Question about Nostalgia Electrics KPM-508 Popcorn Maker
Heating The popcorn motor runsturning the popcorn inside but it will not heat, the heating element is working if you apply direct current but when you put it all back together. the element will not heat.
  • Anonymous Mar 25, 2014
    won't heat up element is bad need a new one
    can't find code or number to get replacement part
Most likely the thermal fuse blew... Ohm it out and if its open then replace it. Take yours off, take it to your local Radio Shack
Posted on Feb 19, 2008
When I turn on the heat for the kettle to warm up. the breaker kicks.
It's shorting out somewhere. One likely area is the heating element inside the kettle.
Sep 28, 2014 | Gold Medal Popcorn Poppers Pop-O-Gold With...
Any trouble shooting tips. My heating element under the rollers is not working
The heating element may have burned out - do you know anyone who can test it?
It may possibly also have a thermal fuse inside - that's not something you can easily replace, but it's cheaper to have someone replace that then to have them replace the heating element.
Jul 31, 2014 | Nostalgia Electrics Hdc 701 Carnival Hot...
When plugged in, only the light works
its done...the element has blown and overloaded the motor....dont brother fixing it.
Dec 03, 2013 | Kitchen Appliances - Others
Barrel turns no heat-new fuse-same-new element-same. Old element burned could new fuse pop and I need new one
Be sure to check for lint inside the filter housing and also vent blockage. 240 volts is going into the dryer. The motor runs on 120 so you might have a voltage problem. Heating element needs 240 volts. here is my video let me know if this helps:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 21, 2012 | Kenmore Dryers
Will not pop the popcorn. The motor works, just will not heat up
Not familiar with the model but my best guess would be it needs a new heating element.
Oct 15, 2011 | Nostalgia Electrics CCP-200 Popcorn Maker
Machine light+motor work,but will not heat up
Did you ever get it to work.. Its either 1 of a few things.. the heating element.. wiring or the thermostat.. youll have to remove the bolts that hold the kettle in place to see the wiring .. let me know.. i just repaired one that had the same problem..
Mar 29, 2011 | Bond Helman Old-Fashioned Movie Time...
Heating Element stopped working
remove the heat element cover attached to the element will be a thermal fuse it looks like a silver tube with a flat end and, a pointed end; remove and, replace the fuse; radio shack sells the fuse
Aug 28, 2009 | West Bend 82306 Stir Crazy® Popcorn...
My popcorn machine wont heat up
First, if you have another cord like this one (for example, a coffee pot cord) plug it into the popper and see if it works.
If it's not the cord, it's probably a blown thermal fuse inside the unit. Could be a heating element broken as well. If you don't have appliance repair experience, I would take it to a repair shop.
May 03, 2009 | Cretors Goldrush Popcorn Maker
Popping plate not heating up
Remember the strirring rod connects to the motor, but the heating element connects via the two prongs in the rear, so the motor can run without the heating element turned on (turn on the base without the plate on...the motor runs fine). Try reattaching the plate...it needs a good connection to the connectors in the back. It should heat up pretty quickly. Also, if you put the heating pad in the dishwasher, make sure it is dry and that the contacts aren't tarnished.
I'm certain over time the contacts will get loose and the popper will stop working, but our is going fine after a year.
Also, be careful not to drop the base...lots of cheap, hard plastic that will break and rattle around.
Mar 01, 2008 | Cuisinart CPM-800 Popcorn Maker
Nostalgia Electrics KPM-508 Popcorn Maker Logo
520 people viewed this question
Top Nostalgia Electrics Kitchen Appliances - Others Experts
Robert
Wayne Fellows
Wayne Fellows
Christopher Smith
Are you a Nostalgia Electrics Kitchen Appliances - Other Expert? Answer questions, earn points and help others
