Question about Panasonic CT-36HL43 36" TV
WON'T TURN ON
When you turn on t.v. it clicks red light comes on ,then it clicks again and red light blinks once every six seconds
  • KEITHB Aug 24, 2007
    it blinks once evry six sec till you unplug it
    President:
  • 3,130 Answers
So your saying it blinks for six times then starts over? There is a problem in the system control or the main regulator circuit. Unless you know how to work on solid state printed circuit boards, you really should call out an Authorized Panasonic repair service center to assist you with this repair.
Posted on Aug 23, 2007
  • Larry  Dillon
    Larry Dillon Aug 24, 2007
    Once every six seconds. So it goes blink, One two three four seconds five six, Blink, one two seconds three seconds four five six, blink One, and so on? If that's the case there is a problem with the 140 volt power supply. most likely the regulator circuit, or a shorted horizontal out put transistor.
Morning, it flashes red light six times
From the manual:
Press the (ON/STANDBY) switch to turn on the projector. If
the power is not turned on, disconnect the AC power cord, then
confirm the ON/STANDBY lamp is turned off. After about 10
seconds, reconnect the AC power cord and turn on the power
again. If the indicators still light up, the electrical system has a
problem. Consult with qualified Sony personnel.
Jul 08, 2016 | Sony VPL-VW95ES Full HD 3D Home Cinema...
My KDF-55WF655 power led blinking red six times.
It looks like your power module is on the blink. Do you get any picture?
Jun 13, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
I have a Plasma TV with black screen and 6 red light flashes.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
May 19, 2015 | Panasonic VIERA TC-P55VT50 55-Inch
Red light blinks six times. When I hit power button green light stays on for a few seconds, turns off the on for a few more. Then goes back to pattern of red light blinking six times.
the kill switch is open ensure the lamp cover presses firmly on the kill switch when u close the lamp chamber door the red light will stop blinking and u can now turn the tv on
Jul 06, 2013 | Televison & Video
Monitor won't turn on after a few hours of being shut off
If it EVER works, then the problem is not a failed part, but a weak part. The most likely component type to give you such problems are capacitors. But very few repair techs know how to find such problems, and even fewer have the equipment needed to find the bad one(s) in-circuit. The failure mode is high ESR (ESR means Equivalent Series Resistance). The lower the ESR, the better. Capacitors with high ESR cannot stabilize circuits which demand high pulse currents, such as in switch mode power supplies.
Apr 24, 2017 | Generic Computers & Internet
Sony bravia won't stay on 52w4100, clicks with green light three thimes then shuts off and blinks red 6 times
Sounds like a power board reset switch gone bad. Have the power board replaced.
Good Luck Ed Pinero
Feb 03, 2013 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
50PF9631D won't turn on... red light flashing/blinking 6 times
Your TV main board is damaged and you need a new one. You can order one on ebay and fix it yourself. Make sure you have the TV model/serial number on the back label of the TV to have the right part when ordering.
Jan 09, 2013 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Oct 26, 2011 | Sony KDF-E42A10 42 in. LCD Television
Tv won't turn on. blinking red light in lower left corner
unplug the television...wait 10 seconds and then plug back in....if you listen carefully after 5-10 seconds you will hear a click sound (the same sound that you hear when you turn on or off) ...once you have heard it, turn the TV on again using the remote. Do not turn on until you hear the click. If this does not work, try again but turn the TV on again before you hear the click. I dont know why it happens but it is as if the TV gets confused as to whether its supposed to be on or off. Most of the time, the solution is to turn it on after the click so I would always try that first.
Feb 14, 2010 | Panasonic TC-32LX700 Television
Panasonic CT-36HL43 36" TV Logo
122 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
