Question about OKI B4300 Led Printer
Paper Jam in OKI B4300 Led Printer
When a user tried to print a page the paper jammed. Then they tried to print a test page and now the paper is double-jammed inside. How do I take the OKI B4300 Led Printer apart to remove the paper jams?
  • 4 more comments
  • Anonymous Jan 03, 2008
    my oki b4300 is not having any paper jam but is still showing paper jam any solutions. and not printing
  • Anonymous Mar 13, 2014
    try to print a paper then it paper jams
  • Anonymous Mar 14, 2014
    printer jams every time you try to print
  • Anonymous Mar 16, 2014
    brand new printer that jams about every other time I try to print my click and ship lables. I have tried feeding from the front with the same problem.
  • Anonymous Mar 24, 2014
    when i go to print, the paper gets jammed and will not print
  • Anonymous Mar 28, 2014
    Fed paper into printer to print and the paper screwed up inside and jammed the printer. Remove most of the paper but small segment jammed under the rollers
  • 161 Answers
This printer is designed with a dual toner/drum chamber. Do not separate these two parts. Upon opening the lid, you will find the toner/drum assembly right in front of you. Pick it up with both hands and pull straight up. After that, you should be able to take the jammed papers. Know this: once a paper is jammed, printing another paper will NEVER take the first out. Just make sure to remove the complete papers. If they break, make sure you extract all the pieces.
Posted on Sep 22, 2007
SOURCE:
ERR 041
Must have Engine (fatal) and Jam Error logs display on the Control Panel or listed on ..... 041. paper jam. switch off the printer, remove its cartridge, look for paper jam or piece of paper jam in the rollers, clean it, place cartilage properly, switch ON the printer. it will work.
Jun 11, 2014 | OKI Electric Industry B4300 Led Printer
Iam getting the duplex paper jam error 371 each time i try to print . how do imake the error go. i dont use the duplex at all.
See page 75 of the attached user manual on how to remove a duplex paper jam. If you can't find a paper jam in the duplexer, simply remove the duplex assembly (power off the printer, then power on) and see if that resolves your issue.
(The printer will operate just fine without the duplex assy. installed)
Okidata C9650 User Manual
Sep 12, 2012 | Oki Printing Solutions C9650 Led Printer
The screen is reading upper paper jam, but when I open the printer cover, there is no paper that I can see.
Mine did the same thing, so I opened the paper tray and pulled it totally out. Then I moved the adjustable paper holder (inside of the tray, next to the paper) snug toward the paper, to hold the paper in place (lengthwise). That solved it for me! :o)
Jan 26, 2011 | OKI B4300 Led Printer
Paper jam
OK, you will need to preform a hard reset. unplug the unit for 5 min.
Mar 04, 2009 | OKI B4300 Led Printer
Paper jam
try by reinstalling the drivers, if the printer gives the same error then your printer need to be serviced
May 30, 2008 | OKI B4250 Led Printer
Paper jam issue
We had the same problem in our office.We tried cleaning it with compressed air but not much was done.Finally be changed the paper we were using with a less glossy and this seems to work.The printer has a roller with some kind of glue on it that pulls in the paper and if the paper is a bit glossy it can't stick on it.However sometimes it jams but once in a while now.
Feb 12, 2008 | OKI B4300 Led Printer
Error LED blinking after paper jam, won't print
I have a similar but different model B4300. Several others, & I have found that a small piece of paper 1/2 square may lodge under a plastic guide, holding open a switch. This is very difficult to notice if you don't know where to look.
Open top lid
Remove the ink cartridge/roller drum as a single unit.
Look in the printer at the metal roller in front.
A Plastic strip on top & in front of the roller covers 2 square holes which should look dark. On your LEFT, as you face the unit, there is a small magnetic switch, to the LEFT of the LEFT square hole, under the plastic.
In my case, the paper was seen as white in the hole, and extended under the switch. I was able to grasp it with a small medical forceps, next to the switch. By gently twisting, I pulled it out without taking the unit apart.
The printer then worked perfectly after the paper under the switch was removed.
Dec 13, 2007 | OKI B4100 Laser Printer
Oki b4300 Led printer misfeed.
No worn picker cause it is getting past paper rego area and stopping at the fuser.Check to see if bottom fuser roller (orange rubber one under metal one) is wrincled or the plastic coating is coming off to the side
If not then one of the paper path switchs is sticking sometimes down and not springing back (common)  when paper has exited area.there is 3 or 4
Oct 18, 2007 | OKI B4300 Led Printer
Pages do not print clean on one edge
open it and clean the drum with a non scratching no-dust tissue with alcohol or similar
Aug 15, 2007 | OKI B4300 Led Printer
OKI B4300 Led Printer Logo
761 people viewed this question
Top OKI Office Equipment & Supplies Experts
Steve Allison
Steve Allison
WTF Chuck.....
WTF Chuck.....
Clive
Clive
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
