Jane, Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." How to connect the TV to WIFI
Amie, There is a way, check links below.
Depends on the type of TV and the kind of headphones you have. Do they have their own transmitter that plugs into the TV? Does the TV have wireless transmission built in? Without know the make and model of both of the items it cannot be answered.
As far as I know there is only one Luxor TV model that has Internet access (Smart TV) and it comes with a wireless adapter/dongle. Plug the dongle in the USB port of the TV set and follow the instructions in the user guide on how to set up a network connection. Usually, from your remote, go to Menu, Settings and then to Set Up Network Connection. Please be aware that you need to have a wireless modem/router for your home network in order to be able to connect your TV to the internet.
There are as many possibilities as there are when trying to find a needle in the haystack. The first think to look for is the WiFi is in range. How o you do the Internet on TV, cable, Wireless or... I don't know unless you spend little more time next time you write a problem on FixYa. You first need to explain whether it is cable connection to the TV, which is a bit impossible, unless your smart TV has wireless connections. Other things that you need to check is the wireless range seen on the TV (those tiny bar-graphs usually seen at the bottom right of the screen), are they all active? They're usually 5 little vertical bars. If the Wireless is fine, you can be sure you will have the Internet, no matter what. If it is not loading you have to reset the code to match the wireless signal of your ISP. Better still, your TV is really a modern one, since it is a Smart TV and it comes with a Manual you cannot fail to understand. Read it carefully under the 'Wireless Connection' section and you cannot go wrong. Panicking over nothing doesn't get you anywhere closer to a solution to your problem. Like computers, Smart TV requires an Internet Service Provider (ISP) and a Wireless Modem to start with. Do you still feel confused? Then try this link below. It may help you... http://www.knowhow.com/article.dhtml?articleReference=1246&country=uk ...or, lastly, contact Hitachi.
Normally the wireless headphones have a transmitter that send audio via wireless to the wireless headphones. The transmitter needs to be plugged into the headphone outlet on the TV. This will switch off the speakers on the TV and sends the audio to the wireless headphones.
u can connect using special cables...u must have a TV out slot in the laptop
Wireless i am nto sure...as TVs dont have softwares that can be configured to receive signal using wireless systems, unless ur TV and laptop is connected thru some connecting medium(a converter box/ADS instant DVD maker etc)
