Question about Whirlpool Calypso GVW9959K Top Load Washer
Water splash sheild ineffective
The washer splashes water out from under the splash shield during each use. It is rusting the left side of the unit and collecting on the floor. Has whirlpool devised a solution to fixing this problem with a redesigned shield, or is there a way to stop this problem?
  • Anonymous May 17, 2009
    I have same problem - machine is about 5 years old, and recently started dripping water in left rear. It happens about 10 minutes into the cycle when water is being sprayed into the tub - I only have 1 splash shield on the right side of the tub, so am wondering if I am missing 1 or 2 more that should be in the back and left side (?)
  • Anonymous Mar 17, 2014
    Hello, I followed the instuctions that Laura gave and it worked wondefully, but beware! How much water is left in the washer will end up on your floor, so make sure you have lots of big cups with you to collect the water that shoots out. I found a pair of my daughers panties and a loonie!
My machine may be a different model, but seems to have similar problems. I resolved this by: a) making sure the splash shield is fastened correctly at all points round the tub (it worked loose) b) as a temporary fix reversed the foam gasket inside the splashshield until I get a new one
Posted on Sep 05, 2007
Where is the horn location under hood of a 2007 mercury mountneer?
Remove the LH front fender splash shield !
Fender Splash Shield Removal and Installation
  1. Loosen the running board bolts and lower the running board to access the front fender moulding pin-type retainer.
    • To install, tighten to 23 Nm (17 lb-ft).
  1. Remove the lower pin-type retainer from the front fender moulding.
  1. Remove the 2 rear pin-type retainers from the front fender moulding.
  1. Position the front fender moulding aside and remove the splash shield lower screw.
  1. Remove the front splash shield screws.
  1. Remove the front splash shield pin-type retainers.
  1. Remove the front splash shield.
  1. Remove the front fender splash shield.
  1. To install, reverse the removal procedure.
Mar 25, 2015 | 2007 Mercury Mountaineer
Splashing water during spin cycle
Failure of the water level sensor
Oct 10, 2017 | Fisher Paykel EcoSmart GWL15
Is water supposed to enter the tub during the first half of the final spin cycle (not rinse cycle)?
no spin cycle don't have water it could be the pump is not getting the water out fast enough, could be clogged or the rear drain pipe is blocked or bent. failing them to problems it could be the valve its self.
Aug 04, 2017 | GE WBSE3120B Top Load Washer
Leaking from bottom middle and right side of door
The center spray arm may not be turning straight and level, causing water to spray over the top of the splash shield. The shield needs to be adjusted to block water as it is sprayed from the center arm.
1. Remove the bottom door seal and reinstall, making sure there is not less than 3/8 inch of seal showing below bottom of internal door panel before closing the door.
2. Check tub seal, at the bottom the tub, seal makes a right angle and points to front of tub. In tub bottom there is a block molded in the tub, the tub seal is to fill this block but not extend over.
3. Select the shortest wash cycle or just use a rinse and hold cycle if available. Run the cycle, making sure the water spray changes from bottom to center not less than twice before making any adjustments.
4. If splash over is found, work only one side at a time. Remove black door seal enough to raise the splash shield up off the bottom of the tub not more than 1/8 inch and reinstall door seal properly. Retry and check for leaks.
5. If leak persists, remove door seal again. This time raise shield an additional 1/16 of an inch, then reinstall tub seal. After the first adjustment of 1/8 inch, any other adjustments will be no more than 1/16 inch at a time.
6. After splash over is stopped on one side go to the opposite side if needed.
May 11, 2010 | Frigidaire PLD2855RFC Dishwasher
My powersteering locked up twice in wet weather
If this happens as your hitting a large puddle then I would check to see if all of the splash shields are installed under the jeep. these help keep water off of the serpentine belt than turns the P/S pump. As you hit a puddle the water splashes up onto the belt causing it to slip reducing pump pressure.
Mar 15, 2010 | 2003 Jeep Grand Cherokee
How do you change the water pump on a 1998 Ford contour 2.0 liter. have the part off but can't get it out of engine compartment
Removal
  1. NOTE: Install the memory saver.
    Disconnect the battery ground cable.
  1. Drain the cooling system. Refer to Cooling System Draining, Filling and Bleeding in this Section.
  1. Remove the wheel.
  1. Remove the right - hand side lower splash shield.
    1. Remove the bolts.
    1. Remove the splash shield.
  1. Lower the vehicle.
  1. Loosen the water pump pulley bolts.
  1. Remove the accessory drive belt. For additional information, refer to Section 303-05.
  1. Using the special tool, remove the crankshaft pulley.
  1. Remove the water pump pulley.
    1. Remove the pulley.
  1. Remove the water pump bolts.
  1. NOTE: Water pump must be turned 180° to remove from the vehicle.
    Remove the water pump.
Apr 27, 2009 | Ford Contour Cars & Trucks
Left rear splash shield 2002 Altima fell off
4 clips to the fender. 3 bolts to the body frame. the splash shield cover the tire.
Apr 23, 2009 | 2002 Nissan Altima
Top load whirlpool washer model LSQ9544KQO leaking small amount
more likely from a hose........need lid off and a good torch
cheers
Aug 03, 2017 | Whirlpool Ultimate Care II LSQ9549L Top...
Water on floor under washer
re; water under washer.
The ammount of water is from 1/4 to 1 cup after an individual load. It only became noticable reciently, after the last 3 or 4 heavy loads, using the manual setting on next to the top level. There is an automatic function, but due to the dirt and grit in the jeans I use manual.
Sep 07, 2008 | Fisher and Paykel GWL11 Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
308 people viewed this question
Sal De
Marvin
Marvin
jimorris77
