SOURCE: music does not play on my CECT i9
Try Refresh List or check in your Music Settings if the Memory Card is selected or not.
SOURCE: Problem playing music on Sciphone i68+
When you put the music on, did you drag an entire folder or just a single song. If you drag an entire folder then it will just go to the documents. I you want to listen to the song in the audio player, than you need to individually drag the song onto the E drive
SOURCE: not able to play music from sd card on env2
HI,
what you need to do is put it in ur PC and if the option of open file location comes up use it, when u see what the file location is open another of the same file containing My_music, My_pics, Music, the file should be easy to open without the option by simply going to START then search and choose Removable disk E: , after having 2 open what u need to do is make sure ur music is in My_music now once done with that if there in Folers you need to take them out and have just the MP3 file in the My_music section when u have them all out of there folders simply delete the folders...keeping the MP3s of course.. now once you have nothing but every songs MP3 file in the My_music file u are set put it in your phone then it should say downloading or checking or doing somthing with the music for a minute till you can play them...and then you DONE....=) any questions my myspace is http://www.myspace.com/johnjg7000 have fun and enjoy took me 3 days to find a way for the phone to read this stuff haha...hope it works
SOURCE: cannot access to my memory card files???
try to format the memory card or scan it with the kaspersky 2010
Testimonial: "fixed"
SOURCE: nokia 2700 classic with 1GB memory, ''operation failed''
Dear Big Brother.
Problem One.Nokia 2700c Model Mobile Memoryte Asle Sudo Opening Gallery Bar Bar Scan Kora.Or Operation Filed Ase.
