Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
ESata connection I have tried to hook this drive up with a Vantec eSata PCI card. I installed the drivers for the card, and hooked everything up but it wont recognize the drive in this mode, and I have to switch back to the USB connection. Is there another setting that I need to change for this to work, or is the problem something else?
  • Schwoebel Aug 25, 2007
    I went ahead and downloaded the drivers again. No change, so I am hoping that there is something in the configuration that can be done so that it will be recognized.
  • Schwoebel Sep 09, 2007
    Well, there was another solution here that seemed to disappear, and that was that the cable was not plugged in firmly enough, it seems that these drives you really have to get it in there solid to ensure the esata connection.
    I am happy to report that the drive now works via esata.
    For you timtech, You dont have to have an install package for the drive, but make sure that you have a package or drivers for the esata port, which in this case is your motherboard. So assuming your motherboard driver/bios is current, then it should be a matter of hooking it up.
Hi
This is pretty low tech but I tapered the edges of an esata cable at the connector which allowed it to be pushed deep enough into the Freeagent Pro to provide a good connection. I used an xacto knife to shave it down, it took 5 minutes, works really well. Ridiculous that Seagate allows this to be released en mass like this but still, a great hard drive other than that.
Posted on Oct 18, 2007
    Problem Solver:
  • 8 Answers
I am having the same exact problem with the 320GB version with e-Sata. The USB connection works, but I bought it strictly to use the e-Sata connection. I have the ASUS M2N32-SLI Deluxe which has the onboard e-Sata port. The drive only had the FreeAgent software already on the drive, I do not think my drive came with an install package, and their website does not have one either. Please let me know if anyone has had experience with ANY e-Sata external drive.
Posted on Sep 09, 2007
  • 4 Answers
Are you using the latest drivers? Most of the time the drivers you get with products do not have the latest drivers. Try http://www.vantecusa.com/download.html This will have the latest drivers for your operating system.
Posted on Aug 23, 2007
Vantec nexstar will not mount as removable
On windows seven there is no eject or remove safely in the main menu. Use mouse click <START> <Devices and Printers> find the device then right click and then select <Eject> or <Remove Safely>
Voil? you now can remove device without having to shut down computer.
May 18, 2017 | Vantec Nexstar Computers & Internet
Just installed Vantec 2+1 Firewire 800/400 PCIe card on my windows 7 - 64 bit desktop. Card seemed to install OK using Microsoft driver. Device manager says it is running OK. Whenever I try to connect a...
sir....
Sorry for the trouble...
I suggest that you try using a different video capture software to capture videos using the firewire card to resolve the issue.
thank you.............
Nov 19, 2011 | Vantec Computers & Internet
After installing the card my PC won't boot. Went into the BIOS and disabled booting on this card but still won't boot. Running Windows XP 32 bit system. I believe it has something to do with the RAID...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
dont forget to vote
hope this helps
Feb 02, 2011 | Vantec UGTST310R PCI Host Card 6 Port 4...
Nothing happens when I plug this in. I've tried eSATA and USB, both with the power adapter. The blue light comes on but nothing else. The hard drive works in other enclosures so I know that isn't the...
Your assumptions are leading in the right direction.
  • The blue light would just be denoting power to the device the red light would denote drive activity. The limitation on this enclosure is that its white papers states a "Hard Drive Compatibility: 320GB HDD capacity", but I have seen people use a 500GB drive that seemed to work. If your using a drive larger then 320GB this may be an issue.
  • The enclosure HDD combo is Plug-N-Play via USB so this would mean drivers most likely are not the issue. I don't believe drivers are even packaged with the device which would mean they use protocol standard drivers from the OS.
  • Make sure that you are not hooking the USB up to a external USB hub (especially a bus-powered one) while trouble shooting as it may not provide enough power. Connect the drive up to system USB controller directly while trouble shooting.
  • I believe this device has the ability to hook up 2 USB cables at the same time for extra power (mainly while using the eSATA connection). Try hooking up the USB mini-B connector and the USB +5VDC connector and then hooking both up to the system on two different USB ports. This should then correct the possibility that your drive may not be getting enough power.
  • Lastly, the enclosure could have a faulty IC on the PCB. Exchanging it would provide the answer for that.
Hope this was helpful. Thanks for visiting FixYa.com
Feb 02, 2011 | Eagle Tech ET-CS2XMESU2-BK 2.5" SATA to...
I'm trying to plug my sata hd into my esata DVR
What you can do is go to a good computer hardware store like, new egg. or somewhere that sells core hardware for computers. you should be able to buy a PCI-E or a PCI ESata card so you can plug it in. hope this helps!
Sep 10, 2009 | Mag Innovision InnoVision XJ 717 Monitor
SATA Raid card on PCI unable to detect eSATA Hard Drive
if you install the raid controller drive,it means it will shown the drives..but it not shown? is this what you mean? did you try to see in the computer management? if you dont know, check this out..right click my computer-manage-select disk management and check if your drive is there......this is only what i know about what you mean.
Mar 03, 2009 | Intel Motherboard
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
171 people viewed this question
Top Seagate Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
