Question about Logitech Z-5500 Computer Speakers
Defect in the control station
Two problems in one. Firstly, the control station sometimes won't turn on - even though the unit is powered (judging from the red standby-light). Second, the control station has a tendency to, every once in a while, "hang" in one of the menu's, e.g. when regulating subwoofer/sattelite volume with the "level" button on the panel.
    Problem Solver:
  • 9 Answers
Come to live chat i can surely solve your problem [email protected] i have more than 20 years experiance .
Posted on Sep 06, 2007
SOURCE:
WF-T1022TP(H) INCOMMING WATER DOES NOT STOP
could b eather a pressour switch prob or inlet valve sticking open
Apr 29, 2015 | LG Washing Machines
Why is the base station not working when the power supply is good?
It is highly unlikely that you will be able to buy just a new base station from the original manufacturer. If you are still covered by the warranty, return the unit and try to claim a brand new unit.
Try taking a call even though the red light doesn't work. Sometimes, the bulb can be faulty. This however, shouldn't prevent you from making a call
Oct 12, 2014 | RTX DUALphone 3088
Simrad Shipmate CP32 Chartplotter won't turn on - any suggestions
bad key pad rick or power on and off switch
Jun 11, 2013 | Boating
I have a wweather station model no. CE0681The outdoor control no longer tranmits infromation on tempereture to the inside weather station. How do I solve this problem?
There are a couple of reasons that this can happen. First try replacing the batteries in the outdoor control. Also replace the batteries in the base (inside unit).
You may also need to resynch the two units. (For some models, this requires bringing the outdoor unit inside and removing the batteries. Then add the batteries and let the base station look for the outdoor unit.) With the Davis instruments weather station with the solar powered unit, clean the solar panel. You may need to replace the rechargeable battery.
Sometimes, lightning strikes near the weather station external unit causes a surge that damages the unit. In that case, the entire board may need to be replaced to fix the problem.
Please add a comment with the manufacturer for additional information.
I hope this helps.
Mar 18, 2013 | Measuring Tools & Sensors
Irritrol tc-9ex-b won't water
i have the same problem. What did you do?
Jun 07, 2012 | Irritrol Total Control Outdoor 24 Station
My Canon xti stopped working at my son's graduation. I had a full battery and took a few photos.....then turned it off.....and when I turned it back on again, it was completely dead. Tried several...
Hiyou might have a problem of either main pcb or power control pcd (dc/dc convertor). it is common but it cost. It cause usually come from loosen screw going around inside and short. If it is lucky, then your unit would just a fuse brown. If not, it has to change main pcb and all of computer adjustment is involved. Your local repair shop would charge you around $65 to 235.
Jun 04, 2011 | Canon EOS 400D / Rebel XTi Digital Camera...
Radio stations wont store once key is taken out
if the unit only looses radio station presets then there is a defect with the unit. if the unit looses all its memory, (clock, stations, settings) then there is an issues with your aux power. basically you have the main power connect properly so it turns on the unit while the cars is on but the aux power keeps those settings.
Mar 08, 2011 | Virtual Reality VRCD500-SDU CD Player
I bought my Zeppelin in 2008 in the U.K. although I am now living in Thailand. Recently I started to have problems with it. I was getting a red flashing light with no control over the unit. After a...
even though the aux is ok, this is a power supply board problem which is known by b and w. contact their service desk via the web site to see how they will help you.
the power supply board is a defect which they are fully aware of.
Oct 07, 2010 | B&W Bowers and Wilkins Zeppelin iPod Music...
Control station won't turn on.
That sounds like a hardware faulty i can only advise you to contact logitech.
Jun 04, 2009 | Logitech Z-5500 Computer Speakers
Logitech Z-5500 Computer Speakers Logo
195 people viewed this question
Top Logitech Audio Players & Recorders Experts
Ekse
Michial Gueffroy
Paul
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
