Question about Jabra BT125 Headset
Jabra BT125 headset
Can't get my laptop to detect it
  • 3 more comments
  • Anonymous Nov 17, 2007
    My JABRA BT125 cannot detect by my PC with Vista. Other bluetooth devices are detected. Can you help me please.
  • Anonymous Mar 04, 2008
    I'm having the same problem.
  • Anonymous Jul 28, 2008
    this is same my Problem
  • lafinchina Nov 11, 2008
    I can't get my laptop to find my Jabra BT125.
  • barry_21k Jan 27, 2009
    i have paired the headset with my vista pc using a dongle but cant get it to work as a headset in the services in properties dialog vista cant find drivers and i cant get any joy on yhe jabra sire
I have the same exact problem but i'm on XP and i have a dongle and the dongle found it but my pc doesn't know what it is
Posted on Aug 08, 2008
This is same my problem icant drive it in PC vista
Posted on Jul 28, 2008
SOURCE:
How do i program my jabra bt125 headset to my cell phone
taken from the manual found at
http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT125%20Black/Documents/User%20manual/BT125_UM_NA_EN_471.pdf
1. Put the headset in pairing mode
• Make sure the headset is off .
• Press and hold the answer/end button until a solid blue light comes on.
2. Set your Bluetooth phone to ‘discover’ the Jabra BT125
Follow your phone’s instruction guide. This usually involves going to a ‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add’ a Bluetooth device.* (See example from a typical mobile phone in fig. 3).
3. Your phone will find the Jabra BT125
Your phone then asks if you want to pair with it. Accept by pressing ‘Yes’ or ‘OK’ on the phone and confirm with the passkey or PIN = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing, repeat steps 1 to 3.
Dec 04, 2009 | Jabra BT125 Headset
What is my pin?
default should be 0000
methinks
try it
Jul 22, 2009 | Jabra BT125 Headset
I change my handset now jabra bt125 is not
Go to this site, and it will walk you through each step to connect your particular Jabra headset with your cellphone. Choose the headset, and then at the next page, choose your phone. Moving your mouse over each step will change the picture to what you should be seeing on your phone at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
Password is 0000.
Jul 03, 2009 | Jabra BT125 Headset
Google g1 phone jabra bt125
Make sure the Jabra headset is set to pairing mode, otherwise the phone cannot find the headset. The manual should have instructions to set the headset in pairing mode. While the headset is in pairing mode, have the G1 search for the headset (Settings > Wireless Controls > Bluetooth Settings). When it finds the headset select it and type 0000 for the PIN code.
Apr 15, 2009 | Jabra BT125 Headset
Can't pair Jabra BT125 with O2mini
check the bluetooth is in visible mode or not
Jan 07, 2009 | Jabra BT125 Headset
Registering and pairing with the ps3
Go to PS3. Accessories Setting -> Manage Bluetooth Devices -> Register New Device**
** = You need to have Jabra BT125 in Pairing Mode. Hold the button for more than 10 seconds till it's a solid blue (initially turned off). Then detect it with your PS3.
If it asks for a password it's "0000"
Mar 23, 2008 | Jabra BT125 Headset
Unable to Detect the Jabra BT125 headset from any Bluetooth Device
If you hold down the button, it will turn the light blue, keep holding it till you can connect it. It will come up as Jabra BT125, hit connect. Then it will ask for a password. The password is 0000. Then it will connect :)
Feb 21, 2008 | Jabra BT125 Headset
Jabra BT125 Headset Logo
299 people viewed this question
Top Jabra Radio Communications Experts
Anthony Ward
Anthony Ward
Bobby G
Bobby G
Damen Wong
Damen Wong
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
