX53 47" Rear Projection...
WARMING PLATE DGB 300
The Automatic Shutoff Time can be programmed
anywhere from immediate shutoff
after completion of the brew cycle up to four
hours. When the coffeemaker shuts itself off,
two tones will sound. Four hours is the default
time. The 0:00 setting shuts the unit off immediately
after brewing is complete. To check the
current setting, press the “On/Off” button and
the Automatic Shutoff Time will be displayed.
To change the preset time, press and hold the
“On/Off” button until the red “power” light
begins to flash. This signals that you have
entered the “Set Automatic Shutoff” mode.
Press the “Hours” and “Minutes” buttons
to scroll forward through the digits until
desired time appears. The first setting which
appears is preset at “4:00” and the next
display will be “0:00”, since four hours is the
maximum Automatic Shutoff setting. Pressing
and holding either button will allow you to
scroll continuously, slowly at first, and then to
accelerate to the rate of about three digits per
second. As the desired time setting approaches,
release the button and then press repeatedly
to advance one digit at a time.
The Automatic Shutoff Time (ASO) may be
programmed either before or during coffee
brewing. You may also re-program the ASO
time when brewing has been completed. If you
do so, the Automatic Grind & Brew™ will automatically
account for any time that has already
elapsed after brewing.
Feb 01, 2009 | Cuisinart Grind and Brew DGB-300BK 10-Cup...
Philips 37pf9975/12 wont switch on
i have a Philips 37pf9975/12 and after about 1hr it switches itself off the green light stops on the side but you loose picture and sound. if you push the stand by button it clicks for about 1 min and then turns itself back on???????
Jan 09, 2009 | Philips 37PF9975 37 in. HD-Ready Plasma...
No picture, no sound.
Hi i have a pilips 42" plasma tv (42PF5320/79) i can hear clicking the green light is on and the tv will go into stand by if i press the power button and the red light also comes on .I have turned it on and off and it works now nothing just the light on the front as if its working looking at the back through the slots two green lights come on then the tv clicks and they turn off,thanks
Aug 06, 2008 | Philips 42PF9630A 42 in. Plasma Television
42PF7320A/37
Hi again,
Did you try connecting the TV into a different power outlet?
Jun 07, 2008 | Televison & Video
Sony KDP-51WS655
how many times does the light blink?
Feb 19, 2008 | Sony Grand WEGA KDP-51WS655 51" Rear...
Philips 55PP9401 55" Rear Projection Television Logo
66 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
