Question about Maytag Atlantis MAV6451 Top Load Washer
Maytag Atlantis Washer
I have some type of coated wire coming through the holes in the tub of my washer. What type of wire is this and will it cause a problem. The washer also makes quite a bit of noise and comes unbalanced often.
I have a Maytag top loading machine and it has stopped spinning. How can I fix it. All other cycles work.
Posted on Jul 04, 2008
  • 183 Answers
This sounds like a foreign object in machine, possible bra wire. Regards Advisor
Posted on Aug 22, 2007
6ya staff
SOURCE:
I have a Maytag Atlantis MAV6200AWW Washer agitates and spins. Water sometimes empties. Pump is fine spins freely and the impeller is fine. Could it be the belt ?
You will need to check for an article of clothing stuck between the basket and tub that may be partially blocking the drain hole.
Nov 22, 2012 | Maytag Atlantis MAV6000 Top Load Washer
Maytag atlantis washer doesnt spin on spin cycle, also found plastic shavings in clothes, appear to be coming from the top outer edge of the tub, a white plastic trim piece. wash cycle seems to work fine...
There can be several causes, the drum off balance would cause the shavings during spin cycle , balance could be one of the the balancing mechanism failed and not running could be the balance sensor shutting down the spin cycle. You should start by checking the balance shocks .
May 14, 2011 | Maytag Atlantis MAV9750A Top Load Washer
Knocking noise during the agitate cycle
you have a brake problem....tub turns while it's washing part?»¿ #21002010 and 35-6918.....will require a specialty tool you can watch videos on you tube just type in maytag atlantis washer
Jan 23, 2011 | Maytag Atlantis MAV6000 Top Load Washer
My Maytag Atlantis is tearing holes in our t-shirts? Any idea what could be causing this?
Hi dingoleo, A typical cause of garment's being torn is not enough water for the amount of items or too many items vs. amount of water...aka overloading. First thing to look for aside from that is insure you have full tub of water and make sure the water isn't siphoning out your drain during the wash cycle. Make sure the drain hose is secure in a standpipe at a minumum of usually 36"-40" hieght...( unless the unit is elevated via a pedestal or other means, the drain has to be adjusted accordingly ) without the hose being pushed down inside the standpipe too far. Just make sure the drain hose exit isn't below the water level of the washer. Also do not cover over the hole where the drain enter's the standpipe, many people do this to keep the drain from popping out, but it causes a siphone effect. Check out those thing's, it's a start. Let me know and if necessary we'll move forward. Than's for coming to "fixya" for assistance. Good luck. Macmarkus :)
Mar 15, 2010 | Maytag Atlantis MAV6000 Top Load Washer
I have a Maytag Atlantis MAV6200AWW. The washer
hi
the solenoid on the cold water is gone down or it is not fed with electric
Jan 29, 2018 | Maytag Atlantis MAV6451 Top Load Washer
Maytag atlantis washer got water leaking from
I have an Atlantis myself. There can be several problems. Did you check that the fill hoses in the back are not leaking? Are they tight? There are hoses inside the washer and a pump near the front. I replaced my pump last year and I,m getting ready to replace the thrust bearing assembly (spin issues). Does the washer leak with every load? make sure water is not splashing over the tub when filling. The front panel comes off if you can and leave off and watch to see where water is coming from.
Feb 17, 2010 | Maytag Atlantis MAV6000 Top Load Washer
I have a maytag Atlantis washer - 7 years old, it
I have a Maytag Atlantis top load washer which leaks in the rear right hand corner under the discharge hose, how do I take the machine apart to get to the problem.
Feb 04, 2010 | Maytag Atlantis MAV6000 Top Load Washer
I have front loader MFW9700 Maytag washer. Water
Check the door seal for tears and the drain boot from tub to drain boot for anything that might have put a hole in like a piece of metal from an under wire bra which front loads will spin so fast that the wires come out of the bras.
Feb 01, 2010 | Maytag EPIC MFW9700S Front Load Washer
Grinding Noise during spin and wash cycles but it' working ok
#1 issue have had with those as a repairman is the pump.the spot welds break and the pump rubs metal to metal also the belt can wear and flap.you can get somthing in the inner tub in those little holes[ie..nail]and when the tub moves it drags.to look at pump,belt motor pulley.tilt washer back .rest on wall and you can inspect all from there.God bless,tom
Jan 03, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV6257AWW
I have a Maytag Atlantis MAV6257AWW. I need to replace the transmission. So I removed all four screws from the inner tub but I couldnt get the inner tub pull out, it's stuck.
From what I read on here, the seal nut doesn't have to be remove in order to remove the inner tub.
I tried every, I even hammer the shaft down from the inside of the tub but still no luck. Can someone help, thanks.
Jun 23, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Atlantis MAV6451 Top Load Washer Logo
111 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
