Question about Sony Playstation 3 (PS3) Console
It does not turn on, remains in stand by mode.
I recently bought a PS3 from US for use in India. After making all the connections, when i turn on the main switch the red light on PS3 switches on indicatin it is in the stand by mode. And then on pressing the on/off button on PS3 the light should turn green, but it does not turn on green and continues to remain in stand by mode(that is light remains to red.) The power supply of US is 120V 60hz but in India the power supply is 230V 50hz. Therefore we are using a step down transformer of configuration 230/120V 50hz. Please recommend the possible cause and solution. Thanks n regards Monto
    Problem Solver:
  • 11 Answers
I cannot be COMPLETELY sure of this so be careful, but doesn't the PS3's board cater for both types of power supply and therefore a step down transformer is not needed? Check the labels on it just in case, but be wary I CANNOT be certain of this...
Posted on Sep 26, 2007
SOURCE:
Nintendo WII
Wires that do not come with the Wii fail. Always use the one that comes with the Wii.
Jun 27, 2013 | Nintendo Wii Console
I want to play the dvds of animation like kungfu panda & madgascar etc.but the message that my ps3 displays is that region code does not match.I bought the ps3 and dvds in Delhi India & my location...
The DVD movie you are trying to play does not match the region code of your player which is your PS3. These movie discs might not be under the same region and you have to comly to the DVD region code settings to make it work. If it says region code does not match, it means that it is unsupported and not compatible with your PS3.
May 12, 2010 | Sony Playstation 3 (PS3) Console
Playstation 3 power issue
Your system has overheated. If it doesn't get on at all anymore, you should get it fixed in the place you bought it from. That happened to me.
Feb 14, 2010 | Sony Playstation 3 (PS3) Console
Godfather 2 does not play on my ps3 - freezes at title screen
Try to RESTORE FILE SYSTEM on your ps3.
Follow this guide,
HOW TO GO TO THE RECOVERY MENU OF PS3 SYSTEM
1. Make sure the ps3 is plugged in (stand by mode).
2. Put out your usb cable for the controller and the controller itself (do not connect yet).
3. Hold down power firmly, ps3 will turn on and then turn off, release power button when it turns off.
4. Hold down power again, you will hear a beep and then a double beep, when you hear that double beep release the power button.
5. Now you should be seeing something in your monitor that say "Connect usb controller", do just that.
6. After connecting the controller press PS button.
7. You are now in the recovery menu.
8. To fix the problem of corrupt data you can choose #3.
9. If you want to format your hard drive choose #5. Be aware that this option will delete everything that is in your hard drive.
10. Remember that doing #3 and #5 is not 100% to fix the problem of corrupt data, I say about 70%.
Jan 27, 2010 | EA - Electronic Arts The Godfather: The...
When I turn on the playstation it goes almost immediately to stand by mode. When I slide my finger over the stand by button it tries to run and then returns to stand by mode.
does a yellow light appear if it does you"ll need to either return it to where you bought it if it still has warrenty or pay sony 131.00 pounds there plenty of videos on youtube if you fancy having a go to repair it yourself. just type in ylod and look for gilsky a step by step repair for the problem
Jan 22, 2010 | Sony Playstation 3 (PS3) Console
I cant get on the internet because I bought my ps3 on ebay and it still has all the previous owners settings and password.
You will need to RESTORE PS3 SYSTEM, this will format the hard disk and delete every data in it, this will include games and saved game progress, and passwords.
Follow this guide. (choose #5 in the recovery menu)
Jan 19, 2010 | Sony Playstation 3 (PS3) Console
Ps3 freezing during gameplay, started after most recent system update, wont recognize disk at times.
You need to RESTORE FILE SYSTEM of your ps3.
Follow this guide.
3. Hold down power firmly, ps3 will turn on and then turn off, release power button when t turns off.
Good Luck!
Jan 16, 2010 | Sony Playstation 3 (PS3) Console
No video output on ps3
If you have trouble on the video output settings on your PS3 try this possible solutions.
a. if recently used a HDMI cable then change the connection back to the Component cable try to check your settings first
b. while on stand by mode try to press the power button right next to the eject button for about 3 to 5 sec. until you here the double beep sound
c. if you have HDMI cable and there
is still no video but sound only try to plug out the connection from the PS3 unit and plug it again.
if this doesn't solve the problem you need to take your PS3 to sony cause the problem would be in *********** board
May 05, 2008 | Nintendo Game Boy Advance Console
PS3 does not recognise the Logitech Driving Force Pro Wheel
hapened to me with a usb drive plug it in,plug it out,plug it back in and leave it for about 10 mins and it should work...thats what i do when my usbdrive dont work
Apr 13, 2008 | Sony Playstation 3 (PS3) Console
PS3
it sounds like your power supply is faulty or you need to make sure all wires are in properly if that don't work leave it in stand buy mode for 12 hours do not touch it at all or you will have to do it all over again it needs the back up battery to gain more power let me know how you get on
Jan 04, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
364 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
