Question about Fedders V Chassis A6V10S2A Air Conditioner
Fan will not start
This is a brand new unit. The compressor will start but the blower will not start?
  • Anonymous Jun 30, 2008
    I have the same problem. Compressor works, fan doesn't. No warranty due to Fedders' bankruptcy.
    Novelist:
  • 75 Answers
Some things you could check first would be to make sure you got all the packing out of it. May just be something blocking the fan blades. Make sure you have the right power supplied to it. Probably 110v 60 cy with a ground which is the normal house plug in the USA. If that's not the problem, I would call the place you bought it from and tell them what's going on with it. If you don't get help there, call the manufacture. In most cases they will have you return the unit for a new one.
Posted on Aug 27, 2007
SOURCE:
HOW TO CHANGE EVAPORTOR FAN AND WHERE IS IT LOCATED NEED SPEC SHEET -
Start with Make and Model? Go to their website and get manuals.
Sep 14, 2014 | Refrigerators
Brand-new window unit emits musty smell when compressor shuts off
It SHOULD NOT ... (smell in... even in WEST TEXAS).
BRAND NEW... Rush on down and get a good
NEW one.
I would suspect the condensate drip pan is plugged...
Common for AC units ..
But NEVER in "brand new"...
Get that (previously owned (my opinion)) UNIT
back from where you bought it ... Trade it in for a CLOSED BOX... and make your sales CLOWN write up why you are returning it.
Mold can be quite dangerous!!
Carnac the Magnificent
Apr 26, 2017 | Frigidaire Heating & Cooling
I have a GE Monogram ZIBI240 Bar Refrigerator with Icemaker. This unit is brand new out of the box. We purchased it 5 years ago and it was never installed (for reasons I won't go into). Installed i
is the compressor running if so it is out freoin or compressor is bad or want start may be relay compressor should start after the fan starts
Dec 12, 2011 | GE Refrigerators
AC is not cooling
Problem #1:Outdoor condensing fan motor has stopped running. This problem could be caused by a bad motor run capacitor. If your motor capacitor is not the problem, then more than likely you need a new motor. Is the fan blade tight, stiff or hard to turn? If the fan blade is hard to turn then you probably need a new motor. Problem #2: Air conditioner compressor will not start. When power is applied to the air conditioning outdoor unit the fan starts, but you hear a sound like the compressor is trying to start, "UGGG"..., for about 5 to 10 seconds and then all you hear is the outdoor condenser fan run. The compressor is locked and will not start. What is happening is the compressor is trying to start, but because the compressor motor is locked it tries to start for a few seconds and then because of the high amperage being drawn goes off on internal overload. The internal overload protects the compressor windings from overheating and burning up. I see this many times during the start of the air conditioning season. Some compressors just have a hard time starting after sitting all winter long. Some compressors are locked up so bad that I can not start them and must tell my customer that they need a new compressor . Many times I can get the compressor started again without having to buy a new compressor or new air conditioning system by using the device that is called, "Super-Boost." I keep two or three of these on the truck. They have saved many of my customers from having to buy new air conditioning systems.
Jun 11, 2011 | Carrier 38CKC036 Air Conditioner
Hi I am Armando and I have a LG AC Mo # LSN180CE and I start to hear a bearing rattle noice right after the compressor, seems to me like it. The evaporator is like 20' o 25' away inside of the room, the...
First of all confirm where the sound comes from whether from Indoor or out door. If from indoor, the blower bearing worn out/ blower wheel broken.
If from out door, fan blade broken (replace fan blade)/compressor internal sound(replace compressor)/compressor seating bush worn out.(replace new bushes).
Helpful.
Jan 21, 2011 | LG LSC121PMA Split System Air Conditioner
Fan works but compressor does not start. Its a brand new unit
Hi!!
By fan woks you mean inside unit right? assuming so, check remote control settings and battery, set temp.to 70 degrees, a light should come on at the display and seconds later, the compressor should kick in. If Unit is brand new, it should be it. If split units, try another remote, some times those remotes show the display but do not send signal strong enough that the unit can receive it. Try getting closer to the unit.
Keep me posted! Rate this post!!
Aug 14, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Wiring Question York Diamond 90 Condensor Unit - New Capacitor
the wire diagram should tell you how. it all depends where wires lead to. be very carefull, capacitors can be dangerous. brown usaully go to fan black usaully goes to common red usaully goes to herm or compressor. it all depends where wires come from
Aug 27, 2009 | Heating & Cooling
Noisy outside from the Unit
Could be compressor noise Improper charge bad fan motor hard to say. What is the brand name of your unit. Russ
Jul 20, 2009 | Ruud Handle Air Conditioner
Blower motor wont start
Every air conditioner is equipped with at least two motors, the compressor and the fan motor. It is possible for the fan motor to be defective and the compressor to be running. If this is the case the unit will appear to be running and may even sound "normal" but no air is blowing out the front or back of the unit. If, after removing the cover of the unit you discover the fan blade is very stiff and difficult to rotate, the fan motor should be replaced. If the fan blade turns freely the circuit powering the fan motor will require electrical troubleshooting. It may be necessary to have a qualified technician locate the cause of the problem, which may be either a problem with the capacitor, the selector switch or the motor itself.
Jun 06, 2009 | Goodman CKL42AR42 Air Conditioner
NO COOLING
Hmm.this will require a few questions for you to answer. first does all the fans run, condenser fan??? indoor blower? and does the compressor humms, when you turn it on?
May 08, 2008 | Carrier 38BRC048 Air Conditioner
Fedders V Chassis A6V10S2A Air Conditioner Logo
56 people viewed this question
Top Fedders Heating & Cooling Experts
Felizardo Erilla
Felizardo Erilla
Donni Steen
Ekse
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
