Question about Sony Ericsson W800i Cellular Phone
Battery prob.. is it normal that when you use your walkman the battery got low..or even when you use your camera?another is, how can you clean the lens of your camera?is it natural that the files in your memory stick duo could corrupt or got lost without any reason?
You need to get this problem repaired use vodeafone there the best xx
Posted on Sep 16, 2007
Camera indicates low battery even for fully charged battery.
I have connected my PowerShot A2000IS that was doing the same thing for me and I discovered the following:
1) The unit works fine even down to 2.5V providing the supply source (i.e. batteries can deliver 500 mA for a short burst during startup, i.e. when the camera's lens is extended). The camera draws 300mA with screen on after the initial startup current has settled. This means that the camera may not work with batteries like normal alkaline as these don't normally supply large currents, like NI-MH and NI-Cd can.
2) I found that if I lowered the voltage down to (using my bench power supply) that the low power indicator come on at just under 2.5 Vs, BUT once it has indicated low battery, turning the voltage back up to 3V didn't remove the low battery indication.
3) Finally I connected my fully charged (with combined voltage of 2.7V) Ni-Mh rechargeables (old and well used) using wires to allow me to measure their voltage and I found that when I turned on the camera the voltage dipped to 2.3V, but come up after the lens was deployed.
Conclusion and recommendations:
a) Get some new high quality Ni-Mh cells.
b) Don't use Alkaline cells (even Duracell brand might not handle it).
c) Forget Ni-Cd as terminal voltage would be at best 2.6V which doesn
Oct 03, 2010 | Canon Powershot A2000 IS Digital Camera
Low Battery
Try going to a service shop and asking to reinstall the firmware, this can fix the problem
Apr 20, 2008 | Samsung S1030 Digital Camera
Camera always says low battery even when you put in fresh batteries..will not allow me to take any pictures
Hello. Remove the batteries and use the eraser on the end of a common pencil to clean the contacts. Then replace the batteries and turn it on. J.
Jul 10, 2010 | Samsung Digimax A7 Digital Camera
'battery is low' even when batteries replaced
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
Oct 25, 2009 | Casio QV-R51 Digital Camera
My walkman will not charge. I left it on charge
Hi joanna,
It is probably not turning on due to extremely low battery. Have you been using it for quite a few years? Then there may be a problem with the battery. But before that, please try connecting the player to another USB port on your computer, or removing any USB extensions except what SONY provided, or upgrading your USB driver. If nothing works, I'm afraid you'll have to refer it to a service center.
Oct 22, 2009 | Sony Walkman NWZ-S616F MP3 Player
My digital camera shows a low battery even with new batteries
You need to clean the contacts inside the battery compartment. To do this "dampen" a cotton swab with rubbing alcohol and wipe the contacts clean. Clean the battery and the charger the same way. Thanks, Dana
Oct 18, 2009 | Cameras
Kodak C813 turns off because of low battery - all of the time!
The way to test this is to have some new batteries of the best grade, don't use the cheaper types, these may not make these cameras work correctly. I have seen this problem before.
Also you can try a set of fully charged rechargeable batteries. These kinds of cameras may use more power and need more power to make them work right.
Links to possible help on this:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=11580&pq-locale=en_US&_requestid=8931
http://selfservice.kodak.com/external/en/urg/urg_00776/GLB_en_urg_00776_manual_ATG/urg00776c3s1.html
Aug 23, 2009 | Kodak Easyshare C813 Digital Camera
Showing low battery even when new batteries have been put in
Have checked and its still in warranty, thank you for replying Mags
Mar 30, 2009 | Cameras
2005 Grn Caravan gauge arms swing to the right the back with igni
REMOVE YOUR battery terminals AND CLEAN THEM REAL GOOD THTWILL FIX THE PROB FOR YOU
Dec 03, 2008 | 2003 Dodge Caravan
Kodak easy share c 340
try taking out the batteries, and clean the connectors that the batteries touch, and the ends of the batteries (if recharagable). Sometimes a dirty connector can make the batteries seem that they are dead even if they are rechargable. If the camera works with new disposable batteries but not with the rechargable ones, then you may need to purchase some new rechargable ones.
Oct 23, 2008 | Kodak EasyShare C340 Digital Camera
Sony Ericsson W800i Cellular Phone Logo
21 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
