Question about Motorola Mobility RAZR V3
RAZR V3 DEAD SCREEN
Hello, the screen on my razer is dead all of a sudden. The keypad works but both screens show nothing at all on them. The phone appears to work as it rings and I can answer the phone. If the screens got "burned" how can that happen at once for both of them? I read previous solution regarding the moisture dots and they appear white. Please help. Thank you
  • 5 more comments
  • Anonymous Jan 03, 2008
    I woke up to the alarm of my razr v3 this morning, and later in the day when opening the phone up realised that the display had died, although everything else appears to be working fine.. im going to try dismantling it and checking the display connectors as recommended, should be interesting!
  • Derek Godfrey Feb 04, 2008
    Same problem... I'm fairly tech savvy and not the least bit afraid to take this phone apart...
    Anybody got suggestions on what I ought to look for while I'm operating???
  • corkkb Feb 10, 2008
    I had used it 10 minutes beforehand, opened it up again and the screen was dead. I can still receive and dial calls but can't see anything at all on the screen. I've had it for 4 months, never dropped or even banged it..
  • Anonymous Jul 31, 2008
    I had the same problem and bullfrog's solution worked. Thanks! Jim
  • pinekonez Aug 29, 2008
    My razr sat in a little puddle of water for several hours. After letting it dry overnight with the battery and sim card out, I turned it on on the morning. The phone would make calls, the keypad would light up and the sound works. However the screen was completely dead. Bullfrog's solution worked like a dream. The screen is a little discolored, but still visible throughout and completely functional. Just start with your phone on and follow his directions. Thank you!!!!
  • Anonymous Nov 04, 2008
    screen is out - after battery fell out
  • Anonymous Jan 29, 2009
    same exact problem. word for word.
    Problem Solver:
  • 3 Answers
This worked for me - I had to do it several times because I never figured out whether to start with the phone "off" or "on".
Press # * and the "end call (red)" buttons simultaneously and hold for several sections. Then power phone off and back on. I read this was the equivalent of "safe mode" booting for a RAZR. My phone has performed flawlessly since I did this on the 6th of February!
Posted on Feb 22, 2008
Bullfrog7's solution worked for my phone after losing display from being dropped. Thanks!
Posted on Oct 29, 2008
    New Friend:
    Problem Solver:
  • 8 Answers
    New Friend:
Motorola Razer V3
My Screen went blank and I am sure I need a new phone. I want to retrieve my data though.
Any idea how can I get the data transfer from my phone to my computer or sim.
Cheers
Posted on Nov 01, 2009
    Brigadier General:
  • 7,752 Answers
You need to have the flexcable replaced on the phone, so take it to a mobile service center and have them replaced it.
Posted on Apr 19, 2009
Thx guys
was driving me nuts... now everything is fine
great info
not even the phone carrier knew how to fix it!
Posted on May 13, 2008
Buy a new fone beleve me it works
Posted on Oct 17, 2007
SOURCE:
Black screen
HI
make hard reset to the phone 9you will loose all your data)
if it does not help probably the screen is dead -or you will have to replace the screen or to buy a new phone
bernard
http://www.rylwy.com/
Jun 22, 2012 | Motorola Mobility RAZR V3
Phone is working but the screen is black
squeezed lower left side of display and powered up ,problem fixed
Sep 12, 2010 | Motorola Mobility RAZR V3
I have an older model motorola razr that the screen went blank but it is stil working.
Yes this is the most common problem with the RAZR.
There is a small cable connecting the screen to the keypad part of the phone. This cable is called a flex cable and fits through the hinge of your RAZR so that the screen and keypad are connected even as the phone opens and closes on the hinge.
BUT, this cable often wears out or can even be severed even a slight bit, and the phone would then work, but only the bottom half, the screen would be dead. I fix this issue for people more than any other cell problem. You need to have the flex cable replaced.
Nov 28, 2009 | Motorola Mobility RAZR V3
So, the screen on cell phone is completely dead, can it be fixed?
take the phone to a mobile service center and ahve the lcd or flexcable replaced on the phone.
Nov 08, 2008 | Motorola Mobility RAZR V3
Motorola razr v3
the phone need to be flash to correct this issue, so take the phone to a mobile service center to correct this...
Oct 25, 2008 | Motorola Mobility RAZR V3
Motorola razer V3
what you should do is take the phone to a mobile service center and have them fully service the phone.
Jun 09, 2008 | Motorola Mobility RAZR V3
My V3 keypad is not responding
probably your flex connector get loose or defective... if you can open your fone try to check it... if not, just visit your service center..
Oct 31, 2007 | Motorola Mobility RAZR V3
Blank Screen
Sounds like the charger's defective. Did it get dropped accidentally? Take both the phone and the charger back where you got it. They should fix the problem for you. Battery in the phone is probably dead and just needs charging.
Aug 19, 2007 | Motorola Mobility RAZR V3
Dead phone but keypad flashes
replace the LCD + flexcable on the phone.
Aug 02, 2007 | Motorola Mobility RAZR V3
V3 dead but keypad flashing
I had exactly the same problem. After unsucessfully looking for a solution on the net I removed the simm chip and set it aside. The next day, I put it on PC usb charge and left it overnight. The next day, I powered it up and it worked. I turned it off and replaced the simm and it is now working fine. Go figure...
Jul 29, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
2,403 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
