Question about Brother LS-1217 Mechanical Sewing Machine
Timing problem The problem started by loud metal sound like needle hit something, than machine stopped because of bunching threads underneath the fabric. It looks like the hook is not timed with the needle anymore: 1) The needle does not bring up the bobbin thread , 2) The hook does not catch the thread from the needle at all: The hook point passes the needle in the middle of the needle hole, when it should pass it just below the midpoint of the scarf on the back of the needle, what is above the hole of the needle, as I understand. Is it possible to adjust the rotation of the hook in this model of sewing machine? In older sewing machines this rotation adjustment was possible by loosening the three large set screws on the backside of the hook that secure it to the rotating shaft. What can be done for this model?
  • Anonymous Aug 11, 2008
    the nnedle is going up before the thread catches from bobbin
  • Anonymous Mar 22, 2014
    machine hesitates when I step on the peddle (belt adjustment? wiring is fine). Also, tension and timing needs adjusting.
  • 202 Answers
You might have to look at loosening the set screws for the gear on the lower shaft that drives the hook driver gear . Loosen the screws, slide the gears apart, then adjust the hook so it is entering the scarf of the needle on the upstroke. Slide the gears togeather so they mesh again and it should be back in time. There are other factors though such as needle height adjustment which is done with the needle bar and hook and needle clearance (the distance between the needle and hook) which should be about .030. I'm a Bernina tech but many machines work the same principle. Good luck.
Posted on Aug 23, 2007
The bobbin thread is bunching up
hi Lois.
this is all i could find out.
Check Your Tension Settings. Looping underneath the fabric usually occurs when there is not enough tension in the needle thread to pull the bobbin thread. Sometimes thread bunching can be caused by something as simple as the tension dial being inadvertently turn.
or try this link.
WHY IS THREAD BUNCHING UNDERNEATH MY FABRIC
or this one,
Sewing Machine Thread Bunching Up Here Why .
if you go to this link a little window might open up in the middle of the page just close the little window down.
or this.
The bobbin thread is bunching up Google Search
Dec 12, 2017 | Sewing Machines
There is thread pieces under the tread plate and when the machine tries to trim the thread it doesn't and sounds like it's hitting something
Sewing Machine Thread Bunching Up? Here's Why! - Craftsy
www.craftsy.com > Blog Home > Sewing Blog
Jan 21, 2014 - There are lots of reasons for sewing machine thread bunching up, and ... or bird nesting, on the top of your fabric, the culprit has something to do ... Frequent dusting underneath the throat plate and along the thread .... It looks like it's hardly been used but the top thread keeps tangling below the material.
Sewing Machine Needle Not Catching Thread ' ThriftyFun
www.thriftyfun.com/tf80302359.tip.html
Dec 20, 2015 | Sewing Machines
I just bought it and its sounds like metal getting hit by the needle, and the thread bunches up underneath fabric.
if it is brand new then have it fixed under warranty
if used then it appears that the needle/bobbin timing is out with the needle hitting the bobbin carrier ot the hook hitting the needle.
bunching up of thread under the material is a sign of upper tension to light
suggest that you have a service done to fix it.
Apr 10, 2015 | Sewing Machines
Top thread won't pick up bobbin thread
The machine's timing may be off and you can take the machine into a repair shop or contact the manufacturer through their web site.
Dec 05, 2013 | Singer 7422
Needle wont catch bobbin thread. Think timing is out.
First change your needle... it's probably bent and make sure you are using a needle FOR Denim in a size 18. Hand run the machine... if you still feel it hitting something... it is out of time. Take it in for repair.
Oct 05, 2012 | Singer 8763 Curvy
The thread is bunching up under the needle and needle keeps hitting something metal down in the bobbin case which then stops the machine. I've rethreaded bobbin, adjusted tension, checked needle &...
Your problem stems from the faulty foot lever mechanism. It's coupled to the upper thread tension control which only provides tension when the presser foot is in the locked down position.
If the presser foot won't positively engage in the down position, there's no upper thread tension and the thread bunches up below. Everything else stems from there. If the needle has hit the bobbin case too frequently then the bobbin timing may also be slightly out and the needle itself will be damaged and won't pass straight through the fabric; it only takes a tiny deflection from the vertical as it passes through the workpiece for the needle to flex and hit the bobbin case.
In summary, your machine is in desperate need of repair and adjustment. You haven't stated which exact Singer model you have, but they are usually easy to get servicing manuals for or you can take the machine to a sewing machine servicing specialist. Most singer spare parts (even for 100 year old machines) are usually still available fairly cheaply from a variety of sources, just enter "Singer spares" into your search engine to find suppliers.
To prevent re-occurrence, clean the mechanism regularly and lubricate it as directed by the manufacturer using sewing machine oil. Depending on how often you use the machine, do (or have done) a more thorough service periodically to check the timing and also that all mechanism screws remain tightly fastened.
I hope that my reply has shed some light on your problem and enables you to decide what to do next. Please take a moment to rate my answer.
Sep 30, 2010 | Singer Sewing Machines
Thread is knotting up on bottom of fabric causing it to stop
1.check the needle & see if it's bent--if so replace
2.lay the needle on a flat surface & roll the needle over if it doesn't roll true replace
3.check for blunt needle-if needle makes a popping sound when needle penetrates fabric
4.needle is not all way up in holder
on my mechanical sewing machine sometimes the threads come off the take up lever, that causes the thread to bunch up under something I'm working on
also check thread in bobbin
Jul 28, 2010 | Janome 4623 Mechanical Sewing Machine
Bobbin problems
Any time you have looping on the bottom, it is almost always related to the upper tension and not anything in the bobbin area.
A good way to troubleshoot this is to turn the machine off, blow out the upper tension disk assemblies with canned air, (the machine needs to be off because most canned air uses butane as a propellant. Butane + electricity = bad;) replace your needle, and rethread your machine. Once you've threaded it to the point where you're about to put the thread through the needle, "floss" the thread forward and backward to ensure that the thread seats correctly into the tension assemblies.
Set your tension to around 4.5 for most applications, and drop your presser foot. Give the thread a gentle tug to see if the tensions have engaged the thread, then thread the needle.
If doing this does not address the problem, you probably need to have your tensions professionally calibrated. This is also true if the needle is in fact hitting something in the bobbin area. This is usually caused by the machine's timing being out of alignment, which is not something that can be fixed at home.
Good luck,
-R
Aug 24, 2008 | Singer 6038 Mechanical Sewing Machine
Needle won't move; something stuck/dislodged
Can you remove the bobbin? Sometimes when thread gets bunched up under the lower plate it will force the bobbin out of position. Try taking it out and cleaning any loose thread and lint from the area. Put a couple of drops of oil on the outside of the bobbin case and re-insert it. Make sure you lower the needle and pull the bobbin thread through to the top and back behind the needle before beginning to sew again.
Hope this works!
Zelma
Jan 18, 2008 | Brother XL-2230 Mechanical Sewing Machine
Brother LS-1217 Mechanical Sewing Machine Logo
457 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
