1999 Subaru Forester Logo
A
Anonymous Posted on Apr 16, 2017
CEL blinking, rough idle, smoke blowing out exhaust: help!
Second leg of long drive (2.5 hours each way): CEL is usually on (emissions problem, common) but it started blinking, was running rough, shuddering, seemed fine at higher speeds on highway. Put some mid-grade fuel in an topped up the oil as it has been burning oil It seemed better. But then when I slowed down at exits, it started blowing LOTS of white smoke out exhaust and smelling bad. Cat converter was replaced last fall; car has total of 205K miles (195K when I bought it). Not sure if head gaskets were ever replaced. Any ideas? I am scared to drive it and also scared the repairs will cost a mint...
5 Related Answers
Anonymous
  • 3 Answers
  • Posted on Dec 29, 2008
SOURCE: intermittant stalls & rough idle
i would say maf 2
Anonymous
  • 1990 Answers
  • Posted on Jan 04, 2009
SOURCE: b4 blowing plooms of smoke
Assuming that the Smoke is White or Black, You are gonna have to get an Overhaul on that Motor.
jmeyer847
Jeremiah Meyer
  • 204 Answers
  • Posted on Jan 06, 2009
SOURCE: 2001 subaru legacy leaking coolant from head gasket......
Your mechanic is ok with saying that...however you should replace both head gaskets. This can get costly if you take it to have it done somewhere, but if you use a manual from your local library or buy one from your local auto parts store, its a much more cost effective way of fixing it. You are ok to drive it, be sure to check your fluid before you do. I would look into getting these changed within the next few weeks.
Thanks for using Fixya!
Sincerely,
JC
Anonymous
  • 2559 Answers
  • Posted on Jun 03, 2009
SOURCE: No power, idling rough
Replace the catalytic converter and EGR valve
Anonymous
  • 321 Answers
  • Posted on Jul 03, 2009
SOURCE: After high speed driving, slow speed shudder
when it starts to shutter get the car up on a lift and spin the wheels and look and see if there is a wheel bubble.
if the brakes were done recently a binding brake pad can cause some of that.
hope this helps
jm
2answers
What is causing it to run roughly?
Black smoke meaning its burning most probable cause of that is a blown head gasket,check your oil depstick for color change if its brown you got it,its also a simp toms of the crankshaft bearing of your car is already wearout also a posible cause of your valve seat,bearings the mechanical parts by the rocker arm assembly.
CEL blinking smoke coming from exhaust, rough idle
White smoke is indicative of burning coolant. Gray smoke is burning oil.
Have a compression test done which will often give an indication of evolving head gasket problems. If the coolant level is going down, and there's no obvious leak, its a head gasket.
Black smoke from exhaust, rough idle, black soot on plugs
signs of a bad fuel pressure regulator-- the vehicle will run rough, the engine will not start ( usually in the mornings,) many times engine starts but stalls shortly after starting. a bad regulator can result in fouled plugs. replacement is only cure. 1- black soot on plugs-2-black smoke from tailpipe-3- running rough-4- stalling, good-day! repost if need be.
1helpful
My 2000 Toyota Echo has the red engine temp light flashing. I checked the coolant container about an hour after I parked in the shade of my house. (95 degrees here today and I was driving on the highway...
a flashing check engine light (CEL) is a warning to stop driving-one that is on steady (not blinking) means something is wrong, but blinking is BAD-make sure it is completely cooled down, and fill the overflow/surge tank, start it up (use 50/50 antifreeze) and let it idle until the engine temp is all the way up-this can take 10-15 minutes, make sure the heater is on high temp setting and the fan is on-look at the temp gauge if it has one to see if it looks normal. If all looks good, fill the tank to the FULL mark (or a hair above it) and put the tank cap on tight. Drive the car for about 10 minutes, and pay attention to the temp gauge-if it looks good, and the engine is alright, the CEL probably with either not light or will go off by itself.
It is possible you did damage driving it with a flashing CEL, however-if so look for leaks, smoke out of the exhaust, poor running/performance, or more ominous signs of trouble like air bubbles in the overflow tank, oil in the antifreeze of antifreeze in the oil-aluminum engines do NOT tolerate overheating, if you ever see a high temp gauge and/or a flashing CEL-STOP and get it checked out, you will save yourself a lot of money being prudent.
2helpful
Grand prix has a 3.1 6cyl. and 166000 mile, it blow white smoke
Sorry to inform you of the bad news but the white smoke is engine coolant burning off and the rough running condition is also associated with coolant leaking into the combustion chambers.This will be a head gasket repair, basically a head job where you will need to machine the heads down and install new gaskets from the heads up.Get back to me if you have any more questions, thanks and I hope I could help!!!
2answers
Vibrations While Idle and smoke issue!
2002 a4 try fuel cleaner first, see how that goes after driveing for a while,,,the same goes for the 200 a4,, then we work from there
Exhaust blows black on ford explorer
look for a vacume leak. black smoke means it is running very rich
1helpful
Rough Idle, and Black exhaust smoke.
coolant temperature sensor boken, check and replace if defective.
1helpful
2answers
B4 blowing plooms of smoke
Top Subaru Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Oliver Street
Are you a Subaru Expert? Answer questions, earn points and help others
