Question about Canon (6981A002AA) for imagerunner 2200, 2800, 3300 Print Server
Error code on screen is E602-0003
There was a power outage at the school. When the Canon iR 2200 came back on, the only thing on the screen was that error code. Looked in the forums to see what others tried, and found the suggestion to hold #1 and #9 down while powering it on. Did so, and flashing cursor appears in top left of screen. Didn't know how long to hold 1-9, so let go, and the cursor dropped to the bottom left and was solid for 45 minutes. Powered off the unit and held 1-9 again, then powered on and let go. Cursor flashing in top left corner, but won't drop down now, after one hour. If HDD is gone, how to restore it? Thanks.
  • Nan Douglas Sep 21, 2007
    Thank you for the advice and information, GeorgeD. That's what I had to do, call Canon service and he brought a new hard drive and installed it. Thanks so much.
  • bergm57 Nov 30, 2007
    Is replacing the HD a big deal if you have experience with computers? If not does it take a special drive?
    Thanks for your response
I have problem in my cannon ir 3320 it shows
E602-001 & E0315-000d
pl solve it
Posted on Aug 12, 2010
E602-003this code means Canon’s hard disksystem have some problemsthe only solve way is change the hard diskThe hard sisk form our company just need connect to the printer then can usewithout any unconventionalitytill now our hard disk we selt to everywhere in China not found any trouble . if client’s machine already have print function,only need add our company’s print system then can get back the print function.(this print system need add RMB100)。If client’s machine don’t have print function,only need prepear the ROM card and network card from our company then can have the print function.(the ROM card and network card need add RMB600)
Our major disk:IR 2200IIR 2800IIR 3300IIR 3320IIR 5000IIR 6000IIR 8500I kprice as following
*Period of validityall the year*
ADD:
201, West block, Shang bu commecial building , Hua Qiang south road, Fu Tian district, Shenzhen China.
Tel:0755-81677725 83001919 Mr.Lin
QQ: 870530595 E-mail:
zcdigi@hotmail.com
Posted on Aug 21, 2008
  • 59 Answers
You were on the right track, but this process can take much more than 45 min depending on how many sectors (on the HDD) are toast. Unfortunately, one key issue with running this fix is that you are NOT to turn it off while running, which it sounds like you did and now you cannot access the drive. I don't know that I would say the the HDD is totally toast....but a service call to Cannon (or your equipment vendor) is most likely in order. Good Luck.
Posted on Aug 25, 2007
  • George Dearborn Sep 21, 2007
    It was my pleasure to help you.
4 Suggested Answers
LASITHA-VEGA
  • 428 Answers
SOURCE: What does error code E602-0003 mean on an IR 2200?
A HDD (iScsi most probably) failure - Internal HD. (Hard Disk Drive = HDD).
Posted on Jun 02, 2010
  • 3 Answers
SOURCE: canon ir 2200 help
For problems with the hard disk on the Canon ImageRunner (my model is 2220n):
Step 1: Unplug the unit (leaving power switch on), and then plug back in while holding down the 1 and 9 keys
Step 2: Wait. The hard disk will reformat - you should see at first a flashing white block in the upper right hand corner, then you will see white blocks building rows on the screen left to right with the screen eventually filling entirely. This may take an hour or more.
Step 3: After reformatting, your screen should say "Download Mode" at the bottom. Now just turn the machine off, unplug it for a few seconds, plug it back in, and then turn it on (you must switch power toggle off and then on - not sure if unplugging is necessary but it worked for me).
This site is great and has saved us at least $1,000 on copier repair this year - repairs that really didn't require a tech at all.
Good luck.
Posted on Apr 01, 2009
jalamb
  • 103 Answers
SOURCE: What does error code E0002020001 mean on a Canon
check the platen glass & adf scanning Glass is proper
That mean white plate error.
Posted on May 10, 2010
Canon2202ir E0000-000 This error code deals with the fuser unit. It is saying that the fuser is not warming up. It needs to be reset in service mode.
How can I enter service mode on canon ir 2202? - Fixya
www.fixya.com/.../t25374950-any_one_help_me_enter_service_mode_...
Jan 19, 2015 - In standby mode, press the "Settings/Registration" key. 2. Press the "Reset" key. 3. Press the "Back" key. 4. Press the "Settings / Registration" ...
Error Code ir 2202n - CopyTechNet.com
www.copytechnet.com > ... > Copier Technical Discussion > Canon
Nov 22, 2014 - 3 posts - ‎2 authors
... pls help me ....i know how to enter service mode but ......pls help. ... Copier Technical Discussion · Canon. [Error Code] ir 2202n ... ir 2202n. how to print jam history in ir 2202.......i dont know pls help ... mm its a new machine , i need to know how to enter the service mode if u please ... Press the "Reset" key. Error Code canon image ronner 2202N
Aug 21, 2014
Canon IR 2200 error E000001-002
Jun 18, 2009
More results from www.copytechnet.com
Dec 21, 2015 | Office Equipment & Supplies
Solution to erro e000007 on ir 2420 copier
What is remedy error code E000007-0000 for canon ... - Fixya
www.fixya.com/.../t14373194-remedy_error_code_e000007_0000_can...
Oct 12, 2007 - ... is remedy error code E000007-0000 for canon imageRUNNER2422/2420 ... Copier canon ir 5065 prolems with eror code e 000808-0002.
Imagerunner 2200 error E000007-0000 - CopyTechNet.com
Mar 15, 2007 - 4 posts - ‎4 authors canon ir 2200. hi, this machine do not have fixing roller. machine have fixing film assembly. this code is for damaged fixing film, on the end you ... Error Code Canon 3025 E000007-0000
Jan 30, 2013
Error Code The dreaded e000007-0001 error code!
Sep 5, 2011
Error Code Color ImageRUNNER 4060i has code ...
Jun 30, 2011
Nov 05, 2015 | Office Equipment & Supplies
How i fixes error code e000002 i change new fuesr unite but the error code is not remove pleas help how to solve?
http://www.copytechnet.com/forums/canon/5317-canon-ir-2200-error-code-e000002-0000-a.html
Aug 10, 2014 | Canon Ir 2525 Copier new
How to solve canon ir 3300 error code e0000190000
Neele, Error code E000019-0000 is a waste toner full , to get rid of this error, remove the waste toner bottle located left rear side of the machine,dispose of waste toner and clean the neck of the bottle because waste toner could obstruct the toner sensor beam. Switch off then on, OK to use.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Thread Canon IR 2200 Error E000019 0000
Canon ERROR 19 Waste Toner Tank
Jun 13, 2014 | Canon (6981A002AA) for imagerunner 2200,...
E000007-0000 error in diplay
The Canon imageRUNNER 3300 System error e007 code means that the fusing film is out of Home Position or the film is ripped. You will need to most likely have the fixing film replaced. You are probably going to have to get a service to repair it.
fixya.com/support/t6195187-cannon_ir2018_system_error_e007
November 7, 2002 Product : IR 2200 / 2800 / 3300 Title : E007 code for the IR 2200 / 2800 / 3300 Problem :
E007 code is occurring for the IR 2200 / 2800 / 3300
Solution :
In Service mode / Copier / Function / Part Check, energize M4 (the Fixing Drive motor). If the Fixing Drive motor does not come on, replace M4 (part number FH6-1848-000). Canon USA, Inc. Systems & Technical Support Division
you access service mode by pressing ADDITIONAL FUNCTIONS-2-8-ADDITIONAL FUNCTIONS...
Nov 02, 2010 | Office Equipment & Supplies
Code error of Cannon IR3300 E000006-0000
getfile.asp?rid=1258 November 7, 2002 getfile.asp?rid=3215 Product : IR 2200 / 2800 / 3300 Title : E007 code for the IR 2200 / 2800 / 3300 Problem :
Solution :
Apr 29, 2009 | Office Equipment & Supplies
IR2200
When I pluge my Canon IR 3300 is showing me to Turn OFF and ON the Switch in the right, if the problem did not solve, so please send solution on Email - rajkumarsingh_kushwah@yahoo.com
Apr 28, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Canon Imagerunner 2220i Error Code E000000-0000
canon printer ir 2200 error E000000-0000 my help
Feb 05, 2009 | Canon imageRUNNER C3220 Color Copier
Computers & Internet Logo
8,053 people viewed this question
Top Canon Computers & Internet Experts
Computer Links
Tony
old marine
old marine
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
