Question about Black & Decker SpaceMaker ODC325 Coffee Maker
Unit will not perk water
Everything else on the unit works but it will not heat the water to perk it to the top so it can drip down through the coffe grounds.
  • 5 more comments
  • baldbob Aug 24, 2007
    How do you check for a burned out heating core?
  • matthew46 Nov 04, 2007
  • Anonymous Nov 21, 2007
    unit will not perk water also!
  • tawdy Nov 24, 2007
    Same problem: water won't heat to move through system up into the basket. Is it possible to find parts for this model?
  • ndrum1 Feb 29, 2008
    Started out great, then about 2mos after use (and gentle cleaning) it would only brew 1 oz and then stop. It started to have a slow drip so I ran a 50/50 mix of water and white vinegar through and it started working again. One month later the unit would steam and the base under the pot would heat, but it would not pull water through to brew. Now it doesn't even do that; the display lights up but that's it. This seems to be a common problem with this model. I am wondering if it has anything to do with hard water.
  • dchill Mar 25, 2008
    I have the odc325b and it quit heating the water to brew the coffee
  • Anonymous Apr 13, 2008
    Mine quit after being used for only a couple of months. I bought it some time ago but it was used only rarely at a second home. When we sold that home, we got rid of our older one (unfortunately) and started using this nice new one. Now it doesn't work! I really like this model as it's very user friendly. I like the separate water reservoir as I can take it to the sink to fill. I would buy a new one if I could find it.
  • 30 Answers
I've had one of these for several years and have replaced the water heating element several times. Abtec sells the entire heater element plus new rubber hoses as well as just the thermostat and fuse, which is what actually fails.
If you're handy with tools and small appliances and take your time you're in and out in 10 minutes. There is a small allen screw at the back of the unit and the same size allen at the top of the heating element. Make certain you don't lose the small plastic ball that acts as a check valve at the end of one of the hoses.
At $35 plus shipping for the element it's almost not worth the time and trouble since new units run about $50, but this is a nicely designed unit, not available any longer, other than the durability of the heating element.
Posted on Mar 28, 2008
  • 625 Answers
Check for a broken connector to the heater coil, check for a burned out heater coil, check that the dip tube goes into the spray nozzle
Posted on Aug 23, 2007
  • THOMAS MIERZWA
    THOMAS MIERZWA Aug 25, 2007
    an instrument called a volt ohm milliameter, which you can get at any radio shack, will check the heater coil. the v-o-m can check voltage, amperage and resistance. set the resistance range to RX1 and with power off put one probe on one side of the element and the other on the other side of the element. disconnect any wires going to the element. if you read resistance then coil is ok. if you read zero, the coil is shot.
My coffe maker leaks water all over the counter and has for a very long time, why? It's only about 3 yrs. old or less, I think and I am tired of it, I have to clean it up everyday and then add more water...
If you haven't used a replacement carafe, then it is probably a clog in the drip orifice, at the bottom of the basket. Note: don't put hot water in your coffee maker as it will perk faster and cause an overflow. Only use cold water. If you have replaced the carafe then it is probably the wrong size.
Feb 08, 2011 | Bunn B10 Coffee Maker
My new percolator will not perk? Water gets hot but doesnt seem to rise to the top.
I had the same problem, and I figured it out. Read on, to see if this applies to you. This percolator was received as a present years ago, and I'm not sure it ever worked right. First, some info and background. The above comments about the heating element being clean to bare metal, while valid, did not work for me. I also read other posts suggesting the thermostat might be defective, which also did not seem to apply to my situation because the water is always hot enough at the end of the cycle, not boiling, but steaming hot enough for just about anyone. I deduced the problem to be with the actual perking process, not heat or heating element. A percolator should perk before the water is at drinking (HOT) temperature, and the perking action cools the water and prolongs the actual perking process. The problem I found was with the washer at the bottom of the tube, which is supposed to act like a 1-way valve. The washer, from the factory, was apparently too loose with almost a 1/4-inch or play, allowing hot water that would otherwise perk back into the water chamber, effectively making my percolator into a kettle. I used a stainless steel washer and an e-clip to tighten the washer against the holes on the lower umbrella-shaped flange so that there is just enough room to slide a feeler gauge or perhaps a couple of sheets of paper. Now the percolator works great, fantastic actually. Watching the coffee perk at the top in anticipation of a hot cup is entertaining, and with the stainless steel pot I have no worries about phytoestrogens leaching from plastics common in drip coffeemakers. See photo of my hack if it uploaded correctly. Its high res, so you may be able to download and zoom in. Enjoy! new-percolator-will-not-n1see0xg4iab1sfdaqlesvfh-4-1.jpg
Oct 18, 2010 | VillaWare Mini-Perk 5120-05 Coffee Maker
I have a 55 cup Farberware Urn. Pot will perc coffee sometimes & sometimes not. Problem exists since new, & have replaced both thermos. Water gets very hot, but not as Coffee. Sounds like...
Hi. The spring slips onto the stem just under the coffee basket, it holds the stem with pressure so the perked coffee go up the stem onto the spreader, check repairshack.com Ron
Aug 15, 2010 | Faberware 12-55 Cup Coffee Urn
A Krups KM7005 coffee maker/grinder doesn't heat or drip water .
Mine had the same problem ... all the lights are on, grinding works fine, but no heat on the plate, and no dripping of water.
After a weekend on the workbench, I mastered this machine. The KM7005 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. To date, I have helped 13 people on this site fix this exact problem.
I'll be happy to advise you to fix this, or fix it for you. Write me at KM7005@flightsystems.biz.
Dec 16, 2009 | Krups Small Appliances Espresso Machine
My 25cup Farberware urn quit perking coffee can it be reasonbly repaired?
I have the same urn and had the same problem.
There are 3 common causes of lost perk that can be dealt with at home, and cause about 1/2 of the failures with these urns. They are very common when the pots are used rarely or carelessly cleaned after use, and when coffee is ground too fine for perc (drip grind is too fine for perc). As long as the pot is still heating, check these three things:
1) Clean the _inside_ of the hollow stem )that holds the basket and moves the water from the bottom of the pot to the top), to remove all grounds. You should be able to see clearly through it.
2) At the bottom of this stem there is a very small cup that has little holes in it and fits into the little well at the bottom of the pot. Make sure these are completely clear.
3) Scour out the little well so all residue/ grounds are removed and the little cup fits perfectly into the well.
It is the perfect fit of the two that allows the perc-ing cycle to occur.
If the pot is not heating, or these cleaning measures do not work, a local electric repair shop can probably do the repair for about 1/2 the cost of a new urn.
Dec 04, 2009 | Faberware 12-55 Cup Coffee Urn
Won't perk or heat water
After checking power cord and plug end to make sure these are in good condition. The unit still does not work.
It is most likely the heating element has gone out.
Suggest replacing the unit.
Oct 04, 2009 | Jura Capresso 452.01 Coffee Maker
Coffee is leaking onto burner and spilling onto counter, yet the carafe is not leaking. The problem seems to be coming from the drip
Does the coffee seem to be overflowing the coffe maker and the running down? If so the valve where the filter is placed is not working properly. When you place the coffee pot it actuates a small arm which inurn opens a valve at the base of the filter unit. If this is the case remove the unit and correct this unit. In speaking from past experience I know this happen to our coffe maker while the unit was apart being cleaned; it was just a matter of proper reassemble.
I hope this may have helped,
Tom
Sep 07, 2009 | DeLonghi Coffee Makers & Espresso Machines
WATER DRIPS DOWN FROM INSIDE TOP REFRIGERATOR BELOW FREEZER
Not an original solution - but a good one. Remove panels at the back of the freezer compartment to expose the heater unit or heater wire that defrosts the freezer coils and wrap a solid copper wire gently around the heater/ heater wire and place the loose end in the drain. This will conduct heat to the freezer drain and help keep it open. I did see a manufactured part in one of the appliance parts websites but it did not match my unit.
May 29, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
I dont know how to make coffee
Water Level ////Amount of Ground Coffee
42 Cups --2 ½ Cups
36 Cups-- 2 Cups
30 Cups- -1 ¾ Cups
28 Cups --1 2/3 Cups
24 Cups --1 ½ Cups
22 Cups --1 ½ Cups
18 Cups-- 1 ¼ Cups
12 Cups --1 Cup
1. With basket and stem removed, fill coffeemaker with COLD water to desired level using the cup markings on inside of coffeemaker as a guide. Do not make less than 12 or more than maximum capacity of the coffeemaker at one time.
2. Place stem into heating unit in bottom of coffeemaker, then put basket on stem. Spread the recommended amount of ground coffee evenly into the basket. See chart. Use regular electric perk grind coffee or coffee ground for all coffeemakers. Do not use drip or finely ground coffee as flooding of the basket can occur.
3. Turn cover in place on coffeemaker. To reduce coffee spills, especially if coffeemaker is tipped over, make sure cover has been turned clockwise until it is completely secured in the handle slots. (Note the arrows on the cover for correct turning.) The cover temporarily reduces coffee spilage if coffeemaker is tipped over, so care should be used when moving coffeemaker.
4. Place coffeemaker on a dry, level surface. Attach cord to coffeemaker and plug into a 120 volt AC electrical outlet ONLY.
5. Coffeemaker stops perking automatically. (Each cup of coffee requires about 1 minute brewing time) Serving light will glow when coffee is ready. Before serving, use a hot pad to remove cover, then carefully remove stem and basket from coffeemaker as coffee and grounds are HOT. If not removed, bitter oils from the coffee grounds will drip into coffee. Replace the cover making sure it is completely secured into the handle slots.
6. Coffee will remain at serving temperature as long as coffeemaker is connected to outlet. (if you have an insulated coffeemaker, the sealed-air insulation will keep coffee hot for up to two hours without electricity.) To serve, place cup and saucer under faucet and press down on handle. If a continuous flow is desired to fill a carafe, lift handle straight up until it locks into open position. When approximately one cup of coffee remains in coffeemaker, disconnect from outlet.
TO MAKE MORE COFFEE: If another pot of coffee is desired right away, partially fill coffeemaker with cold water to reset the thermostat. Pour out water, refill with cold water and repeat steps 1-6.
TO HEAT WATER FOR INSTANT BEVERAGES: Plain water may be heated in your coffeemaker for use with instant beverages. Simply fill the clean coffeemaker with cold water to the desired cup level, and then place the stem and empty coffee basket in place. Using the stem and empty basket will heat the water more uniformly. Secure cover in place and plug coffeemaker in. Heat water until perking stops and serving light comes on. Unplug coffeemaker when less than 1 cup remains. Other than making coffee or heating water, no other liquid should be heated in coffeemaker as damage to heating unit can occur.
When coffeemaker is used to heat water only, the metal inside will discolor which is normal and does not affect performance or the water heated in the coffeemaker. Refer to Special Cleaning Instructions in this manual for removing discoloration as well as mineral deposits, which form inside the coffeemaker when heating water. If these deposits are not removed, pitting of the metal inside may occur and result in damage to coffeemaker. Refer to the cleaning your coffeemaker section
Apr 14, 2009 | West Bend 58030 Coffee Maker
Gevalia CM-500 12 cup problem.
Underneath the hot pad that the carafe sits on, there are two thermal fuses that are inside tubes that are clamped to the heating element with spring clamps.
Remove the bottom of the unit (5 screws), unclamp the thermal fuse tubes, slide the tubes to one side and check the each fuse with an ohmmeter. If one of them is open, that's your problem.
Aug 30, 2008 | Gevalia CM-500 12 Cup Coffee Maker
Black & Decker SpaceMaker ODC325 Coffee Maker Logo
179 people viewed this question
Top Black & Decker Coffee Makers & Espresso Machines Experts
eyecam
jason
Are you a Black & Decker Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
