Question about Malber P21 Front Load Washer
Malber P21 won't empty...
I have checked the the hose leading to the pump and nothing is obstructing it. Althought I found a rubber band stuck in the pump it still does not empty the water. When I do put the hose down, the water does gush out so there is no further obstruction. I noticed that there are 3 hoses leading to the filter, the one leading to the pump, one leading to the tank of the washer and a thin one leading from the top of the tank to the filter. Could these have any obstructions. Also, when I tried to test to see if it could empty out the water the pump was very very hot. Thank you for your help.
  • 1 more comment
  • Lillycub Aug 23, 2007
    Thank you so much. The pump has died...Do you know of a place that will replace that type of pump or where I can get it from?
  • Lillycub Aug 26, 2007
    Last night I decided to play with the pump again and found more rubberband pieces in the part that resembles a fan. It is rotating more freely but not all the way. I believe there is another piece of stuck in it but will try to move it until whatever is lodged in there comes out. Thank [email protected]
  • littlesuper Feb 08, 2008
    washer will not empty. i pulled out the pump to look for obstructions, and found nothing. the thing that looks like a fan i pulled out and the end of it looks broken and was not moving freely. i had it moving, and put back together and it did emty on first wash cycle, and now will not emty on last cycle. i beleive i need a new pump. where can i purchase one?
    johnny
    New Friend:
Where is the drain pump located at? Is it easy to remove? I think the pump on my P21 is going too since it has been very very noisy. Thanks.
Posted on Jun 18, 2014
    Novelist:
    Champion:
  • 244 Answers
Noif water is gussing out when u puy the drain hose low to the ground then your pump has gone a way to check this without any water in the tank take of your outlet hose u will see a little fan inside the pump put it on empty get a screw driver and carefully place on the fan if the fan stops then it definetley neds replacing sorry love all u can do
Posted on Aug 23, 2007
  • peter gittos
    peter gittos Aug 24, 2007
    sorry lillycub spent 30mins trying to find 1 but cant tried alot of web sites only way is to sort it is take it to a washing machine repair shop for them to try and match or send it to me and ill try to sort it for u love
  • peter gittos
    peter gittos Aug 28, 2007
    my pleasure lillycub like i say if u cant sort it try a washer repiar shop if they can match it up if not get intouch ill send u my details send it to me a ill repair or replace it for u and ill let u know b4 going ahead with the purchase of a new pump how much it will cost if i can fix it it wont cost u a penny just the postage back but more than likely for me to replace it will be at the most about £25 wait to c if i hear from u peter
SOURCE:
Where in florida can I get a malber p21 washer and get the dementions of it. I have one in NY and love it
A Malber P21 has the following dimensions:
Height:33 1/2"
Width:23 1/2"
Depth:20 7/8"
(From the AJ Madison Web Site)
The model is discontinued, though.
http://www.ajmadison.com/cgi-bin/ajmadison/P21.html
The current model is the P31.
It's an Italian model sold primarily in the New York area.
You may want to call Malber at 516.323.5299. or email [email protected]
Oct 17, 2014 | Malber P21 Front Load Washer
My malber washing machine p21 will not turn on it is making a clicking sound but nothing else
It might be due to the switch problem or wire will be cutted for that which runs the engine... Check the wiring and switch on the machine..
Thanks
Apr 01, 2012 | Malber P21 Front Load Washer
Machine won't go in to spin and cloth stay wet
Hi alvism,
The drain pump may have something clogging it up, or obstructing the pump impeller, easy fix, see my Tip below:
ACCESSING, DRAINING & CLEANING THE DRAIN PUMP FILTER...
Kind Regards d')
* If you found this solution helpful, please rate it.
Jul 21, 2011 | Malber P21 Front Load Washer
Hi..we washed a rubber backed rug and the rubber came off and the water will not fully drain. we washed several empty cycles since with no results
You will have to take the hoses off between the tub and pump, and the pump and weall drain. They are packed with rubber. Oh, don't forget to clean the inside of the pump too. Run clean water through all hoses and the pump before reinstalling and you should be fine. Don't wash rubber backed rugs in washers unless you go to the laundry mat. This should be put in the maintenance guide of your washer book, but I've yet to see it.
Feb 03, 2010 | Malber P21 Front Load Washer
I NEED A NEW HOSE " Y - INTO ONE. WHERE CAN A GET ONE? I HAVE A MALBER P21.
I'm a general contractor. I made up a new hose by using various couplings
and a speedy connector.
Jun 25, 2009 | Malber P21 Front Load Washer
Ultima wf840 flashing f-05 dont know where filter is
I give you here the filter & pump details:
First empty the machine by lowering the hose at the rear to ground level into a container. Take off the white plastic cover on rear at bottom. You will see black rubber hose connected to barrel of machine in right hand corner. Undo the silver screw on the band securing the hose. (Biggest band). You can now pull the hose down to reveal a ball. Lift it out carefully and you will probably find an obstructions like a coins or clips. Do not take off the white hose clips.
After the filter comes the pump, disconnect. Slide pump to left and lift, it comes clear. Take off 2 black hoses only where connected to main machine. Pull off electrical connection. Pump and hoses lift out easily. 3 screws open the pump. Clean out any obstruction and reassemble. Refit all as you dismantled.
Mar 08, 2009 | Hotpoint Ultima WF860 Front Load Washer
Malber P21 works 3 times slower than normal; I am afraid it will just stop.
I have a Malber P21 the door was open and not turned on and it filled with water till it overflowed onto floor....any ideas?
Dec 02, 2008 | Malber P21 Front Load Washer
Error code f 05
this worked for me and I made 25p for the trouble:
First empty the machine by lowering the hose at the rear to ground level into a container. Take off the white plastic cover on rear at bottom. You will see black rubber hose connected to barrel of machine in right hand corner. Undo the silver screw on the band securing the hose. (Biggest band). You can now pull the hose down to reveal a "table tennis like" ball. Lift it out carefully and you will probably find an obstruction like a coin or similar. I found a hairgrip but it was enough to stop the ball functioning. DO NOT TAKE OFF THE WHITE HOSE CLIPS
Comment by pulmicort, posted on Feb 02, 2008 Further to my comments re clearing scrap from table tennis ball after code F4. Machine started ok but then F5 came up. Had to take the pump off and apart to reveal broken hairclip actually seized in pump. If you are handy at all this is simplicity itself.
Slide pump to left and lift and it comes clear. Take off 2 black hoses only where connected to main machine. Pull off electrical connection. Pump and hoses lift out easily. 3 screws open the pump. Clean any obstruction and reassemble. A 30 minute operation.
Mar 16, 2008 | Hotpoint Ultima WF860 Front Load Washer
My washer won't empty
Does the pump spins ? Try to rotate pump's pulley manually. If it doesn't turn freely (frozen or stiff), check for foreign object inside the pump. In case you will not find an object that prevent pump's spining, it should be replaced. Good luck!
Aug 22, 2007 | Malber P21 Front Load Washer
My washing machine won't fill with water
I have my washer connected to the kitchen sink. In order for it to fill I have to connect the hose to the faucet and turn it on, it is pain but that is the only way it will work for me. I hope this helps.
Sep 15, 2006 | Malber P21 Front Load Washer
Malber P21 Front Load Washer Logo
165 people viewed this question
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
Android Man
Android Man
Jason Harris
Jason Harris
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
