Question about Mitsubishi VS-45605 50" Rear Projection Television
RGB problems - different model
I couldn't locate my model on the site, but I hope someone can help me. I have a 52" Rear Projection Mitsubishi VS-461RS made in 1987. I bought it used and it's worked fine for some time now, but last night, in the middle of watching a DVD, the colors on screen split up - the red and blue appear slightly out of phase with the rest of the picture, and not only are they staggered off the main picture, but they're also weaving up and down around the yellow/main picture. I tried to adjust with the test dials, but they don't make much difference. If anyone can offer me any help in this matter, I'd appreciate it. Best case, something I can do myself, since the TV is rather large and would be a pain to take to a repair shop. I am pretty handy with electronics, but I'll defer to more experienced heads, if necessary. Thanks!
  • paul-buchman Aug 22, 2007
    Both. At first, I thought it might have been only one input, but it's on both AV and both Tuners
    I tried a full power down, plug out, and that didn't help either.
By the age of the unit you probably have a few cold solder connection in and around the power supply and video sections/
Posted on Aug 23, 2007
    Sergeant:
    Champion:
  • 375 Answers
Does only happen on a/v inputs or on tune also/
Posted on Aug 22, 2007
Green light flashing what does that mean?
The steady blinking green timer led is usually caused by failed capacitors on the DM and Power board which prevent the set from completeing the Boot sequence
Jul 20, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Dlp picture showing pink and green
Hello sir, good day, your dlp is missing the B (blue) color from the RGB signal, this is caused by the Blue wire open, replace your dlp signal cable.
May 08, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Dear Sir, I have an Mitsubishi WD 52525 model DLP TV. After about one hour of being on, the picture on the tv starts shaking and jumping around. I tried the reset buttom on the front panel but it does not...
I'm sorry to tell you that on these units the video tube and lamp are the first things to go. If it is not under warranty it is a costly repair. You might consider craigslist as you can get some great deals. Another option is to unplug it and set it aside. Go on line to the Mitsubishi site at this link
http://www.mitsubishi-tv.com/theater.html
see about getting an extended warranty. Make sure that there is someone in your area that honors there warranty. Hope this helps.
JimmyC
Sep 27, 2009 | Mitsubishi WD-52525 52" Rear Projection...
52" mitsubishi rear projection tv model vs6051 sound no picture
Not exactly familiar with this model but sounds like the projector lamp is burned out. Hopefully it's a replaceable type. Try calling these people - http://www.purelandsupply.com
Mar 29, 2009 | Mitsubishi VS-60111 60" Rear Projection...
Getting to the chassis of mitsubishi wd-52525
This is not something that you should attempt on your own. There are dozens of capacitors on several different circuit boards that will need replacement. Furthermore, just the disassembly process is quite complicated and time consuming, not to mention locating all the bad caps and then the re-installation process afterwards.
Mitsubishi will rebuild this chassis at their facility. Contact them so they can locate a company in your area that can handle this for you. Be aware though that this can cost $600-$700 or more between parts and labor. Perhaps someone at Mitsubishi will help pay for this repair.
michtech
michtech
Feb 15, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Display problems
Sounds like bad 1000uf capacitors on the FMT board there are 3 100ufs on that board that can cause that symptom
May 09, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Advent 42" Plasma Tv
It sounds like the tv maybe in RGB mode.
Dec 30, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Upgraded DirectTV satelite TO HD
direct tv hd receiver is hdmi or rgb which is a different signal than the rgbhv input on the back of older mitsubishi tv . You can buy a converter that converts the format for about 90 dollars online. It converts rgb or component to vga/rgbhv
Oct 24, 2007 | Mitsubishi WS-55805 55" Rear Projection...
The colors on my TV are really messed up. Help?
You have bad convergence ICs. They are located on large aluminum heat sinks usually near the rear of the chassis. The number generally looks like STK###-###. If you have no experience soldering or in electronic repair I cannot walk you through it on this web site. The repair cost should not exceed $150.00 at a reputable repair site. I would suggest getting someone to take care of this. Good luck.
Jun 27, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi VS-45605 50" Rear Projection Television Logo
64 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
