Question about KitchenAid 24 in. KUDS02FRSS Stainless Steel Built-in Dishwasher
Kitchenaid not cycling
I have a mod.# kudso1flss2 kitchenaid and installed a new heating element which came with a new replacement electronics board. After installing the parts and reinstalling water,drain, etc. The washer would not fill, but would try to activate the washer arm. I reinstalled the old board and it worked fine, for a few days, and then it began operate the same as with the new board. Is there some type of code/sequence that it is looking for?
  • KitchenAid Master
  • 909 Answers
DONT KNOW THIS UNIT BUT TRACE BACK YOUR STEPS. CHECK THE PRESSURE SWITCH FOR AN AIR BUBBLE AS THERE SHOULD BE NO ACTION WITH THE ROTORS UNTILL YOUR WATER LEVEL IS CORRECT.CHECK IF THE SUMP LIMIT ISNT STICKING.
Posted on Aug 23, 2007
SOURCE:
Kitchenaid dishwasher #KUD524SEBLO will fill with water but not run wash cycle. suggestions?
Check this possible causes:
Water-heating cycle
heat,wash,rinse you must check the 3 types. one of them can be the problem, most of the time when water reach the level of heating work o.k , you must troubleshooting the heating elements.
Timer
often fail, in some cycle, they stuck, try to clean the contacts, tight the wires very well, or replace.
sincerely. God bless you
May 05, 2012 | KitchenAid Dishwashers
We just recieved our new kitchenaid heating element for the dishwasher, but it came with an electronic control or circuit board thing, and there is a note that both must be installed. We easily replaced...
The control goes in the door...it is easy to get to.
Just take the screws out of the inside panel of the door, they are around the outside edge of the interior of the door. The panel will then lift off and the control will be near the top on the inside.
Make sure the power is turned off to the dishwasher and then one by one remove the wires from the old board and place them on the new board. then remove the old board and fasten in the new one. replace the panel and then give it a trial run.
Everything should be working just fine but some of the timing will be a bit different.
heatman101
Apr 21, 2011 | KitchenAid Dishwashers
Dishwasher will not go into Dry cycle. It was given to me and perhaps I did not install it properly.
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Dec 13, 2010 | KitchenAid KUDI24SE Built-in Dishwasher
I need to replace the heating element and electronic control board on my Kitchenaid KUDS01DL Dishwasher. I have the parts. I have been able to find directions on how to replace the heating element, but...
Go to www.repairclinic.com and enter KUDS01DL. With luck, you will be presented with a list of common replacement parts and may be able to vie a generic KitchenAid video showing disassembly and replacement parts installation.
Aug 29, 2017 | KitchenAid 24 in. KUDS01DLSS Built-in...
They just installed a kitchenaid 36 inch KDRP467K
Hello- 'They' should have re-checked bus block connections for cord. Element won't work with one leg. If connections look good, check element connections and then power connection for element at board. If it still doesn't work, check resistance of element. Should be around 13ohms. This is the troubleshoot sequence for solution to your problem, but should be under warranty for first year. A piece of advice- avoid the 'self-clean' function. This feature is called 'self-destruct' by techs. Please acknowledge this post if helpful. Have more info if needed. Thanks-  Ed
Mar 23, 2010 | KitchenAid Kitchen Ranges
Flashes that there is a heating problem. Reset and used 3 times and then "heat" issue returned...now unit will not do anything unless I do the reset proceedure. is there a high limit or something easy to...
If you have selected "heat" with the wash cycle, then heat should be activated at the proper time during the cycle. If not, you could have an issue with a defective heat element or thermostat. If the heat element and thermostat are fine, then your problem may be within the electronic control board. Contact an appliance service company.
Feb 20, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Heating element not working
normally on a kitchenaid dishwasher the diagnostics cycle is activated by pressing heated dry - sani rinse - heated dry - sani rinse - heated dry - sani rinse - heated dry and this will energize the heating element but the only way to check is to see if you are geting voltage out of the board or by checking the resistance of the elment should usaly be around 16 ohm's
Mar 25, 2009 | KitchenAid Dishwashers
Trying to access the pump and motor section
You should check the thermal fuse problem listed elsewhere on this site. My power went out on mine, and it was a cheap {less than $20 part} that snaps into the control panel. It eventually blew again a month later, and I replaced the heater element, and the new heater element came with a new board that was very easy to install. the new programming on the board actually speeds up the cycle due to a higher wattage heating element.
But what I didn't do the first time was replace the wires going to the thermal fuse that came with the replacement kit. (Apparently the OEM wires are too thin) Had I done that, I probably never would have tripped the fuse again and not bought the new heater element.
Jan 08, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
Won't start after repair
SUGGEST YOU PULL OUT PLUG THEN OPEN DOOR UNSCREW TOP SECTION OF PANEL TO GAIN ACCESS TO DOOR LIMIT. CAREFULLY BRIDGE BOTH WIRES OUT AND ALSO WITH WATER SWITCHED OFF, SWITCH POWER BACK ON. IF NOTHING STILL, CHECK POWER TO DOOR LIMIT. IF THERE IS POWER, EITHER THERE IS A LOOSE WIRING CONNECTION ON THE BOARD OR IT HAS AGAIN GONE FAULTY.
Aug 22, 2007 | KitchenAid 24 in. KUDM01TJ - Multiple...
KitchenAid 24 in. KUDS02FRSS Stainless Steel Built-in Dishwasher Logo
282 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Smitty
Level 1 Expert
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
