Are you sure that your Nokia 5300 Xpress Music is completely unlocked from network restriction? If you have unlocked it, you can definitely use any other GSM SIM card with it. If you are not able to access any SIM card with it, it seems to be you have made some mistake in unlocking. The safest and easiest way to unlock a Nokia 5300 Xpress Music is using unlock code. You can get the accurate unlock code for a Nokia 5300 Xpress Music from
OnlineGSMUnlock.com at affordable cost. Good luck.
..............UNLOCKING INSTRUCTIONS..............
1 - Switch on your Nokia 5300 XPRESSMUSIC
without any sim card.
2 - Don't bother as to what is displayed on your Nokia 5300 XPRESSMUSIC.
3 - Compose
#pw+CODE+1#.
4 - The Nokia 5300 XPRESSMUSIC would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 5300 XPRESSMUSIC mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose
#pw+CODE+7#.
The letter
p appears if you press the button star(*) three times quickly
The letter
w appears if you press the button star(*) four times quickly
The symbol
+ appears if you press the button star(*) two times quickly
The
CODE you need to enter is the unique unlock code for your Nokia 5300 XPRESSMUSIC
how do you format the memory card?
