Question about Cuisinart Thermal DGB-600 Grinder
DGB-300 MY GRINDER FILTER BASKET IS STUCK AND I CANT GET IT OUT TO CLEAN IT. HOW CAN I GET IT OUT.
1-800-726-0190 Cuisinart toll free help line.
Wait till the coffee pot cools down. The plastic parts get hot and that is was causes it to stick. You can put the machine in the fridge about 20 minutes, to help it cool down faster.
Also, once the grinder is off.. spray vegetable oil Pam on the shaft that you put the grinder on. That helps to stop it from sticking.
I tried this and it works.
Posted on Aug 12, 2008
I tied a cord around the propeller and dropped the whole unit and held the cord to pop it out. I did it gently enough that i was able to support the fall of the unit when it seperated. be careful though..that propeller is sharp.Similar to pulling teeth with a string and a door knob. =)
Posted on Jan 17, 2008
  • Elaine Bindler
    Elaine Bindler Nov 19, 2013
    Safe and easy. - remove grinder basket by gently giggling and pushing spout from underneath
Cuisinart CS says to pour hot water around the outside of the grinder, that didn't help me at all. I finally used 1 foot of cord (heavy string) and made a loop, putting one end around the base of the grinder blade and then hooked the claw of a hammer in the other. Then yank up on the hammer.
Posted on Dec 29, 2007
It is the seal in the grinder cup that goes bad and causes the whole thing to get stuck. Not a big deal. Get a new little cup and it will be as good as new.
Posted on Sep 08, 2007
Get a new one. I had to pry mine out with a butter knife. After doing that only once I went on line and got a new one for 15 bucks. Problem solved. Better then 200 for a new coffee maker.
SOURCE:
While the coffee is brewing without using the grinder feature, coffee overflows onto the counter. About 1/2 of the coffee goes into the pot while the rest spills over. I have cleaned residue from the lid...
overflow problem possible causes: 1) water is over the "10" marker, 2) no filter in basket 3) too much (or too fine) of coffee in the basket -- does not drain. Also make sure the "spring" on the bottom of the basket is not stuck (the one that lets you remove coffee carafe without dripping coffee.
Jan 17, 2011 | Cuisinart Thermal DGB-600 Grinder
Where can I get a replacement grinder filter basket holder for a Cuisinart DGB 300 coffee maker
Go to this link to order directly from Cuisinart for items for your coffee maker. Just copy and paste into your web browser.
http://www.cuisinart.com/parts/coffee_bar/dgb-300.html
Hope this helps, let me know if I can help you with anything else.
JimmyC
Sep 30, 2009 | Cuisinart DGB-300 Coffee Maker
Cuisinart DGB-300 coffee maker brew pause valve
No one has just the individual part, but you can get the whole brew basket with the part included on Cuinart's website, or by calling them.
Feb 03, 2009 | Cuisinart DCC-100 Coffee Maker
Coffee grinder on brew and grind won't work
Make sure the slot between the grind basket and filter basket is clean and free of grounds - then inspect the area near the grinder motor - use the brush that came supplied with the Cuisinart to clean that area out. Once thoroughly cleaned, try one more time to Grind. Let me know if it works.
-Tha Mp3 Doctor
Jan 06, 2009 | Cuisinart Thermal DGB-600 Grinder
Need schematic to reassemble...
The filter basket is orderable from Cuisinart and costs somewhere in the neighborhood of $5 to $6 - there is no service manual for that particular part of the coffee maker.
-Tha Mp3 Doctor
Dec 05, 2008 | Cuisinart Thermal DGB-600 Grinder
The grinder itseld seems to be working because it makes the grinding noise. However, the beans are not going down the shaft into the grinder. I have cleaned out the top and removed the container holding...
Make sure the filter basket is in the open position, and that the area that runs from the grind basket to the filter basket is free from grinds and mositure.
Jun 28, 2008 | Cuisinart Thermal DGB-600 Grinder
Coffee basket
Called Cuisinart - they said to remove the basket ( I unplugged and then used pliers to move the blade/shaft up and down until it wiggled loose ) ... use soap and water to remove coffee oil (the real problem) and then pour a little vegetable oil into the female end where the motor engages the grinder blade to lubricate.
May 26, 2008 | Cuisinart DGB-300 Coffee Maker
I just called Cuisinart and they will send me another brew basket for my DCC-100 (it has a Brew Pause valve also) for $9.14 (part + S&H). Did you try to contact Cuisinart?
Aug 30, 2007 | Cuisinart DGB-300 Coffee Maker
Cuisinart Thermal DGB-600 Grinder Logo
972 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Pierre Laplante
Steve Allison
Steve Allison
Norman Worley
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
