Question about Philips SpeechMike LFH6164 Microphone
Convert to USB
Have above mike. Actually, 6174 with trackball. It has a serial cable (presumably for mouse control which I don't need) and white and black miniplugs, stereo. I want to convert it to mono USB. Don't need any controls other than start-stop. Using sound card, I can hear, but not speak. Do I need a stereo to mono adapter first? SS
4 Suggested Answers
SOURCE:
Benimur
  • 6966 Answers
SOURCE: setting up tv sound to come thru stereo speakers
Offhand, your Philips 32PFL7422/98 do not have regular Audio Output RCA jacks (white and red), sorry. However, right before the antenna connector is an S/PDIF output connector. This should allow transfer of digital audio signals from the Philips 32PFL7422/98 to a S/PDIF capable receiver or amplifier. If you would look at the rear of your stereo and determine if it has such an input, then it would be a matter of getting the right cable/connector.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 16, 2008
  • 6771 Answers
SOURCE: I have a philips hts2500 home theatre system and
Part of the surround sound system is not working due to some audio output ic issue or the audio processor.
Posted on Mar 10, 2012
SD Tech
  • 14553 Answers
SOURCE: I don't have a remote and the tv is in mono how do
It will usually default to Stereo and still show mono--answer is to manually try (usually not possible) you need to get into the menu with the original remote---Philips at my last count had over 25 different IR codes for their products==many of which are not available with universal remotes etc.
Posted on May 02, 2012
DO I NEED SPECIAL DRIVERS FOR PHILIPS SPEECH MIKE 6174 FOR MY COMPUTER
Here is site to find drivers, check your model number as 6174 does not come up.
Dec 20, 2014 | Philips Computers & Internet
Tip
USB devices not recognised or not working properly?
Try these steps to reinitialize your usb ports on your pc
1. Unplug ALL USB devices connected to the computer. If you are using a USB mouse and keyboard, temporarily use the older type PS/2 devices if you have them, if you don't then just leave them connected.
2. Hold down the windows key and press r
3. Type devmgmt.msc into the run menu and press ok
4. Click on the + sign next to the Universal Serial Bus Controllers
5. You might need another mouse to do this if you have a usb mouse.. I recommend you get a ps2 connector mouse which goes into the green round connector in the back of your pc.
6. Right click and uninstall first the usb root hubs. all of them then uninstall the rest of the devices you see under Universal serial bus controllers
7. Ones you have uninstalled everything you should see the Universal serial bus controllers there at all.
8. Now go ahead and restart your pc.
9. Ones you have restarted the pc your usb ports will reinstall in a moment stand by while it installs all of them. If you get warning messages click ok or continue installation.
10. Now go ahead and plug the usb devices back in. Install software if required, all usb devices if not faulty or broken should work now. Also note the error code if you get one?
This solution doesn't fix all usb problems so if you have a yellow ! mark there and device status reports a error code. Then it might not be a problem with your usb ports.
Thank you for reading, do leave suggestions, comments, feedback below.
Ekse
usb mouse drivers for windows xp mouse trackball mouse drivers bluetooth mouse computer problems 2.0 usb driver microsoft windows scanner driver usb 2.0 air mouse computer service usb hubs update drivers fix windows computer services computers hub usb usb drivers usb 2.0 hub laptop mouse usb switch 4 port usb 2.0 hub wireless mouse usb driver fix computer windows xp pro usb optical mouse computer support computer repairs update driver 4 port usb hub usb security usb cable windows xp microsoft windows xp computer repair windows xp professional upgrade windows
on May 04, 2008 | Microsoft Windows XP Home Edition
Why won't my Logitech Traackman MArble FX work with Windows 7?
If you are trying to convert your Logitech Trackman Marble FX from PS2 to USB so it will work with Windows 7, you can't just convert the port type - you have to get an "adapter" that converts the PS2 signal to a USB signal. See for ATen - UC 100KMA. WEB SIte:
http://www.aten.com/products/KVM/KVM-Modules-&-Accessories/PS2-to-USB-Adapter~UC100KMA.html#.U5sYrCi4NAE.
It allows you to convert a PS2 keyboard and PS2 mouse/trackball with the one device. It's what I use and it works just fine. The regular $2.00 port adapter was useless.
They are on EBAY sometimes for $20 or so. GOOD LUCK. :)
Jun 13, 2014 | Logitech Trackman Marble FX Trackball
W7 using dongle ps2 to usb
Feb 14, 2014 | Logitech Trackman Marble FX Trackball
The tiny red ball bearing got lost, what could be used as a replacement?
Kensington took its time bringing an optical version of its venerable Turbo Mouse to market. The Turbo Mouse was the original multi-button ADB trackball, introduced back in the late 1980s with two buttons and evolving through the late 1990s into a four-button, do-everything wunderkind of a mouse. Unfortunately, Kensington didn’t rush to produce a USB version once the iMac hit the market, leaving users stuck with the imperfect solution of a USB-ADB converter or—heaven forbid—even worse, the stock iMac mouse. Finally, when it got a USB version to market, the rest of the market had moved on to the optical mouse, and Kensington’s renamed Expert Mouse was behind the times again.
No longer.
expert-mouse.gif The latest revision of the Expert Mouse, version 7.0, has been out for about a year, and it fully lives up to its billing as the “ultimate trackball.” With USB connectivity, optical tracking, four programmable buttons, a brilliantly conceived “Scroll Ring,” an included wrist rest, and a billiard-size trackball, this mouse is the whole package.
Let’s get one thing out of the way: the Expert Mouse is the epitome of all things trackball. It’s the latest offspring of the original trackball mouse. If you’re a trackball-hater, approach this review with an open mind. Don’t hate the player. Hate the game—and Kensington’s game is not to be hated lightly.
A good mouse starts off with one of two things: either it’s dead simple or it has great software. Apple has always taken the dead-simple route. Kensington takes the opposite tack, with incredible software that makes an otherwise complex mouse quite easy to use.
Software has traditionally been a Kensington strong point, and the latest version of MouseWorks for Mac OS X is no exception. The only drawback is that third-party mouse support has disappeared. (A little-known secret on the Classic Mac OS was the fact that Kensington’s ADB MouseWorks software was amazingly supportive of non-Kensington devices, sort of like an ADB version of USB Overdrive.) It’s hard to find fault with Kensington for failing to re-implement this feature when it rewrote the software from scratch for Mac OS X.
expert-app-settings.gif MouseWorks will be immediately familiar to anyone who has used the Classic version, except it’s now implemented as a preference pane rather than a control panel application. Separate tabs are provided for button assignments, scrolling control, click speed, and—best of all—acceleration, which allows for a fantastic degree of fine tuning. There is excellent help and documentation, which are thankfully no longer the rarity they once were. Buttons can be assigned on a per-application basis, giving the user limitless possibilities for individual behavior in each application. This comes in especially handy for media pros, though almost every power user can, in time, make good use of it.
expert-acceleration.gif As with all good software, the default settings are sensible, too, though most folks will probably find the default scrolling speed and cursor tracking a bit too slow. Unlike Classic versions of MouseWorks, the new version bases these values on their corresponding global system preferences, so if you find yourself wanting to turn it up to eleven, make sure you’ve adjusted the settings in the Keyboard & Mouse preference pane first. Conversely, if you find it turned up to eleven and a mere tap of the mouse sends the cursor all the way across your screen, make sure the Keyboard & Mouse settings aren’t too high.
There seems to be one minor bug with the software under Mac OS X 10.3: plugging or unplugging the mouse seems to activate the screensaver within about 20 seconds. There doesn’t appear to be any rhyme or reason to this behavior, but it’s fairly reliable and happens almost every time.
Let’s move on to the mouse itself. The great benefit of this long line of trackballs has always been the size of the ball, which allows for much better cursor control than, say, the built-in trackballs on 100-series PowerBooks or the thumb-balls used on Logitech and Microsoft’s widely tolerated optical trackballs. If you’re soured on trackballs because of bad experiences with another model, rest assured this is one area where size does matter, and the Expert Mouse could well change your opinion.
expert-mouse-hand.gif The included wrist rest is a nice touch. Though wrist-rest mousepads are a dime a dozen now, the pleather-covered dense foam makes for a comfortable and stable support. Just don’t plan on taking it off. It snaps into its two mounting holes very tightly, and it’s pretty tricky to remove. The leading edge sticks up a little higher than it should, which is mildly uncomfortable. Moving your hand up on the mouse a bit helps, but doesn’t entirely avoid the problem. Of course, if you already have a wrist-rest mousepad, this should be a non-issue.
Kensington sensibly attaches a six-foot cord, putting the Expert Mouse within reach of even the worst hide-the-tower-under-the-desk setups. This cord is no longer detachable, as the ADB cable on the Turbo Mouse was, nor is there a USB pass-through on the Expert Mouse, though there’s admittedly less reason for one with the proliferation of USB hubs on the desktop. Though not tested for this review, a wireless version of the Expert Mouse (using proprietary RF, not Bluetooth, unfortunately—maybe in version 8.0?) is available for an additional $20, if you’re the type who hates any cord clutter and loves to use batteries.
Tracking is accurate and generally smooth, although not as precise as I remember the Turbo Mouse being under Mac OS 9 on my Wall Street, especially at slow tracking speeds. Fortunately, with the optical pickups, you’ll never have to worry about the ball sticking or the horrible thunking sounds the ball bearings in the old Turbo Mouse could make when dirt and dust got into the mechanism. Trust me, with heavy use, this happened more often than you might think, and the Turbo Mouse required fairly frequent cleaning. It’s one of the disadvantages of a trackball, with its upward-facing mechanism that collects whatever gravity drops on the ball.
expert-scrolling.gif Scrolling with the ring is very comfortable and feels quite natural, since my ring finger and thumb rest on or near the scroll ring anyway. It is not, however, as smooth as the tracking is. In fact, it’s noticeably jumpy at times. The scroll ring has very shallow detents that seem to exacerbate this problem, much like the soft clicking you feel on most scroll-wheel mice. At least some of the blame can be laid at the feet of application developers, though. Scrolling is noticeably smoother in Safari than in either Camino or Eudora.
Finally, those four glorious, programmable buttons are all within easy reach for maximum clickability. Even reaching over the massive trackball to chord is no problem, as your hand settles into a natural spread over the top of the mouse.
When I dropped $120 on a Turbo Mouse back in 1999, I did so sight unseen and without having tried it. Call it instinct. With the $20 price drop and superior features, the Expert Mouse is an even better value than its grandfather was, because the experience is markedly improved. While a lot of people might say $100 is too much for a mouse, a lot of people haven’t given the Expert Mouse a fair shake.
Kensington is one of the very few computer or peripheral makers to offer a fully transferable five-year warranty on anything, and their technical support has been highly praised in the rare case that it’s necessary. Do whatever you can to experience this mouse, and then try to argue it isn’t the best trackball—and maybe the best mouse—ever made. Well done, Kensington. Well done indeed.
Apr 30, 2010 | Kensington Expert Mouse Trackball
It is possible to convert the cable of lq-2180 from parallel to sb cable?
No!
Are you trying to connect your printer to a PC using the USB port?
If so, it would be far better to purchase a USB to Parallel port cable.
The data passing over the USB cable will have to converted from a serial format to a parallel format before the printed can store the data,
Next, the converted has to add the required control signals in order for the printer to read and latch the data.
Don
Apr 18, 2010 | Epson LQ-2180 Matrix Printer
I have lost my serial/PS2 Cable for the model #64215 wher can I get such cable here in Europe /Hungary or Germany.Please help me
This cable is a serial to PS2. You can buy these on the Internet from cablestogo.com or another cable company. If you cannot find this, or it is too costly, this mouse is being sold on the web for a very reasonable amount.
Dec 14, 2009 | Kensington Expert Mouse Trackball
Microsoft trackball explorer. lights blink a few times, then lights go out and mouse stops working. works fine on other computer.
If the mouse has a USB cord to plug into your computer it sound like the mouse and the computer arnt sharing power like they should be.....check if the USB mouse is blocked by your add-onn manager but other than that i have no clue how to fix that
Aug 19, 2009 | Microsoft Intelli Explorer 3.0 Mouse
Kensington 64215 PS2/ Serial Trackball on USB Mac?
Is the trackball supported by the MAC operating system? If available try the same setup, using the adapter, on a windows based computer to troubleshoot whether it is the trackball or the Mac.
Mar 24, 2008 | Kensington Expert Mouse Trackball
Trackball connection
no, neither a trackball, nor a mouse can bne used with an iPAQ. The only mouse to be used with iPAQs is a bluetooth mouse.
Sep 12, 2005 | HP iPAQ H2215 Pocket PC
Philips SpeechMike LFH6164 Microphone Logo
89 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
