Question about Motorola Mobility RAZR V3
Loud key sounds
I can't figure out: 1) how to turn down the ringer or turn the phone to vibrate without making a beeping sound with each decrease in volume. 2) how to turn the sound of the keypad off, so I can have the ringer on, but not have to hear every key pressed when I send a text.
  • ak335 Oct 18, 2007
    Awesome!  Thank you so much!!!
With your v3 press <<
>> select <<>> select <<>> in <<>> you must choose a ring style exemple:<<>> then goto <<>> and move to <<>> and change 7,6,5,4,3,2,1. Normaly, i put number 3 it's loud enought.
Posted on Aug 22, 2007
Tracfone customer service
  1. Check a ringer volume and profile. Press a volume key to see the volume status bar at the top of the screen. Use the volume up and volume down keys to adjust the loudness of the ringer (scale 0 to 30). Tap on the text next to the ringer icon to change the profile (vibrate only, ring+vibrate).
  2. Check if the issue is with a specific ringtone: Go to Settings > ringtones+sounds > Ringtone, and tap on a playbutton to preview the ringtone.
  3. Switch off the ringer vibration (Settings > ringtones+sound > vibrate) temporary, to determine if your phone is affected by any motion settings i.e. Flip-to-Silence.
  4. Make sure that call forwarding is not switched on: Tap the phone icon > ... > Settings.
If the problem persists, restart your phone by pressing and holding the power and volume down keys simultaneously until the phone vibrates. Release and the phone will restart. After this operation, you may need to re-adjust the volume and set date+time on the phone. Note that this does not remove your personal content.
Mar 13, 2014 | Computers & Internet
I did not receive a user manual with this phone...the ringer volume is EXTREMELY loud, cant figure out how to turn it down.
you can go to menu, settings, sounds or arelts and turn it down or use the the up and down keys on the upper left of your handset
May 18, 2011 | Cell Phones
My phone will not vibrate at all anymore
Hi
Make sure your ringer is not in vibrate mode. Try These this thing first
Press Menu > Settings/Tools > Settings > Sounds > Ringer Type > Voice Calls.
Select Caller IDor No Caller ID. (A list of ring type categories will be displayed.)
Select a category, and then use your navigation key to scroll through the available ringers. A sample ringer will sound as you highlight each option.
Press OK to assign a ringer. Make sure your speaker works. Turn On your speaker phone while talking to someone and see whether you can hear or not. Make sure the increase the volume using keys on side of your phone.
If none of these works the ******** motor needs to be cheked for loose connections inside the phone.
Thanks for using Fixya
Mar 24, 2011 | LG Ally Cell Phone
Phone will only vibrate and not ring
a. Make sure your ringer is not in vibrate mode.
1. Press Menu > Settings/Tools > Settings > Sounds > Ringer Type > Voice Calls. 2. Select Caller IDor No Caller ID. (A list of ring type categories will be displayed.) 3. Select a category, and then use your navigation key to scroll through the available ringers. A sample ringer will sound as you highlight each option. 4. Press OK to assign a ringer.
b. Make sure your speaker works. Turn On your speaker phone while talking to someone and see whether you can hear or not.
c.Make sure the increase the volume using keys on side of your phone.
Mar 14, 2011 | LG RUMOR Cellular Phone
How do you turn up the ringer volume on the Jitterbug phone. It's currently set on vibrate & I don't know how the volume got turned that far down.
First, make sure your Jitterbug phone is turned on and open. While looking at the inside screen, adjust the volume by using the rubber volume button, which can be found on the outside of the phone. Press the top of the button to increase the volume and the bottom of the button to decrease the volume. The inside screen will display the ringer volume level. The ringer volume ranges from Vibrate to Max.
If you need additional help, you can call a customer service expert available 24 hours a day 7 days a week at 1-800-733-6632 who will walk you step-by-step through the process.
Jan 31, 2011 | One Touch Jitterbug One-Touch Cellular...
I have 4 KX-TG2740 units, each with 2 lines. One unit does not ring for line 1. It says "Ringer Off line 1". I can't figure out how to correct. Thank you.
Press CONF/FUNCTION key, scroll to Ringer Setting by using the up or down arrow of the center navigator key, then press the right arrow. Press the right arrow again at Ringer Volume. Press the down arrow to select Line 1. Press the up or down arrow to choose the ringer volume you want. Press the right soft key SAVE, a confirmation beep will sound.
The ringer volume can also be set while a call is ringing in on the line. Make a call to Line 1 number, use up or down arrow key while phone is ringing to adjust volume of Line 1 ringer.
The following link is for the manual in pdf format.
http://service.us.panasonic.com/OPERMANPDF/KXTG2740S.PDF
Jan 31, 2011 | Panasonic KX-TG2740 Cordless Phone
How do you adjust the volume on the Samsung T255 StraightTalk phone?
Sound Settings
You can customize various sound settings.
Incoming call
Note: When downloading MegaTones® or HiFi RingersTM, charges may apply.
Ringtone.
This menu allows you to select a ring melody. Highlight Ringtone and press . Use the Up or Down key to highlight a ring tone or press the Left or Right key to select a file from either the Default Melodies, Voice list, or Sounds folders. Press the Select soft key.
Volume
This menu allows you to adjust the ring volume to one of 7 levels plus Silent mode and Vibration mode.
  • Use the Right or Left key to increase or decrease the volume.
Alert type
This menu allows you to specify how inform you of incoming calls. Use the Right or Left key to select an Alert type.
The following options are available:
- Melody: the phone rings using the ring melody selected in the Ringtone menu.
- Vibration: the phone vibrates but does not ring.
- Melody and vibration: the phone rings and vibrates simultaneously.
- Vibration then melody: the phone vibrates three times and then starts ringing.
- Melody then vibration: the phone rings using the ring melody selected in the Ringtone menu and then vibrates.
Message tone
This menu allows you to set up the ringer for incoming messages. You can set the Tone, Alert type, and Repetition.
  • Use the Up or Down Navigation keys to make your selections.
Keypad tone
This menu allows you to select a Beep or a Xylophone for your Keytone and to select the Volume (0-7) that the
phone sounds when you press a key.
Jan 25, 2011 | Samsung T239 Cell Phone
I own LG VX8360 and can't figure out hoe to turn ringer on. Can you help me?
To restore the ringer it will depend on what mode your phone is in:
Vibrate Mode:
Sets the phone to vibrate instead of ring.
To set Vibrate Mode, with the flip open, press and hold the # key .
To return to Normal Mode, press and hold the # key again.
Sounds Off Mode:
Quickly deactivate your phone's sounds when you're in a place where phone sounds would be disruptive.
From standby mode with the flip open, press and hold the lower side volume key for 3 seconds. To return
to normal sounds mode, press and hold the upper side key.
Airplane Mode:
Turning on Airplane Mode will disable all wireless communications.
1) With the flip open, press the Menu key.
2) Use the Directional Key (top center of phone) to scroll to 'Settings and Tools'.
3) Press the 6 key for Phone Settings.
4) Press the 1 key for Airplane Mode.
5) Use the Directional Key to highlight a setting, then press OK.
On/Off
Mar 30, 2010 | LG VX8360 Cell Phone
Silent mode (vibrate only) capability
Although there is no real profile support in the SCH-u740, a simple downward press on the volume rocker lets you quickly silence the phone, while pressing upwards will reactivate the normal ringer.
With the phone open, a long press on the 'T' or '#' key will toggle the VIBRATION mode. The device comes with 11 ringtones built-in, but they are very basic sounding.
Jan 17, 2008 | Samsung SCH-u740 Cellular Phone
Motorola Mobility RAZR V3 Logo
329 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
