Question about Canon imageRUNNER 400S Copier
CANON CLC900 COPIER
I WANT TO INSTALL THIS COPIER IN MY INTERNET CAFE BUT I DONT KNOW HOW TO FIND IS IP ADDRESS
Whats an e 010? need to fix it before we sell it :)
Posted on Jan 16, 2008
    Problem Solver:
  • 18 Answers
Go to the menu on the printer and ell it to print out a configuration page. on there it will tell you what the ip address is. they might call it something diffrent on this machine like machine reports
Posted on Aug 23, 2007
SOURCE:
How to unlock the cafe manila client software when IP address is encoded wrong, it appears LOCK without password. I tried to use CTRL+ALT+DEL but still no use. Do i have to reformat?pls help
how to unlock the cafe manila client software when IP address is encoded wrong, it appears LOCK without password. I tried to use CTRL+ALT+DEL but still no use. Do i have to reformat?pls help
**** just press esc and choose admin.. the default paswword is pass hope this helps..
Feb 22, 2011 | Cafe Manila Cyber Cafe Management Standard
IR 22 30:HOW TO PUT IP ADRESS? i whant to
the easiest way is to print out a function list on the copier it should give the ip address on the list then open internet browser and input the ip address in the browser nd change the ip address there dont forget to make the ip address static hope you come right
Feb 19, 2011 | Canon IMAGERUNNER 2230 Copier
I HAVE ONE IRC 3200 AND I DONT KNOW WHAT DRIVER INSTALL FOR SCAN AND PRINT, I HAVE WIN XP
Go to http://www.usa.canon.com
Select Downloads
Select Office/Production
On next page from the dropdown select Office/Production products again
Next page Select Networked Office Systems/Copiers
Next Page select Color ImageRunner Series
Next Page Select Color ImageRunner Series
From List select Color Image Runner Irc-3200
From the choices select the driver needed. PCL or PS (postscript)
Select either Setup or INF.
If Setup or INF file. Download the zipped file. Create a folder on desktop or downloads. Call it Canon Copier or whatever. Download the zipped file to this folder. Go to the folder you downloaded the zipped file to and double click on the file. When Win-Zip started and asks where you want the file un-zipped to enter a period (.) this will unzip the file to the folder you created.
Once the file is un-zipped if you downloaded the setup file run setup exe.
At somepoint in the setup process you will be asked which port you want to use. You will need the IP Address of the copier ( which can be obtained by pressing the additional Functions key on the copier, selecting report settings, selecting Network and print report. If the IP address needs to changed select additional functions again, Select System settings Key, Network settings key, TCP/IP settings, Check or Set IP Address here or select DHCP to get new address. Repower the copier if any changes are made.
At the which port to use select New Port, select Standard TCP/IP port and create new port. Enter IP address in the new port window.
If using INF file after INF is unzipped. Go to Printers folder and select create New Printer. Follow Printer Wizard. Create New Standard TCP/IP port. When the Wizard Asks for Driver, select have Disk and browse to the folder you created and click the unzipped file and continue clicking until the file installs.
Mar 20, 2010 | Canon imageRUNNER C3200 Copier
I want to instaal the driver for my canon ir 105 on my omputer and i go th the sitting of the copier and i put a new ip and i install mey be all driver for that but it i didnot find any thig and i cant...
Pull it from the printer itself. If you know it's IP address type //and the IP address in the address bar of your web browser and you should be able to download the driver from the printer.
Dec 31, 2009 | Canon imageRUNNER 105 Copier
I want to print copies from my workstation how to i connect this to canon ir3300
For that it should have a network adaptor, if that is availabe just feed an ip-address in machines, and connect with your workstation and installed the driver of printer.
Jul 09, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
How to find IP address
Print the config page, is the easiest way -Carl
Jun 23, 2009 | Canon imageRUNNER 1023iF Black and White...
Scanner installation
I WANT T INSTALL SCANNER SOFTWARE IN MY SYSTEM
Dec 09, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Internet Exporer
"Obtain ip address automatically" indicates that it will use DHCP. DHCP will also provide the Internet Gateway address, which is required to access anything outside your local subnet (like the internet). You can set your IP address manually, but you also have to enter the Internet Gateway and DNS server addresses ( and you have to know what those addresses should be for your pc ).
Feb 17, 2008 | Computers & Internet
Canon imageRUNNER 400S Copier Logo
109 people viewed this question
Clive
Clive
old marine
old marine
Ekse
