Question about Nikon Coolpix S6200 Digital Camera Black 16gb Sd Card Kit
My Nikon Coolpix S6200 is less than a year old. It will not focus properly. The left side of the images is not focused as clearly as the right side. it doesn't matter whether the image is up close or a broader scene. I have tried changing the autofocus setting and it has not made a difference. What can I try for a fix?
  • 26 Answers
Check where the focal point is in the matrix....try changing to other positions
Posted on Dec 07, 2017
4 Suggested Answers
  • 58 Answers
SOURCE: Nikon D300 - Auto focus point won't move. Autofocus doesn't work.
The lock that's around the 4-way button that moves the AF point will stop it from moving. The AF switch (says C,S,M) on the body below the lens release button gets knocked to manual and turns off the AF
Posted on Nov 05, 2009
caroldon
  • 17130 Answers
SOURCE: The focal length on my Nikon S52 Coolpix seems to
This ccan be an error in the lens settings that have changed the alignment or a possible shift of the lens before the CCD imager.
This canot be retified wxternally asn I advice that you get help from Nikon, specially if under warranty for a replacement.
Posted on Sep 25, 2010
  • 36 Answers
SOURCE: Focus problem. Coolpix 5000 mounted on Nikon
If you are initiating the shutter manually, it is quite possible that the camera has become very slightly loose at the F-mount. So, when you press the shutter button, the movement though it may be extremely slight, is shaking the camera at the exact moment you are taking the picture.
Make sure that the camera is tight to the F mount and that the F mount is secure to the microscope.
If you are initiating exposure via software, it is still possible that there is still some slight movement on your desk.
Remember, the slightest movement is magnified many, many times to the camera.
Posted on Dec 25, 2010
Nikon Coolpix S32 watreproof camera doesn't focusing properly
You have to know if the FOCUS is the issue or SHUTTER SPEED. In most cases with most CoolPix Cameras if the Image is not in focus (When you push shutter down HALFWAY) the Focus Rectangle will not be GREEN... If it RED it cannot focus. If every time you take a photo the focus area is red then it is not focusing. Small Coolpix cameras have difficulty focusing in low light.
Low light can make a hand held image look blurry because of hand shake. If the light is so low it wants to take a long exposure. This works with a tripod, but not with a hand held photo. With most of these small cameras you can take 1 second night photos with a tripod. They would look horrible handheld.
Typically on the Coolpix cameras you can set the FOCUS mode. It is usually shown with a FLOWER for MACRO... You get AF / FLOWER / MOUNTAIN / MANUAL (may not have this)
Plase make sure your FOCUS MODE is in AF AF is the ONLY Mode where the camera will focus CLOSE and FAR... Light is not your problem..... It seems it is your FOCUS MODE.
Jan 21, 2017 | Nikon Coolpix S32 White 13.2 Megapixel...
The camera is set on Auto. The pictures are a blur, not in focus. Is there a way to set up good focus?
Revie manual here:
User Guide.pdf
This your camera:
Nikon Coolpix 775
1.check your lens camera is clean and clear.
You have to choices, auto and scene.
What happen when you choose scene mode?
2. test change your image quality to normal. you can go to menu even in shooting mode.
3.change image to normal and back to shooting mode and try again
It is same ?blur?
4.if still blur, try go to menu mode again, at left side you can find BSS.
5 IF BSS is off.. change it on. if it is on, change it off.
6.go to shooting mode again.
that all. good luck and rate me..tq
May 12, 2011 | Nikon Coolpix 775 Digital Camera
Focus problem. Coolpix 5000 mounted on Nikon microsocope for photographing tissue slides. Perfect digital images for years; now 90% poorly focused. Image viewed through microscope in perfect focus, image...
Dec 18, 2010 | Nikon Coolpix 5000 Digital Camera
After several years use without accidents or damage, cannot focus to one image any longer and left eye will not focus to clear any longer. They are Barska, 8x42 reverse porro prism.
I fear these have suffered damage without your knowledge. The collimation has gone bad, hence the two images instead of one. As the left side doesn't focus properly, I would guess that one of the prisms in that side has shifted position, which would account for both defects. This can be fixed by a skilled and knowledgable person, or made worse by someone who does not know what they are doing, but in the end, it may be too expensive to have them put right by an expert, as very good binoculars are available quite cheaply today.
Nov 16, 2010 | Barska Optics Optics
My Nikon Coolpix S570 has a purple and black striped screen and I can't take pictures but everything else on the camera comes out clear. I can read the menus and I can see any previous pictures perfectly...
Your camera has the classic and unambiguous symptoms of a failed CCD imaging sensor. It's a common fault with all digital cameras but apart from when there's manufacturing faults should not usually occur until a camera is five to six years old.
There is nothing which you've done to cause the fault, nor is there anything at all you can do to fix it.
The only fix is to have it replaced, but it's not a DIY job and the part is not cheap. However, your camera is probably less than a year old so should still be under warranty; if you purchased it in Europe from an official supplier then you have a two year Nikon warranty. To make a claim you'll need to visit the Nikon website in your country and complete a repairs form which you send with the camera along with copies of any proof of purchase required. Without proof of purchase the repair is chargeable.
After repair, check the images carefully, looking for any marks on the images which are in the same place on every shot: these may be quite subtle such as a slightly blurry small patch or two (almost like an out of focus water droplet). If you have any of these symptoms then promptly return the camera to Nikon to do the repair again as it's not uncommon for a clumsy repairer to leave debris or even adhesive/grease on the sensor. If these faults go unnoticed then most manufacturers try to wriggle out of responsibility by claiming the repair only had a ninety day warranty.
Mar 11, 2010 | Nikon COOLPIX S570 Digital Camera
Problem with my Nikon Coolpix 5700.
Hi there, its a problem of the lens sensor, So i suggest you please contact with you service center. Thanks.
Feb 19, 2010 | Nikon Coolpix 5700 Digital Camera
The focus between the two lenses is not synchronized; when I zero the eyepiece lenses and try to use the center wheel to focus, I can only get one clear image at a time.
Here's how:
Focus the left side first.
Close your left eye and now rotate the right hand eyepiece (dioptre ring) until the right hand side is clearly focused.
Open both eyes! Surprise! both sides should now be in focus simultaneously!!
Jan 29, 2010 | Nikon Action Binocular
Nikon Coolpix: lens goes in and out of focus, then LENS ERROR
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 10, 2009 | Nikon COOLPIX L18 Digital Camera
Auto focus
you push the button half way down (sounds crazy) but that is when you are letting the camera know you want it to focus and when it turns green push the button the rest of the way down
Jan 20, 2009 | Nikon COOLPIX P80 Digital Camera
AF flashing green, red AF sign on screen - won't take pictures
When you depress the picture button you should both hear the camera making motor noises and see the image focus changing as it seeks the proper focus for the image. If no focus movement takes place and you hear nothing then the focus motor is either completely jammed or malfunctioning. Alternatively focus movement may take place but it never finds the right focus point. Or you may hear a buzzing or clicking sound when it should be focusing. These symptoms can be caused by impact or, more commonly, sand or other contaminants making their way into the delicate system which moves the focus element. The camera will require professional repair in either of these cases. David Millier Advance Camera Repair
Feb 22, 2007 | Nikon Coolpix 4600 Digital Camera
Nikon Coolpix S6200 Digital Camera Black 16gb Sd Card Kit Logo
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
