Question about Daewoo DV-6T955B DVD Player/VCR
Bad disc Recently, the DVD player stopped playing discs. It either loads slowly and immediately freezes or, more often, it simply loads for a while and then says "bad disc." I have tried many discs on the player, and all of them work well on other players, and many used to play on this player.
  • 790 Answers
Clean the laser lens first! or you have damage flex ribbon wire. change flex ribbon wire
Posted on Sep 09, 2007
SOURCE:
My blue ray player changes from Blue Ray player to Network when loading a Universal movie.
follow this steps and fix it. God bless you
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
Nov 06, 2013 | Samsung BD-D5700 WiFi blueray disk player
Dvp ns725p says: cannot play this disc
Is it for all discs or just certain types of discs? Some DVD players simply cannot play some formats unfortunately. Often, the issue is with burned DVD-R or DVD+R discs or CD Video. Sometimes it's simply a matter of a bad burn. Refer to your manual as to the formats compatible with your player.
Nov 07, 2009 | Sony DVP-NS725P DVD Player
DVD deterioration
I would blame it on the DVD player. They are fickle when it comes to playing burned discs. Try playing the disc in your computer. If does the same thing there, the disc is garbage. You can also try burning at a slower speed, sometimes this helps. I would also try to avoid using DL (dual-layer) discs.
Apr 09, 2017 | Televison & Video
Tevion player shows BAD DISC,
Since the unit is under warranty, you can't touch anything without voiding the warranty. This problem could be as simple as a dirty lens. Bring the unit in for repair under warranty.
Dan
Mar 19, 2008 | Televison & Video
DVD Freezing / skipping
It almost has to be the discs. Try them in a friends unit.
I had a similar problem with DVD's I burned and had printed labels and put the label on the discs. It caused the disc to be out of balance. I peeled them all off (what a job) and the discs play fine now. I'm now a "magic marker" person... :)
Geno
Feb 09, 2008 | Televison & Video
Dvd video player
Your DVD player is having a problem reading the disc. This is what is accounting for the pausing and the slow loading times...especially if it plays other movies without hitches. Even if the DVD is cleaned, some scratching on the disc will prevent it from being viewed properly. Blockbuster shoudl give you another disc to try of the same movie if you ask. Also, you can try getting a cleaner for your DVD player to remove dust and help it read discs better.
Dec 26, 2007 | Toshiba SD-3980 DVD Player
Denon 2910 CD player malfunctions
you could try this http://www.fixya.com/support/t244156-denon_2910_cd_player_malfunctions or clean the lens
Nov 06, 2007 | Denon DVD-2900 DVD Player
DVD PLAYER NOT READING DISC
Well I have been repairing dvd players a while now and the main problem spots are laser ,spindle motor, laser tracking motor and the biggest culprit and un suspecting one the lens cable .....most of them range from the lens cable to the spindle motor though... the constant movement of the lens in watching a whole movie causes the cable to unknowingly and slowly break and if the spindle motor is defective ,on inserting a dvd the disc spins slowly and you may hear the lens chirping ... so you can check those....
Oct 06, 2007 | Onkyo DV-S535 DVD Player
Check disc
Change your DVD player
May 23, 2007 | LG DE9523P DVD Player
Daewoo DV-6T955B DVD Player/VCR Logo
129 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
