Question about Broksonic DRVCR900 DVD Recorder/VCR
Setup I unplugged my system to move it and now it will not allow me to reprogram the player. I have unplugged the player before and had not problem doing the setup. This time when I select the setup botton I get nothing. If I put a VCR tap or DVD in the system is playing it but I get no picture or sound. I cannot find my manual is there anyway to get a copy of it.
Where can I get a Owner's Manual? If I could view one online, that would be great.
Posted on Oct 30, 2008
SOURCE:
I hsve a 2008 saturn sky base 2.4L. The dealer says I need a new body control module. My question does the new BCM require reprogramming? If it doesn't then I will replace myself. Thanks
Body Control Module (BCM) Replacement and Reprogramming
If the BCM is replaced or requires reprogramming, the following procedures must be performed in the specified order:
BCM Setup -- Using a scan tool, go to Vehicle Control Systems » Computer/Integrating Systems » Module Setup » Body Control Module. Select Setup BCM and follow the on-screen instructions, making sure to select the proper RPOs and input the VIN correctly.
BPP Sensor Calibration--Refer to Brake Pedal Position Sensor Calibration
Program Key Fobs--Refer to Transmitter Programming
Setup SDM Part Number in BCM -- Using a scan tool, go to Vehicle Control Systems » Computer/Integrating Systems » Module Setup » Body Control Module. Select Setup SDM Part Number in BCM and follow the on-screen instructions.
Dec 28, 2016 | Saturn Cars & Trucks
KS3102 no display. how to change back to NSTC from PAL
make sure there is no dvd in the dvd player before you start fixing the problem. Press menu on remote, then select setup. Once you have removed the dvd from the dvd player it should allow you to go to "preferences" in the setup menu. So do that. Step 4: Go to "TV TYPE" and make sure it's on NTSC. And then exit setup by pressing the setup button once again
Apr 02, 2016 | Televison & Video
I moved roku from one tv to the other I see the light on but different inputs still show no signal
Make sure the Roku is on the same input that is selected. With that setup properly, unplug the Roku power for 30 seconds and then plug it in, then it should go through it's setup sequence.
Dec 28, 2014 | Roku Televison & Video
How do i program stanley radio transmitter model 28070T
U will have to get your manual or go online to Stanley and reprogram the remotes.
Nov 30, 2014 | Vehicle Parts & Accessories
Has Sansung Pro Star DCS - phone system; Has changed offices so moved the phone system. Now For incoming phone calls, none of the extentions can recieve the calls. Has four incoming lines; no incoming...
pdf.textfiles.com/manuals/.../Samsung%20Prostar%20DCS%20Compact%20System%20Admin%..
pdf.textfiles.com/manuals/TELECOM-S-Z/
panasonicmadeeasy.com/SamsungManualsLead.htm
Above is your setup manuals.
Unfortunately it is NOT just a simple job of moving the instrument, one has to reprogram the system to "Tailor" it to everything.
You need to use the manual and reprogram the system to it's new configuration.
Mar 14, 2011 | Cell Phones
I just bought a JBL CS3/CS5 DVD Receiver several months but only started to unpack. Unfortunately while moving house, I lost the receipt and guarantee card. But when I setup the system, there is no video...
I had the same problem with mine - eventually it just stopped playing anything. Turns out that the HDMI from the Tv to the CS3 was actually 'reprogramming' my CS3. My flatmate gave it a system reset and that seemed to fix it.
I now have the problem that when I play blueray DVDs with dolby digital from my PS3 via optical digital i get the sound cutting out intermittently for a couple of seconds grrrrr.
Aug 16, 2010 | Car Audio & Video
Media problem
General system error means it's software is corrupted, just reprogram it. It cannot detect by pc because it have no identity at, just reprogram it and it will work fine, maybe it's infected with the virus while you're synchronizing with your pc.
Aug 15, 2009 | Nokia 5800 XpressMusic Smartphone
Chassis intruded!!
Clear RTC RAM (CLRTC)
This jumper allows you to clear the Real Time Clock (RTC) RAM in CMOS. You can clear the CMOS memory of date, time, and system setup parameters by erasing the CMOS RTC RAM data. The onboard button cell battery powers the RAM data in CMOS, which include system setup information such as system passwords.
1. Turn OFF the computer and unplug the power cord.
2. Move the jumper cap from pins 1-2 (default) to pins 2-3. Keep the cap on pins 2-3 for about 5-10 seconds, then move the cap back to pins 1-2.
3. Plug the power cord and turn ON the computer.
4. Hold down the <Del> key during the boot process and enter BIOS setup to reenter data.
Except when clearing the RTC RAM, never remove the cap on CLRTC jumper default position. Removing the cap will cause system boot failure!If the steps above do not help, remove the onboard battery and move the jumper again to clear the CMOS RTC RAM data. After clearing the CMDS, reinstall the battery.
You do not need to clear the RTC when the system hangs due to overclocking. For system failure due to overclocking, use the CPU Parameter Recall (C.P.R) feature. Shut down and reboot the system so the BIOS can automatically reset parameter settings to default values
Mar 18, 2009 | ASUS P5V800-MX Motherboard
My royal cms487 plus cash register keeps malfunctioning after I reprogram it. I have the manual and follow the instructions, but it won't always allow me to do a full system clear. When it does allow it I...
Unplug register, put in program mode, hold down C key and plug in register while holding. Now you can turn key register mode. This should clear it. I just read it on another site and it worked for me!
Mar 04, 2009 | Royal X3 Calculator
Interac tv
my interac tv has a solid greenlight after putting in new batteries. I am unable to reprogram the controller. help?
Dec 04, 2007 | Video Game Consoles & Games
Broksonic DRVCR900 DVD Recorder/VCR Logo
117 people viewed this question
Top Broksonic Televison & Video Experts
Marvin
Marvin
Are you a Broksonic Televison and Video Expert? Answer questions, earn points and help others
