Question about Saeco Magic De Luxe Espresso Machine
Magic saeco plus
Machine whirls but won't grind. suggestion?
    Problem Solver:
  • 6 Answers
Sounds like you need to take the grinder apart as in the manual and clean it due to a stone or other foriegn object in it. It may also need an adjustment as it may have loosened up and be slack now. The other potential problem is your beans are to oily or to big.
Posted on Aug 30, 2007
My coffee is very weak. i have the machine for 8 years and always had a good cup of coffee
My machine is 11 years and I found that I had to increase the dose rate and also slightly giner grind.
Jun 25, 2014 | Saeco Magic Comfort Plus Espresso Machine
I have a saeco magic comfort +. It is, all of a sudden, not going thru the rinse upon set up. Then, it is not putting water thru the grinds, and, thus, pushing all grinds dry to waste, not generating...
Hi
Don't really like the rinse cycle because it waste water. If you want to rinse the brew unit just push the "scoop button" and not put any coffee in, then push the large coffee. Does the same thing but doesn't use as much water.
Dry grounds is one of my tips.
http://www.fixya.com/support/r4084157-dumping_dry_grounds_not_making_coffee
Jul 23, 2011 | Saeco Magic Comfort Plus Espresso Machine
My Saeco Magic Comfort Plus machine will not grind the beans. The grinder just spins and spins
You can try to remove all beens, then with the use of paint brush and vacum cleaner try to clean the grinding entry and gringing burrs. If
this not help then you need to revove top cover panel and so you can clean grindr more closer, check also the burrs they might need to be replaced.
Sep 03, 2010 | Saeco Coffee Makers & Espresso Machines
Saeco Magic Comfort Plus not dispensing coffee
Try setting the grind to the coarsest setting, if you still have the same problem, then descale machine.
Jan 09, 2009 | Saeco Magic Comfort Plus Espresso Machine
Making Espresso shots... how does the macine do this? Not in man
www.partsguru.com look to the left for Saeco Home Models, select that, then go the model you have and download the manual.
On a magic comfort it has two settings for adjusting the espresso shot besides the amount of the shot. .
On a magic comfort plus,
you can adjust the grind size, the amount used for the shot, preinfusion (a short shot of hot water on the grinds before the unit passes all the water through the puck (coffee grinds), temperature and amount of water for shot
Also, when setting the strength on this machine, don't use a full grind amount as it can jam the machine. use a setting of 6 or 7 max for strong shots, not the 8 or 9 setting!!!
Dec 03, 2008 | Saeco Magic Comfort Plus Espresso Machine
Saeco magic de luxe grinder problem
Hi Cindy,
Make sure you not get any water in the grinder, if you get water in the grinder then it bean smeary and will not grind the beans.
You have to clean the grinder if you get any moisten in it.
/Mirran
Aug 17, 2008 | Saeco Magic De Luxe Espresso Machine
Electonic display will not change on a Siemens Expresso machine
I have had this problem with our coffee machine as well some how the machine has sucked air into the system and needs to get it out.
To ventilate the machine turn the dial on top of the 'magic comfort' sign (the one for the froth) and place a glass underneath. Keep the dial turned till the sign ventilate goes away then close the dial.
This process has always worked for me...
Thanks
Coffee Fix
Nov 13, 2007 | Saeco Magic Comfort Plus Espresso Machine
Saeco Magic De Luxe Espresso Machine Logo
70 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
eyecam
Marvin
Marvin
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
