Question about CyberDrive CW088D CD-RW Burner
Driver Not recognised
My CD-R/RW is not recognised in windows. I have checked device manager and the burner is listed there. when I go onto properties the following is displyed ''Windows cannot initialize the device driver for this hardware. (Code 37)'' I have tried to update driver software but nothing works
  • stu1 Aug 22, 2007
    Thanks - however the solution supplied relates to XP, I am currently using Vista.What do I do now
  • stu1 Aug 22, 2007
    I have tried to update driver software but nothing works - My operating system is Windows Vista and I cannot change to XP
My LiteOn iHAP422-98 9 IDE drive will read but not burn CD/RW discs. No problem with DVDs or CD/R. One of two error messages, depending on the CD/RW disc: 1) Doesn't recognise a disk is in the...
Click start control panel administrive tools computer management device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
If this does not fix the problem you might try
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
hope this helps
Jul 14, 2011 | Lite On iHAP422 DVD+R Burner
I need solution for this problem immediately I installed windows 7 in my PC. after that in My PC DVD RW is not working.
Was the Windows 7 installed from a clean slate or you upgraded from Vista to Windows 7? If you have upgraded from Vista to Windows 7, then this is definitely a driver problem. You can try to update the driver by going to Device Manager, check if the DVD drive is listed. Pull down the drop down list, and right click on the devices listed under DVD/CD-ROM Drives and choose Update Driver Software.
If the DVD drive came with a software bundle (e.g. Nero Burning Application) Try reinstalling these application under Windows 7 Environment.
Mar 26, 2011 | LG (GCC4521BK) CD-RW/DVD-ROM (Combo)...
Can't recognise DVD RW
Hi all,
Boy, have I been having a problem. I've tried two different dvd burners, an external TDK DVD+/- RW drive and now an internal NEC dual layer DVD+/-RW drive. I have a Dell Dimension 4500 that came with a Dell branded Windows XP Pro. Have you ever tried getting support from Dell? What a freaking bad joke that is.
Microsoft says there is known problem with XP viewing a DVD+/-RW disc the same way it views a CD+/-RW disc. Problem is a CD RW uses 32 bit packets and a DVD RW uses 16 bit packets. As a result, without the fix, my computer can't recognize there is a DVD RW disk in the drive when trying to burn to it. It recognized DVD +R and DVD-R discs just fine, and I am able to burn to those with no problem.
What I want to do is image my hard drive and burn the image to DVD. That I can't do, because it always comes up with "no disk" or some variation thereof anytime I try to write to an RW disc. Any suggestions? Has anyone else had this problem?
Feb 28, 2011 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
Driver for dvd-r 8801 need a driver for dvd player windows won't recognise it
The drivers for DVD ROM drives are built into Windows and there is no download.
If Windows does not recognize th drive then it could be a hardware issue or possibly a BIOS setting is wrong.
Does the Windows Device Manager show an un-recognized device?
Apr 14, 2010 | LG (GCC4521BK) CD-RW/DVD-ROM (Combo)...
Recognised by windows as CD-RW but not as DVD-RW
Click Start
Click with the RIGHT mouse button on My Computer.
Click Properties.
Click Hardware.
Click Device Manager.
Click the '+' preceding 'DVD/CD-ROM' devices.
Double-click the CD/DVD device.
Click the Details tab.
The string displayed _should_ include 'DVD'.
Apr 05, 2010 | LG GH22NP20 22x Internal DVDRW Retail Kit...
My cd writer driver is showing error code 39
Your drive may have taken a driver update, causing the problem. In device manager, right click on the device and select properties, then under the driver tab, select "Roll back driver". If a driver update is at fault it will complete the roll back and hopefully cure your ills. If there is no driver to roll back to, you can attempt an update under the same tab.
I hope this helps and good luck.
Jul 12, 2009 | Sony CRX-230EE (33383923840) Burner
How to install a RW dvd burner
os should of recognised it and installed it..maybe it installed as generic and isnt suitable.
click start , right click my computer , click properties.....In system properties screen click hardware then device manager.
here youll find youre cd/dvd device.double click on it to open and display details/driver etc.click driver heading then update...app opens giving options choose use internet.
if it cant find software check the cd/dvd name/model ( in properties still open) write it down and search on net for it....download it install it
Jan 06, 2009 | Compaq Pavilion ZT3280US Notebook
DVD Burning Problem
To reinstall the driver RIGHT Click on My Computer - select Properties - select Device Manager - RIGHT Click the DVD listing - select Update Driver (have your disk handy).
Good luck.
Apr 19, 2008 | NEC ND-2500A DVD±RW Burner
Dell Inspiron 1200 CD/RW \ DVD Rom combo drive
Try this:- Go to my computer>properties>hardware>device manager and look down the list for your cd/dvd drives and click the '+' sign then highlight your dvd drive and right click to delete. Restart the pc and windows will find the drive again automatically and install the drivers. See if that sorts it.
Feb 03, 2007 | Dell (1G055) CD-RW/DVD-ROM (Combo) Burner
CyberDrive CW088D CD-RW Burner Logo
224 people viewed this question
Top CyberDrive Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a CyberDrive Computer and Internet Expert? Answer questions, earn points and help others
