Question about Whirlpool (RH3736XLS) Kitchen Hood
Kitchen hood We bought a whirlpool range hood and we are in the instalation process. I was wondering if you can cut the vent hole on the back of the hood at a different location then specified? The location of the hole for the outside is 11" from one side of the kitchen cabinet and 9" from the other side of the cabinet. The actual hole is 10", but can I cut the hole on the hood to fit the external vent hole accordingly? Thanks
  • 24 Answers
Yes you can , usually they got hole on top too , just make sure when its done that the air is going out and it will be fine . I
Posted on Feb 25, 2009
What product can I use to replace a down draft venting system from a Jenair range when I have to install a range hood above a new range and wish to vent down and out of my house in the same place of the...
Short answer is if you have the vents already in there is a product to make use of these. I would recommend talking to an appliance dealer for your options on this one. I am sure they would steer you in the right direction.
Mar 01, 2015 | Range Kleen For Whirlpool Jenair Ranges
I have a GE XL44 that I inherited in my new house. For some reason that I cannot figure out, the previous homeowner cut a circular hole in the floor below the stove and ran a vent line (looks like a six...
It is possible that a down draft venting stove such as a Jenn-Air could have been previously installed and now there is this stove that doesn't need this vent system.
Dec 02, 2012 | GE Kitchen Ranges
How do you replace?
Kitchen hood replacement can be completed easily with a family member or a friend. While you may wonder why anyone would replace a kitchen hood, the answer usually is simple. Here is how to replace a kitchen hood.
Tools Needed
  • New Range/Kitchen Hood
  • Screws
  • Screwdriver
  • Friend
  • Wiring Nuts
  • Circuit Tester
Warning: Remember that you are dealing with electricity, so stay away from water and use all safety precautions issued by the manufacturer.
Step 1 - Shut off Electricity
Remember to turn off the electrical supply to the old kitchen hood. You will need to do this via the circuit breaker box. Wait for 10 to 20 minutes and then test the wires with the circuit tester to double check that no electricity is being supplied to the kitchen hood.
Step 2 - Remove Old Hood
After you know for a fact that it is not receiving an electrical current, you can begin the process of removing the older kitchen hood. You should first take off the electrical wiring cover that is located by the light fixture. Then have your family member or friend hold up the old kitchen hood while you remove any screws or bolts from it. Once that is done, you can then freely slide it off.
Step 3 - Check Wiring
Double check that you have at least 12 inches of wiring to connect your kitchen hood to the wall. It should be noted that if you have a kitchen hood without vents, proceed to step 5 next.
Step 4 - Find the Ducts
If your new kitchen hood has vents, you will need to locate the fan or vent duct. Once you have found it, you can open up the vent hole where it will belong.
Step 5 - Wires
Open up the covering for the wiring and put the covering in a safe area for easy reach.
Step 6 - Install the New Kitchen Hood
Have your friend or family member hold up the kitchen hood and mark the areas where the screws or bolts will be. Then have them put down the kitchen hood and screw in the screws half way into the holes. After that, you can slide in the kitchen hood.
Step 7 - Route Wiring
Lightly pull the wiring through the proper holes and connect both black wires from the new kitchen hood to the black wire from the wall with a wire nut. Then connect the two white wires from the hood with the white wire from the wall, again using a wire nut. Next, connect the green wire to the green ground screw. Then place the wire covering back on.
Step 8 - Tighten Screws
Finish tightening the screws in place.
Step 9 - Test
Check to make sure the fan and light work. If it is supposed to vent outside, make sure that the air is leaving the vent with no issues. If something does not work proper, repeat steps 6 and 7 until everything works well. Remember that you will be working with electrical equipment, so follow safety measures issued by the state or the city.
Jan 29, 2011 | Kobe RA9436SQB Kitchen Hood
My existing duct is a 4x10, the KOBE CH2230SQ does provide the 4x10 ducting option, but 1. it does not have any spout to catch the duct opening; 2. the vent plate has a thickness, but my cabinet is...
You should be able to purchase the 4x10 hood boot from Lowe's or Home Depot. As for the cabinet mount, maybe you can cut a bigger hole. I have modified fittings to fit small spaces but most heat and air installers can make you fittings for small confined spaces. I have found them to be quite reasonable too! Hope this helps.
Aug 12, 2010 | Kobe CH2230SQ Kitchen Hood
Fsr3600 range hood has vent hole on top located to the right off ctr and wiring on the the left side. I want to center the vent hole on top by moving the plate and cut a hole on the body to move wires to...
roberto cant you just install a small junction box go to home depot back at appliances and ask for a dishwasher pigtail the are usually about 6ft long and feed it back to yourpower my e mail
Apr 12, 2010 | Kitchen Ranges
Range hood installation
you can reseal the hole with aluminium tape
you can use screws with metal flat washer that has a rubber backing
May 28, 2009 | Broan-NuTone Allure III QS330SS Kitchen...
Installing a vent hood...
There is no kit to make this conversion. That being said, you could get an estimate from a sheet metal fabrication shop on creating the conversion you are seeking.
Good luck with it.
Feb 13, 2009 | Frigidaire PLHV36W7CC Kitchen Hood
No suction
There is a set of blocks that are installed on the venting system to make the unit recirculate....use the manual to find them and make sure your not venting half outside and half into the kitchen.
Feb 02, 2008 | Zephyr Pyramid ZPY-E30S Kitchen Hood
Stoves newhome
the residue is the grease being exhuasted from the oven.i wouldnt think you could vent it out unless you have an overhead hood.if its really bothersome look at a home depot/lowes for a heat/fire resistant filter and install it on the oven somehow.
Jan 05, 2008 | Stoves 800DFDOm Dual Fuel (Electric and...
Whirlpool (RH3736XLS) Kitchen Hood Logo
247 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
